[CLOSED] After 1.3 upgrade! Some files suddenly unplayable
talanmawr
Post Tue Aug 13, 2013 4:33 pm
Hi all. All of my media is ripped into WMV format for portability. On my Sony Blu-Ray player with Serviio 1.2 I never had a problem with any media and one title would flow to the next seamlessly after playing.
Now after upgrading to 1.3 I might venture to guess that more than half of my library won't play, and when one title finishes it cannot progress to the next saying that the file is corrupt or unplayable. This was never the case before the upgrade, and all of the titles are ripped from their original sources the same way.
Is there a way to re-download 1.2 or 1.2.1, or does anyone know why this might be happening? There's no logged information, but I also haven't turned on debugging either. Seems like a stupid problem to have with just an upgrade.
Post Tue Aug 13, 2013 7:38 pm
Re: Need help after 1.3 upgrade! Some files suddenly unplaya
Are you using the same profile as before?
talanmawr
Post Tue Aug 13, 2013 9:08 pm
Yes, I suppose. I haven't changed anything. In fact I had installed over 1.2.1 as suggested just because I was keeping the same library. I don't recall really changing much of anything (let alone a profile) when I installed Serviio a couple of months ago as it "just worked". Is there a protocol I should try to use (not even sure where to change that specifically). Almost all media was ripped to WMV to support portable uses on a Zune as well as Android.
talanmawr
Post Wed Aug 14, 2013 6:25 am
The device and profile is Sony BDP-Sx70/SMP-N100 (2010). All of the files are now apparently unplayable (all WMV's), and the few AVI's aren't showing up at all.
I'm completely new to all of this so any direct hand holding or pointing to explicit resources would be great. This literally worked fine a few days ago.
Post Wed Aug 14, 2013 10:26 pm
WMV should be transcoded with this profile..
can you post detailed log of playing the file?
talanmawr
Post Thu Aug 15, 2013 12:45 am
I'll do this tonight. Thanks so much Zip. I see you all over these boards giving help...I really appreciate it. The wife is a bit annoyed that I tinkered with a software upgrade when she was already enjoying the server. ;-)
talanmawr
Post Thu Aug 15, 2013 1:05 am
I've uploaded and attached the log to this post. I edited out the library look-up lines because of file size, but this is otherwise the entire log from when I just restarted the service and server. From my Sony player, I requested Serviio to play a single WMV movie. I got the unplayable message, which kept repeating itself. I assume it was moving on to the next file on it's own...but that's just a guess.
serviio log 08142013-1.txt
(180.69 KiB) Downloaded 672 times
Post Thu Aug 15, 2013 8:24 am
the log doesn't include actually playing the file.
talanmawr
Post Fri Aug 16, 2013 2:04 am
Well Zip, I went to recreate the whole process again...
renamed the log file (it had gotten really large)
exited the console
stopped the server
started the server (new log created)
started the console
went to launch a movie...
They all played thus far. Suddenly with no reason whatsoever, everything started playing. No updates to Blu-Ray player, no server updates, no changes in the network. Just started working. Thanks for the offer of help! I have a large library, I suppose I know how to post a detailed log for help now if nothing else. ;-)
talanmawr
Post Mon Sep 30, 2013 7:02 am
Weird! This just started happening again! We were watching a TV series, and suddenly without warning, the next file came up as corrupted, and then the enxt, and then the next. I stopped the Blu-Ray player, and restarted it, and then it just told me there was no playable files. Still using the same profile, but I changed it to the US version (for avi support). Still, it had been working absolutely fine for weeks. No idea why it suddenly cut out!
Post Sun Oct 13, 2013 8:17 am
Do you have wired or wifi interface ?
I suggest to fix all IP address of your devices (rooter configuration - or - devices network settings), what is your network setting?
talanmawr
Post Sun Oct 13, 2013 6:26 pm
It's a wired connection, and it's all back again.
Just doesn't make sense. But it's working right now so we're ok. ;)
Post Sun Oct 13, 2013 6:30 pm
talanmawr wrote:It's a wired connection, and it's all back again.
Well enjoy it...
