[In progress] Serviio breaks after latest Java update on Mac
Bumru5h
Post Sat Jul 06, 2013 3:32 am
Re: [In progress] Serviio breaks after latest Java update on
Greetings,
I have the same issue after updating to the latest Java update. Samsung D series TV and movie plays for about 20 minutes before disconnecting. I have to restart the TV to get it to work again. Used to work flawlessly. Running Java 1.6.0_51 according to the console. I will try anything at this point :) Thank you in advance for any help.
Bumru5h
Post Sat Jul 06, 2013 3:40 am
Sorry, forgot to ask this question. I have gone through and deleted prefs, cache, and application support files left over from an old VMware Fusion install thinking this would get rid of those adapters listed in Serviio, however they still show up. Is there anywhere within the application contents to change the settings so that Serviio does not see them? I assume this is why I keep getting the "Could not advertise the device..." that is constantly being posted to the log. The Nic config I am using(native) works fine.
propizza
Post Sun Jul 07, 2013 7:47 pm
Same issue for me, switched to Vuze until Serviio work out a fix
Shred
Post Wed Jul 10, 2013 12:36 am
Likewise...
Serviio works for a while and then can't be seen by the DLNA clients. I haven't had it stop midway through playing content yet but eventually it "disappears" with the Could not advertise the device on any available NIC, will try again log message.
I too updated to the latest Java verson, Java(TM) SE Runtime Environment (build 1.6.0_51-b11-457-11M4509).
My solution is to quit Serviio and start it again. Not good but it's the only thing that works.
Post Thu Jul 11, 2013 9:38 am
Also from this thread - now closed - viewtopic.php?f=5&t=11185
BitStream
Post Mon Jul 15, 2013 10:33 am
We're having the same problem after updating the Mac Mini server. I get about 20 minutes into a video when I get a device disconnect on all of our Samsung TVs. Only way to get Serviio to show as a source again is to power cycle the TV. Serviio has worked flawlessly on my network for about a year prior to this update.
Have this in my log file since the update ..
2013-07-15 05:55:13,001 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2013-07-15 05:55:13,004 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2013-07-15 05:55:18,002 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2013-07-15 05:55:18,006 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2013-07-15 05:55:23,003 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2013-07-15 05:55:23,007 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2013-07-15 05:55:28,005 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2013-07-15 05:55:28,008 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2013-07-15 05:55:33,006 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2013-07-15 05:55:33,010 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2013-07-15 05:55:38,007 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2013-07-15 05:55:38,011 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2013-07-15 05:55:43,008 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2013-07-15 05:55:43,013 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
jeromeof
Post Sat Jul 20, 2013 9:31 pm
I am having this problem also? Anyone got any solution? Was there a beta version of 1.3 which solves this or I am going to have to try another DLNA server for a few weeks?
propizza
Post Sun Jul 21, 2013 10:19 am
I need to find a working solution. Is there another working program that I can use with my mac?
dhuskiss
Post Sun Jul 21, 2013 3:17 pm
Yes same for me. Upgrade to os 10.8.4. Appears on my WD TV box and plays movie for about 3/4 minutes then disappears. I love Serviio. Its been faultless over the last year of use. Hope you guys can this fixed! don't want to change.
angeldust_atlas
Post Mon Jul 22, 2013 1:17 pm
After latest Java update on Mac - temporary solution
Temporary solution - downgrade to Java version 1.6.0_45
As I found it here:
http://www.mathworks.com/matlabcentral/ ... ent_156222
In Terminal, copy and paste these commands...
Check your Java 10.6 version:
/usr/libexec/java_home -v 1.6 -exec java -version
(the bad one is build 1.6.0_51-b11-457-10M4509)
Remove enough of the new Java version to allow re-installation of Java 1.6.0_45:
sudo rm -rf /System/Library/Java/JavaVirtualMachines
sudo rm -rf /System/Library/Frameworks/JavaVM.framework
Find which package is installed on your machine:
pkgutil --pkgs=.*Java.*
Substitute the appropriate package version into the 'forget' command:
sudo pkgutil --forget com.apple.pkg.JavaForMacOSX107
For OSX 10.7 & 10.8 download Java Update 2013-003 from some file sharing server like this:
http://mac.filehorse.com/download-java-for-mac/3485/
Test SHA1 checksum:
openssl sha1 ~/Downloads/JavaForOSX2013-003.dmg
Result should be:
SHA1(/Users/YourName/Downloads/JavaForOSX2013-003.dmg)= 3393ff8642b6e29cacaf10fbb04f76e657cc313a
Open image, install JavaForOSX.pkg...
