[In progress] Serviio breaks after latest Java update on Mac
luketdavis1712
Post Sun Jul 28, 2013 8:04 am
Re: [In progress] Serviio breaks after latest Java update on
No problem pinging it... :(
--- 192.168.0.5 ping statistics ---
9 packets transmitted, 8 packets received, 11.1% packet loss
round-trip min/avg/max/stddev = 4.438/15.805/44.462/11.907 ms
Lukes-MacBook-Pro:~ Home$ ping 192.168.0.5
PING 192.168.0.5 (192.168.0.5): 56 data bytes
64 bytes from 192.168.0.5: icmp_seq=0 ttl=64 time=110.940 ms
64 bytes from 192.168.0.5: icmp_seq=1 ttl=64 time=5.576 ms
64 bytes from 192.168.0.5: icmp_seq=2 ttl=64 time=6.903 ms
64 bytes from 192.168.0.5: icmp_seq=3 ttl=64 time=4.888 ms
64 bytes from 192.168.0.5: icmp_seq=4 ttl=64 time=3.306 ms
64 bytes from 192.168.0.5: icmp_seq=5 ttl=64 time=5.355 ms
64 bytes from 192.168.0.5: icmp_seq=6 ttl=64 time=7.782 ms
64 bytes from 192.168.0.5: icmp_seq=7 ttl=64 time=4.591 ms
64 bytes from 192.168.0.5: icmp_seq=8 ttl=64 time=4.674 ms
64 bytes from 192.168.0.5: icmp_seq=9 ttl=64 time=7.540 ms
angeldust_atlas
Post Sun Jul 28, 2013 10:39 am
luketdavis1712 wrote:No problem pinging it... :(
I’m getting out of ideas.
Do you run Serviio.app as current user or with root privileges?
Via Terminal:
sudo /Applications/Serviio.app/Contents/MacOS/JavaApplicationStub
Or do you start it via Launchd on boot as described here (also root privileges): http://wiki.serviio.org/doku.php?id=mac_launchd
You can also check open ports (more details here http://wiki.serviio.org/doku.php?id=portinfo_mac):
sudo lsof -i -P | grep JavaAppli
My response is this:
JavaAppli 4933           root   61u  IPv4 0xffffff8031105500      0t0    TCP 192.168.0.100:44331 (LISTEN)
JavaAppli 4933           root   62u  IPv4 0xffffff801b85f6c0      0t0    TCP localhost:58292->localhost:58291 (TIME_WAIT)
JavaAppli 4933           root   63u  IPv4 0xffffff802fe116c0      0t0    TCP *:23423 (LISTEN)
JavaAppli 4933           root   64u  IPv4 0xffffff801b8a9c20      0t0    TCP *:23424 (LISTEN)
JavaAppli 4933           root   90u  IPv4 0xffffff801b85ade0      0t0    TCP *:8895 (LISTEN)
JavaAppli 4933           root   91u  IPv4 0xffffff802f526368      0t0    UDP *:1900
JavaAppli 4933           root  116u  IPv4 0xffffff801b8a3c20      0t0    TCP 192.168.0.100:8895->192.168.0.102:35421 (ESTABLISHED)
dhuskiss
Post Thu Aug 01, 2013 11:39 am
Just checking in.....has there been any progress? I miss my Serviio
luketdavis1712
Post Thu Aug 01, 2013 11:48 am
Just as an update from me i swapped my mac book to my partners mac book which had no java update... i will use this until the issue is fixed
Post Thu Aug 01, 2013 8:23 pm
1.3 with the fix is coming out probably next week
Post Wed Aug 07, 2013 9:56 pm
This should now be fixed in the released 1.3
propizza
Post Sun Aug 11, 2013 10:50 am
Working perfect again now.....Thanls
Mattttttttt
Post Sat Feb 14, 2015 10:50 pm
I'm sorry if this is the wrong place to post this...
My Sony Bravia KDL-32CX523 (Ethernet straight from Virgin Media Superhub) stopped picking up Serviio form my Windows 7 laptop this week after months of working perfectly.
I have tried updating Java, reinstalling Serviio, making sure the firewall is letting everything through. I've even tried a system restore.
There's a green dot next to the TV in the console so it all looks like it should be working fine, but it's still not showing up.
Is there anything else I should be trying please?
Previous
