Yamaha BD-A1020
djivatma
Post Thu Jun 27, 2013 9:42 am
Re: Yamaha BD-A1020
Ok, great news, thank you ;)
djivatma
Post Thu Aug 08, 2013 3:25 pm
Re: Yamaha BD-A1020
Dear Illico
Please recall me to update your profile for these files format when 1.3 will be released.
I remeber about it :) - will you please...?
Post Fri Aug 09, 2013 7:41 am
Re: Yamaha BD-A1020
djivatma wrote: I remeber about it :) - will you please...?
- Could you install the latest 1.3 version,
- Make a backup of ../serviio/config/profiles.xml
- Edit and copy/paste the following just before the last </Profiles> element at the end of profiles.xml file ?
- Restart Serviio services or reboot PC
- Check that wavpack (*.wv), Musepack (*.mpc) and Monkey's Audio (*.ape) audio files were transcoded to your device.
       <Profile id="YamBD" name="Yamaha BD-A1020/BD-A1010" extendsProfileId="1">
          <!-- YAMAHA BD-A1020, BD-A1010,   -->
          <Detection>
             <UPnPSearch>
                <FriendlyName>BD-A10(1|2)0</FriendlyName>
                <Manufacturer>YAMAHA CORPORATION</Manufacturer>
             </UPnPSearch>
          </Detection>
             <!--For WLAN system mp3 target could be used -->
             <!--Audio targetContainer="mp3" aBitrate="192" aSamplerate="44100" -->
                <Matches container="mp4" /> <!-- The device should plays audio/mp4 natively so this line can be removed-->
                <Matches container="flv" />
                <Matches container="asf" />
                <Matches container="rtp" />
                <Matches container="rtsp" />
                <Matches container="wavpack" />
                <Matches container="mpc" />
                <Matches container="ape" />
             </Audio>
djivatma
Post Sat Aug 10, 2013 7:52 am
Re: Yamaha BD-A1020
It's all OK, thank you very much!
Post Sat Aug 10, 2013 7:58 am
Re: Yamaha BD-A1020
djivatma wrote:It's all OK, thank you very much!
I ask Zip to add it to the next release : https://bitbucket.org/xnejp03/serviio/i ... 20-profile
Previous
Users browsing this forum: Google [Bot] and 35 guests
