[SOLVED] Sony TV (wifi) Cannot find server (Lan cable)
kevinzh
Post Sun Aug 11, 2013 12:18 pm
Struggled for 2 days...tried every thing (well...I think).
My Sony W670A cannot even see the Serviio Server.
I have following devices home,
- Sony W670A TV. 192.168.0.9 (WIFI)
- Windows XP PC installed Serviio (on Cable . 192.168.0.8) Problem here...can never be found by Sony TV.
Tried:
- Fixed IP.
- Reinstalled Serviio and Java..
- reset factor on Sony TV
- installed 4 other Media servers...same problem
Another windows 8 (on LAN cable) and a Samsung TV (also on LAN Cable) can see/connect to the Serviio without any problem!
just Sony TV (on wifi) cannot connect!
Run another test:
installed serviio on my new windows 8 tablet (wifi), it runs no problem! Sony TV can pick it up in seconds!
was thinking it is the problem with windows XP. but really confused.
Post Sun Aug 11, 2013 1:37 pm
Re: My Sony TV (wifi) Cannot find Serviio server (Lan cable)
Have you checked your windows firewall and any antivirus software to ensure Serviio is allowed full inbound and outbound access?
NX3
Post Sun Aug 11, 2013 7:20 pm
Turn off any firewall for a few minutes see if it works.
Also post your log file
Lowlander
Post Mon Aug 12, 2013 5:33 pm
Can you access the internet from your Sony TV? I assume there is an internet router involved...
Can you access your Serviio server from any other wireless device (Win8 tablet?)?
Did you try to establish a wired connection from your Sony TV?
kevinzh
Post Fri Aug 30, 2013 11:34 pm
Sorry guys...was on business trips in the last couple of weeks... thanks for the replies.
Yes. I can access internet from my Sony TV
and Yes my sony tv can access my win9 tablet on wifi
tried turning off firewall. still the same
no antivirus running at the time
No log file as the TV doesn't even know the serviio server exists.
ok. the problem is
Sony TV (Wifi) -> win8 tablet serviio server(wifi). OK
Samsung tv (wired) ->windows XP PC serviio server (wired) - OK
Sony TV (Wifi) -> windows XP PC serviio server (wired) . Not OK
Samsung tv (wired) ->win8 tablet serviio server(wifi) - Not Ok
I check my modem/router completely and didn't find any setting separates wifi one with my wired ones.
Log file didn't record anything....
Lowlander
Post Sat Aug 31, 2013 6:10 am
Some routers can restrict the way wireless devices communicate with each other, but this is fine here.
Can you please check if all four IP-addresses are on the same subnet with a matching subnet mask?
| Serviio Pro 1.6 (Win Server 2008 R2, Athlon 240e, 4GB RAM, 6TB HDD) |
| Sony KDL-42W829B | Sony KDL-24EX320 | Yamaha BD-S677 | assorted iDevices |
kevinzh
Post Sat Aug 31, 2013 6:34 am
Lowlander wrote:Some routers can restrict the way wireless devices communicate with each other, but this is fine here.
Yes they are all on the same subnet mask and same ip range.
192.168.0.2~192.168.0.50
Post Sun Sep 01, 2013 3:05 pm
What model router are you using?
Lowlander
Post Sun Sep 01, 2013 4:15 pm
Do you have a chance to wire our Sony TV for testing?
cefn
Post Mon Sep 16, 2013 4:39 pm
Sorry to add my bit ..... get exactly the same problem ..
(useing BT home hub2 router)
Windows 8 on wireless lappy ...
Sony KDL22EX553 wireless all works ok!
As soon as i plug the lappy into the lan wham!!! ... no serviio ... did all the same fixes as kevinzh but one!
i installed "ps3mediaserver" and out of the box worked ok with the lappy wired?
Also serviio showed on tv but never worked?
Any help?
Post Mon Sep 16, 2013 6:46 pm
Clean the server list on sony menu (networks settings) and refresh.
Same on serviio console, clean the device list.
Lowlander
Post Tue Sep 17, 2013 10:30 am
You could also make sure that your lappy is not connected via wireless and wired at the same time. Having a host on one network/subnet with two MAC- and IP-Adresses can cause issues.
cefn
Post Tue Sep 17, 2013 5:37 pm
Illico wrote:Clean the server list on sony menu (networks settings) and refresh.
Same on serviio consol, clean the de
vice list.
Many thanks that did the trick! :D
mcinnocent
Post Tue Oct 08, 2013 4:46 pm
Re: [SOLVED] Sony TV (wifi) Cannot find server (Lan cable)
THX Also!
This helped me with my Sony BDP-S390 Blu-ray Player.
After a Router change I could not anymore see the serviio server on my PC.
Cleaning the serverlist in both devices, PC and Blu-ray player solved the problem!
Users browsing this forum: No registered users and 252 guests
