Re: SvtPlay
zip wrote:Is there still a problem with the accented characters in the URL?
Zip,
Do you refer to the oppetarkiv.se urls discussed just a few messages above this one, or do you mean some other, older issue?
Regards
/ O
peter1212 wrote:Script needs update.
Doesn't show any shows any more. Probably becuase of redesign at the source page.
ottomatic wrote:peter1212 wrote:Script needs update.
Thanks for the report. I'll look into it.
peter1212 wrote:ottomatic wrote:peter1212 wrote:Script needs update.
Great! Any progress so far?
ottomatic wrote:
I have confirmed the error but have not had the time to solve it. I hope to make progress over the weekend.
Any progress yet???
Hippas wrote:Hi,
I installed the Serviio package on my Windows 8 PC yesterday and it seems to work just fine when I access and play local movies on my new Panasonic TV (TX-P42ST60Y).
However, when I installed the SVT Play plugin (very interesting as the Panasonic web browser can not offer a full screen mode for SVT Play) I did not really succeed. I followed the instructions on the first post of this forum thread (I hope they are up to date) and added a few links for the online sources, for example http://www.svtplay.se/kategorier/nyhete ... ram&sida=1
When I then open up the online sources on my TV I can see "SVT Play nyheter" (which I named it) and so on, but when opening it is totally empty. And this is the case for all the similar SVT Play links that I created.
I don't know where to start the troubleshooting. Is this problem familiar to someone? Theories on possible causes and solutions?
Some help would be very much appreciated, thanks!
Kindly
Jörgen
Hippas wrote:Hi again,
I seem to have the same problem, i.e. only empty program categories on my TV, also after updating to the new version of the SVT Play plugin (and then restarting my computer).
Does it work for the rest of you?
Hippas wrote:Yes, I added them as web resources (or webbresurs as I use the Swedish GUI of Serviio)
I have added 3 sources, none of them yields any results:
http://www.svtplay.se/kategorier/dokume ... des&sida=1
http://www.svtplay.se/kategorier/kultur ... ram&sida=1
Thanks for trying to help me out!
/Jörgen
http://www.svtplay.se/kategorier/dokumentar?tab=episodes&sida=2
http://www.svtplay.se/kategorier/dokumentar?tab=senasteprogram&sida=2
ottomatic wrote:csholmq wrote:ottomatic wrote:
It turns out the sequence is %C3%A4.
So I mean like this: http://www.oppetarkiv.se/etikett/titel/Fem%20myror%20%C3%A4r%20fler%20%C3%A4n%20fyra%20elefanter/
/ O
That actually works. How did you come up with that?
It is the url in the link according to MSIE.
kjesch wrote:I appreciate your work as SVTPlay is important for me.
I have replaced the plugin and changed the URL:s (e.g. http://www.svtplay.se/kategorier/dokume ... ram&sida=2) and restarted but still no entries in the folders. Just empty folders.
Am I doing something wrong here?
