Mediabrowser MKV subtitles
secretdk
Post Thu Aug 15, 2013 9:06 pm
Subtitles from a MVK media file don't seem to work in the mediabrowser.
The video plays, but the subtitles don't appear.
Will this be fixed?
Post Thu Aug 15, 2013 9:32 pm
Re: Mediabrowser MKV subtitles
Have you turned on the option to extract embedded subtitles in the console?
secretdk
Post Fri Aug 16, 2013 12:45 am
will wrote:Have you turned on the option to extract embedded subtitles in the console?
Yes, should i also emable burned in subtitles?
Post Fri Aug 16, 2013 10:57 am
That should not be necessary. Is the CC button visible in the player window?
secretdk
Post Fri Aug 16, 2013 11:37 am
zip wrote:That should not be necessary. Is the CC button visible in the player window?
This is all i got, no cc button and no subbies.
Post Fri Aug 16, 2013 7:16 pm
did you enter the language code of subtitles you want to extract in the console?
secretdk
Post Fri Aug 16, 2013 9:20 pm
zip wrote:did you enter the language code of subtitles you want to extract in the console?
Its empty at this moment. What should i fill in for english language code?
EDIT: Found this link, will get back here if this doesn't solve it.
http://www.serviio.org/index.php?option ... icle&id=33
secretdk
Post Sat Aug 17, 2013 11:36 am
On my pc i get totally nothing. On my iOS device i do get the option for subtitles, but it still doesn't give any subtitles.
PC:
iPad:
Post Sat Aug 17, 2013 6:44 pm
post ffmpeg -i of the file and what language code did you enter in the console?
nanoflower
Post Fri Aug 08, 2014 6:33 pm
Hi, I'd like to follow up on this one. I have the exact same problem; no subs when playing mkv's in the Mediabrowser .
There is no CC button in the browser (Chrome). On the iPad the option is there and i can choose between: "Off", "Auto" and "Unknown CC" neither produce any subs.
I running the lates Serviio and have "Extraction of subtitles" is enabled.
I have tried setting the language code to: "EN,DA" for English and Danish, "English" and "En" (no quotes) and that has not helped - Am I using the right language code format?
Brgds, Nanoflower
nanoflower
Post Fri Aug 08, 2014 7:26 pm
I figured it out - I enabled all options (subtitles, extraction and burned-in) and set the language code to: en,eng,english,da,danish,dk
The Subs are very small though, is there any way to change this?
Users browsing this forum: Google [Bot] and 66 guests
