Yamaha BD-A1020
• Page 2 of 2 • 1, 2
Ok, great news, thank you ;)
Re: Yamaha BD-A1020
Dear Illico
I remeber about it
- will you please...?
Please recall me to update your profile for these files format when 1.3 will be released.
I remeber about it
Re: Yamaha BD-A1020
djivatma wrote: I remeber about it- will you please...?
- Could you install the latest 1.3 version,
- Make a backup of ../serviio/config/profiles.xml
- Edit and copy/paste the following just before the last </Profiles> element at the end of profiles.xml file ?
- Restart Serviio services or reboot PC
- Check that wavpack (*.wv), Musepack (*.mpc) and Monkey's Audio (*.ape) audio files were transcoded to your device.
- Code:
<Profile id="YamBD" name="Yamaha BD-A1020/BD-A1010" extendsProfileId="1">
<!-- YAMAHA BD-A1020, BD-A1010, -->
<Detection>
<UPnPSearch>
<FriendlyName>BD-A10(1|2)0</FriendlyName>
<Manufacturer>YAMAHA CORPORATION</Manufacturer>
</UPnPSearch>
</Detection>
<!--For WLAN system mp3 target could be used -->
<!--Audio targetContainer="mp3" aBitrate="192" aSamplerate="44100" -->
<Matches container="mp4" /> <!-- The device should plays audio/mp4 natively so this line can be removed-->
<Matches container="flv" />
<Matches container="asf" />
<Matches container="rtp" />
<Matches container="rtsp" />
<Matches container="wavpack" />
<Matches container="mpc" />
<Matches container="ape" />
</Audio>
Re: Yamaha BD-A1020
It's all OK, thank you very much!
Re: Yamaha BD-A1020
djivatma wrote:It's all OK, thank you very much!
I ask Zip to add it to the next release : https://bitbucket.org/xnejp03/serviio/i ... 20-profile
Users browsing this forum: Google [Bot] and 43 guests
