[SOLVED] version 1.3 make windows 7 64b slower
Only after I stopped the service that my windows return to normal.
Finally I've ditch the 1.3 and put back the 1.2.1.
Please remove the 1.3 from your web site and don't bring it back until you fix it.
alando22 wrote:Maybe there is a problem with the plugins. I had the same problem with the slow system but after deleting all plugins and a reboot everything seems to be ok at the moment.
alando22 wrote:Update:
The Plugins are not the problem. Now my system (Win7 64Bit) is very slow again. Going back to 1.21
Illico wrote:alando22 wrote:Update:
Could you enable detailed logging and check the serviio log file ?
Users browsing this forum: Baidu [Spider] and 14 guests
