Samsung TV 65 series C and Mkv Files
Dariune
Post Mon Jan 24, 2011 11:58 am
I tried serviio 0.5 version, everything works fine, but does not play MKV files through my Samsung TV ue32c6530, things could be the problem?
Post Mon Jan 24, 2011 12:04 pm
Re: Samsung TV 65 series C and Mkv Files
Can you post detailed log of when you try to play the file?
Dariune
Post Mon Jan 24, 2011 12:47 pm
zip wrote:Can you post detailed log of when you try to play the file?
I attach a movie, then refer on TV video, folders, and play film, but tv wrote the file format is not supported.
Post Mon Jan 24, 2011 12:50 pm
Dariune
Post Mon Jan 24, 2011 1:55 pm
zip wrote:I mean this: viewtopic.php?f=5&t=7
I tried the DEBUG command, the result is the same, what else could be the problem?
Post Mon Jan 24, 2011 4:10 pm
I need you to post serviio.log that is written as a result of the change you did... don't post the whole file, only the bit around the time you attempt to play the file
Post Mon Jan 24, 2011 5:47 pm
your doing better than me on this one i cant even get teh MKV fiel to appear on the tv at all let alone be able to play them :(
sukerman
Post Mon Jan 24, 2011 6:05 pm
Hi,in my samsung bluray bd-c5500 i cant play mkv files too.
sukerman
Post Mon Jan 24, 2011 8:02 pm
Now i can see mkv files already,ive changed the profile and its working fine,the only problem is that some movies are out of synch.
Dariune
Post Mon Jan 24, 2011 8:21 pm
[quote="sukerman"]Now i can see mkv files already,ive changed the profile and its working fine,the only problem is that some movies are out of synch.[/quote
what to changes in profile?
tkos
Post Mon Jan 24, 2011 11:03 pm
I am having to go back to 0.4.2 to play MKV files as well. At least I am about to try that.
Post Tue Jan 25, 2011 12:38 am
There should be no change in the Samsung C profiles in these two versions, or at least not anything MKV relevant. Can you play them using the Generic profile?
nwcollins
Post Tue Jan 25, 2011 4:25 am
I was having this exact problem with my Samsung C6400 Plasma. I could not play any mkv files. Then I noticed that on the "status" tab of the console that the profile was on the default "Generic DLNA" profile. Once I switched it back to the Samsung C Series everything is playing again.
I've been using this program for a bit now and I gotta say its great. This latest build--now that I have the mkv issue sorted--is even better. Most notable the "presentation" options. It cuts the amount of file screens down to 2-3 instead of like 1000. :D
Nathan
Dariune
Post Tue Jan 25, 2011 7:36 am
nwcollins wrote:I was having this exact problem with my Samsung C6400 Plasma. I could not play any mkv files. Then I noticed that on the "status" tab of the console that the profile was on the default "Generic DLNA" profile. Once I switched it back to the Samsung C Series everything is playing again.
Nathan
I switcded on "status" back to Samsung tv and it works!
Thank you all :D
tkos
Post Tue Jan 25, 2011 10:45 am
Not me sadly. I tried both generic and Samsung series C as profiles. The only MKV file I couldn't play for either 0.5 or 0.4.2 was one with AAC sound. All others work great under 0.4.2 and are listed as non supported under 0.5. With 0.4.2 all MKV's work under generic as well. My Samsung BluRay player is listed as supporting them natively, so I don't understand why there would be an issue.
sukerman
Post Tue Jan 25, 2011 9:03 pm
hi,i had the profile as generic and ive changed to samsung tv/player c series and all works good now except some movies that are not synch with audio.
Post Tue Jan 25, 2011 9:08 pm
Can you guys confirm that if you remove all your renderers from the table (in the console, don't forget to save) and restart Serviio, it'll find your Samsung and give it the right profile straight away? If not, a detailed log of when the server starts would be cool.
tkos
Post Wed Jan 26, 2011 6:14 pm
Right now I have downgraded to 0.4.2 and it works great. Maybe this weekend I can try and upgrade to 0.5 again and see what is up. I did know that my player (the BD C6500 bluray player) only shows as unknown device. It did that always in 0.5. It does that in 0.4.2 as well, though files seem to play anway, whether or not I use generic or the c profile.
R0ckw3ll
Post Mon Jan 31, 2011 2:42 am
Dariune wrote:Hi,
I also have noticed this issue of this version. Even though I really wanted to play .mkv files but I am going to switch it to the new version. I am looking forward to see this fixed.
L2u
Post Mon Jan 31, 2011 5:59 am
Serviio is awesome.. blame Samsung and their ----- media player software... with a little work on the profiles I got .4.2 working and .5 was even easier (see below).
Found same problem - multiple MKV (audio/etc) wouldn't play n new version, played fine on .4.2
I didn't go back in and reset the renderer profile (the dropdown needs an arrow so people know it is there, I found it by accident by clicking where is said unknown profile.. hint hint programmers!).
Once I changed it to SONY BD Player (US) I had all of my MKVs back instantly!
Also, I used the following in my profiles.xml in .4.2 and it helped run all the MKVs (I have a Samsung TV and BD Player running out of a Windows 7 Pro-64-bit Serviio).
Hope this helps someone.
-Dave (L2u)
<Profile id="11" name="Samsung WiselinkPro - Blu-ray Player" extendsProfileId="2">
<!-- transcode H264 MP4 files with LPCM audio -->
<Matches container="mp4" vCodec="h264" aCodec="pcm_s16le" />
<!-- transcode MKV with MPEG2 video, remux into mpeg2ts -->
<Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video">
<Matches container="matroska" vCodec="mpeg2video"/>
<!-- transcode AVI with AVC video -->
Users browsing this forum: No registered users and 100 guests
