Idiot guy to linux shares?
standarshy
Post Mon Aug 19, 2013 6:46 pm
Hello all,
I've been using serviio for a long time on windows and I'm trying to set it up on a headless linux server for work.
What I have so far:
I have followed the setup guide and serviio is properly installed. TV recognizes the server.
Unfortunately, I don't know where to go from here.
I have performed many searches to try to find a better guide on how to add files but have yet to find one.
I would greatly appreciate any help I could get. I know this should be easy :(
Post Mon Aug 19, 2013 8:21 pm
Re: Idiot guy to linux shares?
where are your files stored? what is the file path? are you running a web UI or remote console?
standarshy
Post Thu Aug 22, 2013 2:47 pm
Hey zip,
Thanks for your reply.
The files will be located on a mounted network share.
The computer will have access to the shared location, so that is not a problem.
I don't have the WebUI because I haven't paid for pro.
I am doing doing everything by ssh'ing into the computer with serviio and configuring it via the terminal.
Really what I was looking for is where in the configuration file I can add the share?
Post Thu Aug 22, 2013 3:16 pm
There is not terminal-based configuration, you will have to either run the console remotely (see faq) on a different machine, or install a webUI (this is not MediaBrowser and you don't need Pro for that), or use a mobile app like ServiiDroid.
standarshy
Post Thu Aug 22, 2013 3:36 pm
Maybe I am misunderstanding you somewhere or maybe I am being unclear.
I am a noob a linux so I could be using a few of the wrong terms.
Would you be able to link me to the specific faq for running the console remotely so I can read up on it?
I am looking into the WebUI now.
Again, I greatly appreciate your help.
standarshy
Post Thu Aug 22, 2013 4:32 pm
I take that back.
I found the spot in the faq. I tried looking at the link for more help but it "doesn't exist." viewtopic.php?f=5&t=142&start=10#p873
Post Thu Aug 22, 2013 4:35 pm
standarshy wrote:I take that back.
I don't think that extra help article is needed any more.
What operating system are you connecting to your server from (what does your PC run)?
Iveky
Post Thu Aug 22, 2013 5:41 pm
on linux you have to beware for file permissions.
before few days, I also moved all my PC's at home from windows to fedora linux, and had some trouble to get serviio working....
my main problem was not paying attention about 'read' permision on files....
standarshy
Post Thu Aug 22, 2013 6:02 pm
I can probably get some help changing permission if need be.
I am running Scientific Linux 6 on both machines. Scientific Linux is a RedHat clone, basically, it is identical to that and CentOS.
Post Thu Aug 22, 2013 6:17 pm
This is nothing to do with permissions at the moment, the OP needs help connecting the console to a headless server.
cefn
Post Sat Aug 24, 2013 1:29 pm
Im running remote ubuntu 12.04 headless with 1.3 and webui all working ok
i did it with putty
cd into you serviio user, dowload and extract serviio ... no extra file permissions needed
cd into www folder download webui and extract it ... again no extra file permissions needed
make sure you have the webserver working ... then go to webui addy server http://<ip>/webui/ (webui must go in www. folder)
and configer from there.
and media folders are owend by serviio user
(old ubuntu tut but should be ok with redhat http://ubuntuserverhelp.com/serviio-webui-guide/ )
standarshy
Post Tue Sep 24, 2013 7:49 pm
Y'all have been very helpful.
The webgui finally did it for me. I was hoping there was another way, maybe there is. It works for me this way though.
Now, I have a new problem. My script no longer works.
I will provide details to this in a new post.
Users browsing this forum: No registered users and 52 guests
