Re: YouTube
Just:
- Folders
- Genres
- Series
- titles
- Recently Viewed.
2013-10-05 10:50:59,097 WARN [FeedUpdaterThread] Failed to retrieve online item information for http://r5---sn-fpoq-o52e.c.youtube.com/videoplayback?fexp=939110%2C919111%2C932100%2C932241%2C914062%2C916626%2C924606%2C924616%2C916914%2C929117%2C929121%2C929906%2C929907%2C929922%2C929923%2C929127%2C929129%2C929131%2C929930%2C936403%2C925724%2C925726%2C936310%2C925720%2C925722%2C925718%2C936401%2C925714%2C929917%2C906945%2C929933%2C929935%2C929937%2C929939%2C939602%2C939604%2C912909%2C937102%2C906842%2C913428%2C912715%2C919811%2C939908%2C935704%2C932309%2C913563%2C919373%2C930803%2C908538%2C932211%2C931924%2C938608%2C940501%2C936308%2C939201%2C900816%2C912711%2C916304%2C900391%2C934507%2C907231%2C936312%2C906001&sparams=algorithm%2Cburst%2Cclen%2Ccp%2Cdur%2Cfactor%2Cgcr%2Cgir%2Cid%2Cip%2Cipbits%2Citag%2Clmt%2Csource%2Cupn%2Cexpire&upn=ftXHxjWwesA&factor=1.25&id=46ce02494016dc80&itag=5&expire=1380985437&key=yt1&gcr=it&ipbits=8&source=youtube&cp=U0hXRVlTU19IUUNON19RTVdFOlNZN2doYmFVVzd6&mv=m&mt=1380962991&ms=au&lmt=1366060736189485&sver=3&clen=7011112&gir=yes&ip=62.98.22.234&algorithm=throttle-factor&dur=159.974&burst=40. It might not play.
java.io.IOException: org.serviio.library.local.metadata.extractor.InvalidMediaFormatException:Unknown video file type.
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:320)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:237)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:116)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:454)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:97)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:135)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:297)
... 2 more
2013-10-05 10:50:59,463 WARN [FeedUpdaterThread] Failed to retrieve online item information for http://r7---sn-fpoq-o52e.c.youtube.com/videoplayback?factor=1.25&burst=40&gcr=it&sparams=algorithm%2Cburst%2Ccp%2Cfactor%2Cgcr%2Cid%2Cip%2Cipbits%2Citag%2Csource%2Cupn%2Cexpire&source=youtube&upn=Vr0L1m8tDSU&key=yt1&fexp=901481%2C932248%2C930102%2C935010%2C924606%2C924616%2C916914%2C921905%2C929117%2C929121%2C929906%2C929907%2C929922%2C929923%2C929127%2C929129%2C929131%2C929930%2C936403%2C925724%2C925726%2C936310%2C925720%2C925722%2C925718%2C936401%2C925714%2C929917%2C906945%2C929933%2C929935%2C929937%2C929939%2C939602%2C939604%2C937102%2C906842%2C913428%2C912715%2C919811%2C939908%2C935704%2C932309%2C913563%2C919373%2C930803%2C908538%2C931924%2C938608%2C940501%2C936308%2C939201%2C900816%2C912711%2C916304%2C935012%2C900391%2C934507%2C907231%2C936312%2C906001&cp=U0hXRVlTVF9MUENON19RTVhGOlZoMW1sZHhlamUy&ip=62.98.22.234&itag=5&algorithm=throttle-factor&mt=1380962991&expire=1380986576&mv=m&sver=3&id=0517b830508ac112&ms=au&ipbits=8. It might not play.
... 2 more
2013-10-05 10:51:00,118 WARN [FeedUpdaterThread] Failed to retrieve online item information for http://r6---sn-fpoq-o52e.c.youtube.com/videoplayback?cp=U0hXRVlTVF9MUkNON19RTVhHOl84QmljZGwzZnRn&ms=au&ipbits=8&mv=m&source=youtube&burst=40&sparams=algorithm%2Cburst%2Ccp%2Cfactor%2Cgcr%2Cid%2Cip%2Cipbits%2Citag%2Csource%2Cupn%2Cexpire&expire=1380986678&id=1d7167aecb29c3bf&sver=3&fexp=906942%2C927845%2C941201%2C916626%2C936204%2C924606%2C924616%2C916914%2C929117%2C929121%2C929906%2C929907%2C929922%2C929923%2C929127%2C929129%2C929131%2C929930%2C936403%2C925724%2C925726%2C936310%2C925720%2C925722%2C925718%2C936401%2C925714%2C929917%2C906945%2C929933%2C929935%2C929937%2C929939%2C939602%2C939604%2C937102%2C906842%2C913428%2C912715%2C919811%2C939908%2C935704%2C932309%2C913563%2C919373%2C930803%2C908538%2C931924%2C938608%2C940501%2C936308%2C939201%2C900816%2C912711%2C916304%2C900391%2C934507%2C912714%2C907231%2C936312%2C906001&gcr=it&itag=5&mt=1380962991&key=yt1&factor=1.25&upn=LNFb8TbaiGs&ip=62.98.22.234&algorithm=throttle-factor. It might not play.
... 2 more
2013-10-05 18:52:15,550 WARN [FeedUpdaterThread] Failed to retrieve online item information for http://r5---sn-fpoq-o52e.c.youtube.com/videoplayback?ipbits=8&ip=62.98.22.234&key=yt1&burst=40&algorithm=throttle-factor&fexp=935501%2C920603%2C932200%2C923500%2C916624%2C919514%2C936106%2C924606%2C924616%2C916914%2C929117%2C929121%2C929906%2C929907%2C929922%2C929923%2C929127%2C929129%2C929131%2C929930%2C936403%2C925724%2C925726%2C936310%2C925720%2C925722%2C925718%2C936401%2C925714%2C929917%2C906945%2C929933%2C929935%2C929937%2C929939%2C939602%2C939604%2C937102%2C906842%2C913428%2C920605%2C912715%2C919811%2C939908%2C935704%2C932309%2C913563%2C919373%2C930803%2C908538%2C904839%2C932211%2C931924%2C938608%2C940501%2C936308%2C939201%2C900816%2C912711%2C916304%2C900391%2C934507%2C912714%2C907231%2C936312%2C906001&source=youtube&cp=U0hXRlBMUl9IUUNON19IRlZDOkRPaTVVQjV2S0h2&id=46ce02494016dc80&ms=au&factor=1.25&upn=2zzhLjBOrJw&mt=1380991865&sparams=algorithm%2Cburst%2Ccp%2Cfactor%2Cgcr%2Cid%2Cip%2Cipbits%2Citag%2Csource%2Cupn%2Cexpire&mv=m&gcr=it&expire=1381014237&sver=3&itag=5. It might not play.
... 2 more
Configure Serviio with at least one url to an RSS feed. This is done using the serviio console using the Online Sources Tab which is found on the Library tab.
Users browsing this forum: No registered users and 69 guests