Check your Java 10.6 version again:
My sw_vers
ProductName: Mac OS X
ProductVersion: 10.7.5
BuildVersion: 11G63
CrumbGuy
Post Tue Jul 23, 2013 5:11 pm
I just updated Serviio and now the new version won't let me choose anything with .mp4 extension in my "movies" file... Any ideas?
Post Wed Jul 24, 2013 12:40 am
@CrumbGuy - please start a new topic. This seems unrelated to the Java problems experienced by others on this topic.
When doing so let us know what version you upgraded to/from, what renderer profile you are using and any mods you may have made, and what TV/device you are using. Test whether the files appear in the "folders" area and advise. Lastly, also provide MediaInfo details for one of the offending files.
lesmikesell
Post Wed Jul 24, 2013 10:58 pm
So is serviio just broken now on current OSX? I replaced my imac an on the new one it starts and players find it at first but after a short time even though it seems to still be running the players don't connect or get errors if they were previously connected.
amkaplan
Post Thu Jul 25, 2013 5:10 am
I see that I am not alone with Serviio troubles. Same story - Serviio had been working great, better than the competition. After a hiatus, I tried to connect and my Sony BluRay won't connect, despite Serviio recognizing the player and saying the server is running. Running 10.8.4, Java 7.25 (build 1.7.0_25-b15).
Looking forward to a solution.
Thanks,
Allan
luketdavis1712
Post Thu Jul 25, 2013 10:17 pm
Anyone have serviio that doesent even see their players?
Trying to work out if mine is same issue... see my othrr post
luketdavis1712
Post Sat Jul 27, 2013 1:46 pm
Any steps to fix this yet? anything I can test?
Luke
angeldust_atlas
Post Sat Jul 27, 2013 3:22 pm
luketdavis1712 wrote:Any steps to fix this yet? anything I can test?
Luke
Can you write us what have you tested already? What is you OSX version, what is your Java 6 version? Do you see your TV in Serviio-Console application (Status tab)?
Start with Terminal (find it via spotlight) and use these commands:
sw_vers
If your Java 6 build is 1.6.0_51, did you downgraded Java as it's writen in previous post?
viewtopic.php?f=5&t=11027&p=73988#p73568
luketdavis1712
Post Sat Jul 27, 2013 10:13 pm
Hi, thanks for the help...
NO I don't see any media players at all :( my Twonky NAS sees them all though, as does some other rubbish media apps.... nothing cuts it like serviio.
java version "1.6.0_51"
Java(TM) SE Runtime Environment (build 1.6.0_51-b11-456-11M4508)
Java HotSpot(TM) 64-Bit Server VM (build 20.51-b01-456, mixed mode)
Lukes-MacBook-Pro:~ Home$ sw_vers
OSX 10.8.4
I will try to roll back Java and come back to you.... I just find it odd I cant even see the media players and my Windows 7 still can.
See my post for troubleshooting: viewtopic.php?f=5&t=11537
Do you think my issue is related?
Cheers
Luke
luketdavis1712
Post Sat Jul 27, 2013 10:34 pm
Now have:
java version "1.6.0_45"
Java(TM) SE Runtime Environment (build 1.6.0_45-b06-451-11M4406)
Java HotSpot(TM) 64-Bit Server VM (build 20.45-b01-451, mixed mode)
Still no devices found... gutted.. should I try and un then re-install Serviio again?
Luke
angeldust_atlas
Post Sat Jul 27, 2013 11:22 pm
luketdavis1712 wrote:Now have:
So it seems like some other issue. I would try to diagnose if TV is reachable.
You can see on snapshots from my Mac, that I can ping Samsung TV and get response, so I guess your Sharp should be also pingable...
