SvtPlay
ottomatic
Post Mon Jun 17, 2013 3:47 pm
Re: SvtPlay
zip wrote:Is there still a problem with the accented characters in the URL?
Zip,
Do you refer to the oppetarkiv.se urls discussed just a few messages above this one, or do you mean some other, older issue?
Regards
/ O
peter1212
Post Sat Aug 24, 2013 7:11 am
Re: SvtPlay
Script needs update.
Doesn't show any shows any more. Probably becuase of redesign at the source page.
ottomatic
Post Sat Aug 24, 2013 8:12 am
Re: SvtPlay
peter1212 wrote:Script needs update.
Thanks for the report. I'll look into it.
peter1212
Post Fri Aug 30, 2013 8:30 am
Re: SvtPlay
Great! Any progress so far?
ottomatic
Post Fri Aug 30, 2013 8:39 am
Re: SvtPlay
I have confirmed the error but have not had the time to solve it. I hope to make progress over the weekend.
n3mmr
Post Mon Sep 02, 2013 1:36 pm
Re: SvtPlay
Any progress yet???
ottomatic
Post Mon Sep 02, 2013 5:05 pm
Re: SvtPlay
n3mmr wrote:
Any progress yet???
No. Sorry. Too many children's partys and football games to attend.
Please be patient.
/ O
Hippas
Post Fri Sep 06, 2013 6:58 am
Re: SvtPlay
I installed the Serviio package on my Windows 8 PC yesterday and it seems to work just fine when I access and play local movies on my new Panasonic TV (TX-P42ST60Y).
However, when I installed the SVT Play plugin (very interesting as the Panasonic web browser can not offer a full screen mode for SVT Play) I did not really succeed. I followed the instructions on the first post of this forum thread (I hope they are up to date) and added a few links for the online sources, for example http://www.svtplay.se/kategorier/nyhete ... ram&sida=1
When I then open up the online sources on my TV I can see "SVT Play nyheter" (which I named it) and so on, but when opening it is totally empty. And this is the case for all the similar SVT Play links that I created.
I don't know where to start the troubleshooting. Is this problem familiar to someone? Theories on possible causes and solutions?
Some help would be very much appreciated, thanks!
Kindly
Jörgen
ottomatic
Post Fri Sep 06, 2013 7:04 am
Re: SvtPlay
Hippas wrote:Hi,
Kindly
Jörgen
Hi Jörgen,
The SvtPlay site has recently restructured their HTML markup, which means that the plaugin needs to be rewritten in order to work properly.
So in effect, the plugin is currently broken. Hopefully I will have time to fix it this weekend.
Regards
/ O
Hippas
Post Fri Sep 06, 2013 7:08 am
Re: SvtPlay
OK, thanks for the info and quick reply.
Good luck with the rewriting! :)
/J
ottomatic
Post Fri Sep 06, 2013 4:23 pm
Re: SvtPlay
Hi everyone,
It turned out that it was one simple attribute name which hade changed in the markup of the svtplay site.
I have fixed the SvtPlay plugin and uploaded the new version in the original forum post.
Have a good weekend folks!
/ O
Hippas
Post Fri Sep 06, 2013 5:00 pm
Re: SvtPlay
Hi again,
I seem to have the same problem, i.e. only empty program categories on my TV, also after updating to the new version of the SVT Play plugin (and then restarting my computer).
Does it work for the rest of you?
ottomatic
Post Fri Sep 06, 2013 7:48 pm
Re: SvtPlay
Hippas wrote:Hi again,
Did you add the feeds as "web resource"?
Please provide samples of failing feed url:s!
/ O
Hippas
Post Fri Sep 06, 2013 7:55 pm
Re: SvtPlay
Yes, I added them as web resources (or webbresurs as I use the Swedish GUI of Serviio)
I have added 3 sources, none of them yields any results:
http://www.svtplay.se/kategorier/dokume ... des&sida=1
http://www.svtplay.se/kategorier/kultur ... ram&sida=1
Thanks for trying to help me out!
/Jörgen
ottomatic
Post Sat Sep 07, 2013 8:24 am
Re: SvtPlay
Hippas wrote:Yes, I added them as web resources (or webbresurs as I use the Swedish GUI of Serviio)
/Jörgen
Thanks for reporting. It turns out that the markup for the category pages had changed too, but in a slightly different way.
I have uploaded a fix for this as well.
Regards
/ O
ottomatic
Post Sat Sep 07, 2013 8:27 am
Re: SvtPlay
Hi folks,
New version uploaded.
Kindly note that you may need to change the url:s for some of your feed definitions. If you previously had Documentaries added with this url:
http://www.svtplay.se/kategorier/dokumentar?tab=episodes&sida=2
It needs to be entered like this instead:
http://www.svtplay.se/kategorier/dokumentar?tab=senasteprogram&sida=2
Regards!
/ O
Hippas
Post Sat Sep 07, 2013 12:03 pm
Re: SvtPlay
Ok, thanks!
I am in Vienna right now, but will try it ASAP when I get back home (late Thursday night)
/J
csholmq
Post Sat Sep 07, 2013 4:51 pm
Re: SvtPlay
ottomatic wrote:
csholmq wrote:
ottomatic wrote:
It turns out the sequence is %C3%A4.
So I mean like this: http://www.oppetarkiv.se/etikett/titel/Fem%20myror%20%C3%A4r%20fler%20%C3%A4n%20fyra%20elefanter/
/ O
That actually works. How did you come up with that?
It is the url in the link according to MSIE.
Yes. But when I copy the URL from Safari I need to convert those letters manually. Any tips to speed that up?
kjesch
Post Sun Sep 08, 2013 3:14 pm
Re: SvtPlay
I appreciate your work as SVTPlay is important for me.
I have replaced the plugin and changed the URL:s (e.g. http://www.svtplay.se/kategorier/dokume ... ram&sida=2) and restarted but still no entries in the folders. Just empty folders.
Am I doing something wrong here?
ottomatic
Post Sun Sep 08, 2013 7:23 pm
Re: SvtPlay
kjesch wrote:I appreciate your work as SVTPlay is important for me.
Hard to know. Did it ever work on your setup?
Please enable debug logging and post your logs here.
Return to Available plugins
Users browsing this forum: No registered users and 107 guests
