Subtitles stop working in 1.3
jamir2013
Post Mon Aug 12, 2013 1:27 pm
Hello
I was using servio 1.2 working great with my sony bravia 40nx700 and now with the 1.3 update the subtitles work intermitent, ie, they only appear like in intervals of 10 sec and just one sentence, then they dont show for more 10 sec.
Any help?
PS. Sory for the english im portuguese.
Post Mon Aug 12, 2013 7:56 pm
Re: Subtitles stop working in 1.3
Can you send me the subtitles file? zip[at]serviio[dot]org
jamir2013
Post Tue Aug 13, 2013 1:34 am
sure i will send it to you, but it happens to all files (i have arround 200) and they all worked before and stoped now and i didn't "touch" the files also they work great with others softwares, but if you want i can send it.
Post Tue Aug 13, 2013 6:20 pm
I tried with a file I have and all worked as expected. Are you on Windows? Did you use some character encoding in the console other than utf-8 ?
jamir2013
Post Wed Aug 14, 2013 1:36 pm
Yes i am in windows, and like i said before there is no problem with the files because they were working fine before 1.3 and they all work fine with other media servers, only with serviio 1.3 they dont work
Post Wed Aug 14, 2013 10:23 pm
can you try the latest ffmpeg? http://wiki.serviio.org/doku.php?id=win_ffmpeg
egh2ema
Post Thu Aug 22, 2013 9:14 pm
Dear, I have the same problem as mentioned in this forum, with the 1.2.1 version did not experience this problem, and Realize the ffmpeg update to version mentioned in the link but the problem persists, you think of any other solution for this problem.
Serviio is running on Windows 7 HP 64B.
Serviio is configured as described in this forum.
Greetings to you very carefully. :D
Emanuel
irahodei
Post Sun Aug 25, 2013 11:40 am
It's also happening to me. In 1.2.1 all subs are working fine but in this new version one sentence ok and 10secs ko.
I've already updated ffmpeg... what can i do?? Thanks in advance
RenoRJ
Post Sun Aug 25, 2013 2:39 pm
Same problem here, but I noticed that it not occur for english subtitles.
I used portuguese brazilian subtitles, and it works perfectly on version 1.2.1. After the upgrade to version 1.3 (and 1.3.1) it stopped working properly, some of them appeared some not.
I't's not a problem with the subtitle files (already checked them), but to test I got a english subtilte and it worked fine.
The solution for me was to downgrade to version 1.2.1 and all my subtitles are working fine again. :)
Let me know if you find a solution for the 1.3 version.
Regards
Post Mon Aug 26, 2013 9:09 am
what character encoding do you have in the console. And can someone send me the srt file that's causing this to the email address above?
RenoRJ
Post Mon Sep 02, 2013 5:40 am
Just sent an email with the file attached.
Regards
Post Sun Sep 15, 2013 4:09 pm
So the subtitles file is not in UTF-8 encoding and FFmpeg skipps the lines with illegal characters. Previous FFMpeg didn't do that.
To get around it for your file(s), enter this to the character encoding field in the console
iso8859-2
I will try to make it more error prone for future.
awatrin
Post Tue Nov 26, 2013 2:34 pm
Hi, I've tested a lot of codes, and the one that works with brazillian portuguese subtitles is: iso8859-1
It shows all the characters, including ç, ê, é, etc.
achtoug
Post Wed Dec 25, 2013 1:43 pm
irahodei wrote:It's also happening to me. In 1.2.1 all subs are working fine but in this new version one sentence ok and 10secs ko.
Hi All
Same problem here with finnish language, from the version 1.3 the subtitles work only sometimes or not at all :( I had to get back to the version 1.2.1 :!:
Sony Blu-ray Player BDP-S480
Post Wed Dec 25, 2013 7:21 pm
achtoug wrote:...
Where does subtitles come from ? avi, mkv embedded, external srt file ? please could you provide more informations?
achtoug
Post Wed Dec 25, 2013 10:01 pm
Illico wrote:
achtoug wrote:...
Hi Illico
The subtitles are external srt file.
Regards
ciberglo
Post Sat Dec 28, 2013 2:25 am
awatrin wrote:Hi, I've tested a lot of codes, and the one that works with brazillian portuguese subtitles is: iso8859-1
Mannnnn, this solution is AMAZING!!! I'm also from brazil, and this was the only solution I've found to work with our subtitles in a Sony Bravia tv (nx655).
Thank you to share this solution. For everyone else with pt-br (brazil/brazilian) subtitles, please change the Subtitle character encoding (inside Delivery/Subtitles tab) to iso8859-1
Thanks! Muito obrigado! Valeu! hehe
eugeniombr
Post Wed Jul 02, 2014 2:43 am
Hi everyone,
I've changed character encoding to iso8859-1 in order to play videos with subtitles in pt-br (portuguese/brazil) but I'm still having the same problem mentioned above. Serviio doesn't recognize the ".srt" files. When I watch those same movies/series locally in VLC or Quicktime I can choose my pt-br subtitles and they work fine. However, when I try to use Serviio I can stream those movies but the pt-br subtitles doesn't work.
My TV is a SAMSUNG UN40FN5500 and I'm using Serviio 1.4.1.2 on a Mac with MacOS 10.9.3. They are connected with "Generic DLNA Profile". I tried to use "Samsung TV / Player (E/F - Series)" profile but the problem get worse. On that profile, my TV can't connect on Serviio.
I'll be very please if anyone can help me with this issue...
Users browsing this forum: No registered users and 186 guests
