Samsung TV 65 series C and Mkv Files
I tried serviio 0.5 version, everything works fine, but does not play MKV files through my Samsung TV ue32c6530, things could be the problem?
zip wrote:Can you post detailed log of when you try to play the file?
zip wrote:I mean this: viewtopic.php?f=5&t=7
nwcollins wrote:I was having this exact problem with my Samsung C6400 Plasma. I could not play any mkv files. Then I noticed that on the "status" tab of the console that the profile was on the default "Generic DLNA" profile. Once I switched it back to the Samsung C Series everything is playing again.
I've been using this program for a bit now and I gotta say its great. This latest build--now that I have the mkv issue sorted--is even better. Most notable the "presentation" options. It cuts the amount of file screens down to 2-3 instead of like 1000.
Nathan
Dariune wrote:Hi,
Users browsing this forum: No registered users and 107 guests
