Playlist content appears in alphabetical order !
Venere
Post Fri Jul 19, 2013 10:12 am
Hi Everybody,
I want to use video playlist with classical m3U format (#EXT.....). My problem is on my tv, when i click on my playlist the contents appears in alphabetical order, not in the playlist order.
Anyone have an idea ?
Thank you for reply.
Serviio 1.4 - TV Samsung UE40ES6710 - DELL XPS8500, Windows 8.1, Ram 8 Go, CPU 3,40 Ghz
Post Mon Jul 22, 2013 11:36 am
Re: Playlist content appears in alphabetical order !
Can you post the playlist file and screenshot of the TV?
Venere
Post Mon Jul 22, 2013 5:22 pm
Here is my playslit (fully functional with vlc for example) DiversLive.m3u :
#EXTM3U
#EXTINF:626,George Duke, David Sanborn, Marcus Miller - Brazilian Love Affair - 2011
./Divers/George Duke, David Sanborn, Marcus Miller - Brazilian Love Affair - 2011.mkv
#EXTINF:561,Air - La Femme D'Argent (Live @ Fuji Rock Festival '10).flv
./Divers/Air - La Femme D'Argent (Live @ Fuji Rock Festival '10).flv
#EXTINF:233,Acoustic Alchemy - Roseland - Java Jazz Festival - 2011
./Divers/Acoustic Alchemy - Roseland - Java Jazz Festival - 2011.mkv
#EXTINF:416,Stanley Clarke & George Duke - 1981 - Schooldays
./Divers/Stanley Clarke & George Duke - 1981 - Schooldays.mpg
#EXTINF:213,Matt Bianco - Ordinary Day
./Divers/Matt Bianco - Ordinary Day.mp4
#EXTINF:361,Toto - Georgy Porgy
./Divers/Toto - Georgy Porgy.mkv
#EXTINF:368,Crusaders - Randy Crawford - Soul Shadows
./Divers/Crusaders - Randy Crawford - Soul Shadows.mkv
And here is what is shown when i select my playslist on my TV :
It's the exact content of the list but as you can see it's listed in alaphabetical order.
Post Wed Jul 24, 2013 7:02 pm
Can you check to list the playlist in VLC or MediaBroswer? It should sort properly, but the TV might be sorting them alphabetically.
Venere
Post Thu Jul 25, 2013 7:57 am
zip wrote:Can you check to list the playlist in VLC or MediaBroswer? It should sort properly, but the TV might be sorting them alphabetically.
As i said the playlist is ok with VLC.
If someone in this forum uses m3u playlist format, can you tell me if it works in the right order ?
Note that i try with pls format and it's the same -> alphabetical order.
Perhaps a samsung Series E problem ?
Venere
Post Mon Jul 29, 2013 1:28 pm
It has to be said that apparently nobody uses playlists with Serviio.
However it seems that many DLNA servers have problems with playlists and apparently it's the same with Serviio.
But that would be better if Serviio team could confirm the problem to avoid searching a solution for days.
Post Mon Jul 29, 2013 10:10 pm
If the playlist look ok in VLC (via Serviio), then Serviio sends it in the right order.
Venere
Post Tue Jul 30, 2013 11:08 am
Hi Zip,
The playlist appears in the right order in VLC via Serviio but not on the TV.
Do you think it could be a parameter in the Samsung TV / Player (C/D/E-series) profile ?
Post Tue Jul 30, 2013 11:24 am
I don't think so. Do other items you browse appear in the right order and not alphabetically (e.g. audio tracks on an album)?
Venere
Post Tue Jul 30, 2013 12:11 pm
Yes it's the same alphabetical order with an audio playlist.
I use exclusively folder option for browsing my files on the TV and it always sort alphabetically any kind of file, folder and playlist.
I dont' find any parameter on the TV to avoid this and apparently DLNA requests are overriden by that.
It's surprising that nobody reports this kind of behavior.
Post Tue Jul 30, 2013 1:53 pm
In Folders category they are ordered alphabetically by file name, that's fine. You could turn on Audio / Albums and see how it's ordered in these categories.
Venere
Post Thu Aug 01, 2013 1:00 pm
I've tried with 3 differents DLNA servers and it's the same behavior for all.
My conclusion is this is the TV and i must say it's a shame for a supposed DLNA renderer. I'll try to get support from samsung and i'll post the response (if they do it !).
Post Thu Aug 01, 2013 8:25 pm
Thanks for confirmation
sheldon
Post Sun Aug 25, 2013 1:47 pm
This issue appears to be related to the version of the Samsung environment being used. I own several samsung smart TV's and have two on my desktop that I use as PC monitors. One of them is a smart tv which I purchased 3 years ago, the other is an ES8000 which I purchased the other day and is this years model. I created several playlists with varying sort orders and placed them where they could be read in Serviio. On the older model the lists appear the order they were placed in the m3u/ playlist file e.g. by date, chapter number etc. In the newer model, though, they appear in alphabetic order. Since all my internal systems are connected to the network I checked the other sets connected through serviio and the older systems show the correct sort order while the more recent Samsung, like the one on my desktop, displays the information alphabetically. I would conclude Samsung changed its upnp to sort these lists in alphabetic order for their newer smart TV's. The m3u file is merely a directory dump of file names and locations. I am not sure as to why Samsung has made this specific change to their display of a playlist, but they have, and are disregarding certain information in the playlist file and re-sorting that information alphabetically.
Venere
Post Thu Sep 05, 2013 6:11 pm
I confirm :
Samsung says play with the color buttons on the remote control but it does nothing.
The tools menu is very poor and i can't change anything.
This problem is only for video m3u playlists, the music playlists are displayed in the right order.
So at this point i don't see any solution. Thanks for your support.
apw2607
Post Wed Oct 30, 2013 12:08 am
Yes, I can confirm the same behavior with the new Samsung Smart Media Player.
All video playlists are shown in alphabetical order regardless of the order they are in within the playlist. My Sony BDP works perfectly with Serviio playlists and shows the correct playlist order.
What the heck was Samsung thinking????
Very frustrated.
kingsped
Post Wed Dec 18, 2013 3:19 am
Just to add my 2 cents, my audio playlists (all m3U8's) were created in MP3Tag and work as intended in WinAmp, Serviio, WDLive, WDLive from Serviio, but NOT my Samsung UN40F5500. In their wisdom, I guess, the folks at Samsung decided that I didn't really want the list as constructed, so they sorted it alphabetically on Title. For a randomized playlist that I wanted, would have preferred if they sorted, say, on file size.
Now to show my ignorance about DLNA: Why doesn't Serviio, since it's streaming, just send one track/file/song from the playlist at a time, thereby maintaining the integrity of the playlist order? I bet the Samsung's dumb enough not to care.
