Waiting for Serviio 1.3 for Synology NAS
patters
Post Wed Sep 11, 2013 1:35 pm
Re: Waiting for Serviio 1.3 for Synology NAS
Sorry, I'm having some difficulty getting the new FFmpeg compiled. They've changed something which has broken libass stuff. In the exact same toolchain and library environment on my dev machine FFmpeg 1.1.1 compiles fine, but grab the latest FFmpeg from Git, or even the 2.0 release bundle and they won't build with libass properly. Thing is that I need the newer versions to get libshine properly built in (unlike the semi-bodged patch I had been relying on before). I'm picking away at the problem when I can, but I don't have much free time at the moment.
Ryster
Post Wed Sep 11, 2013 6:50 pm
No worries Patters, RL takes precedence as always :)
I'm sure you'll have it fixed soon enough.
Serviio Pro Purchaser - 24/07/2012
timbolina
Post Thu Sep 12, 2013 12:43 am
patters wrote:Sorry, I'm having some difficulty getting the new FFmpeg compiled. They've changed something which has broken libass stuff. In the exact same toolchain and library environment on my dev machine FFmpeg 1.1.1 compiles fine, but grab the latest from Git, or even release 2.0 and they won't build with libass properly. Thing is that I need the newer versions to get libshine built in. I'm picking away at the problem when I can, but I don't have much free time at the moment.
Just signed up to express my gratitude for the work you doing here for the two communities. Thanks!
chrisy1972
Post Sun Sep 22, 2013 11:33 am
Have you guys found that you can't look up tmdb.org movie data any longer with 1.2.1? I've raised a topic here http://forum.serviio.org/viewtopic.php?f=5&t=13291 where I wonder if the recent dropping of tmdb.org API v2.1 is behind my problem.
If that's the case then I certainly add my +1 for Serviio 1.3.1. I really enjoy using Serviio with my WDTV, but my current metadata hiccups are pretty annoying.
Ryster
Post Thu Sep 26, 2013 5:40 pm
Just spotted this next to the Synology Package on the Serviio download page...
This package is behind the latest release and mostly unsupported.
Is that a gentle prod from Zip? :)
timbolina
Post Fri Sep 27, 2013 1:12 am
Ryster wrote:Just spotted this next to the Synology Package on the Serviio download page...
Haha, we're all waiting in breathless anticipation :)
Morbeas
Post Mon Sep 30, 2013 2:29 pm
Patiently waiting on 1.3.1 for my 1511+. :(
globus243
Post Tue Oct 01, 2013 7:58 pm
patters wrote:Staff? Serviio is written by only one guy (Zip). Not surprising he can't target NAS platforms...
I have the ARMv5 version done but I still need to find time to compile FFmpeg for QorIQ, Intel and ARMv7 CPUs. Synology don't make this easy. Since I can see from my download stats that most users are ARMv5 I may just go ahead and release that build today.
If you finished the ARMv5 version, could you publish this? so we with smaller NAS can use it?
Post Mon Oct 07, 2013 6:04 pm
I've added it there until Patters releases the new version. People were repeatedly asking the same questions regarding this package.
scartsjer
Post Mon Oct 07, 2013 6:35 pm
With the new update of thesynology dsm. serviio 1.2.1 isn't able to start anymore ... any idea how to fix that?
keep up the good job! hope to get serviio up and running on my DS213J
adski
Post Thu Oct 10, 2013 4:32 am
Serviio 1.4 is on the way also... hope we can get 1.3 for Syno NAS soon :(
blase
Post Thu Oct 10, 2013 9:00 am
scartsjer wrote:With the new update of thesynology dsm. serviio 1.2.1 isn't able to start anymore ... any idea how to fix that?
viewtopic.php?f=14&t=3311&start=100#p79541
Saludos
patters
Post Mon Oct 14, 2013 12:11 am
Hi all - the big delay has been caused by the fact that something has changed in FFmpeg's build scripts for libs that link to other libs when cross compiling and my methods no longer worked (for libass in particular). It has been an absolute mission to get working, but I think I have it done now. I've had repeated starts and stops on this over several months, and unfortunately I really haven't had much available time. As before I have compiled with shared libraries, using libraries native to Synology DSM where possible, but having the linking done with a relative path so the system's libs are not interfered with.
Anyway, can someone with a DS213j please extract this archive to a folder and check that ffmpeg launches from the command line? I'm cross-compiling blind for an architecture I don't own (armada370), so I can't test at all. Can you post the screen output please? You need to launch it from inside the extracted folder using a dot slash like this:
/volume1/@tmp$ ./ffmpeg
ffmpeg version 2.0-67d7ea9-compiled_by_patters_for_Serviio Copyright (c) 2000-2013 the FFmpeg developers
  built on Sep  1 2013 20:12:00 with gcc 4.2.3 (GCC)
  configuration: --arch=arm --cpu=armv5te --prefix=/opt --extra-cflags=-I/tmp/include --enable-shared --disable-static --enable-pic --disable-ffplay --disable-ffserver --disable-vfp --disable-neon --disable-debug --enable-pthreads --enable-libshine --enable-librtmp --enable-libass --enable-libx264 --enable-gpl --extra-version=compiled_by_patters_for_Serviio
  libavutil      52. 43.100 / 52. 43.100
  libavcodec     55. 30.100 / 55. 30.100
  libavformat    55. 15.100 / 55. 15.100
  libavdevice    55.  3.100 / 55.  3.100
  libavfilter     3. 82.102 /  3. 82.102
  libswscale      2.  5.100 /  2.  5.100
  libswresample   0. 17.103 /  0. 17.103
Use -h to get full help or, even better, run 'man ffmpeg'
/volume1/@tmp$ ldd ./ffmpeg
   libavdevice.so.55 => /volume1/@appstore/Serviio/bin/../lib/libavdevice.so.55 (0x40026000)
   libavfilter.so.3 => /volume1/@appstore/Serviio/bin/../lib/libavfilter.so.3 (0x40039000)
   libavformat.so.55 => /volume1/@appstore/Serviio/bin/../lib/libavformat.so.55 (0x40106000)
   libavcodec.so.55 => /volume1/@appstore/Serviio/bin/../lib/libavcodec.so.55 (0x40262000)
   libpostproc.so.52 => /volume1/@appstore/Serviio/bin/../lib/libpostproc.so.52 (0x41058000)
   libswresample.so.0 => /volume1/@appstore/Serviio/bin/../lib/libswresample.so.0 (0x4106a000)
   libswscale.so.2 => /volume1/@appstore/Serviio/bin/../lib/libswscale.so.2 (0x41087000)
   libavutil.so.52 => /volume1/@appstore/Serviio/bin/../lib/libavutil.so.52 (0x410df000)
   libx264.so.133 => /volume1/@appstore/Serviio/bin/../lib/libx264.so.133 (0x41132000)
   libm.so.6 => /lib/libm.so.6 (0x41284000)
   libpthread.so.0 => /lib/libpthread.so.0 (0x41333000)
   libc.so.6 => /lib/libc.so.6 (0x41353000)
   librt.so.1 => /lib/librt.so.1 (0x41482000)
   libass.so.4 => /volume1/@appstore/Serviio/bin/../lib/libass.so.4 (0x41491000)
   librtmp.so.0 => /volume1/@appstore/Serviio/bin/../lib/librtmp.so.0 (0x414c3000)
   libz.so.1 => /lib/libz.so.1 (0x414e3000)
   libshine.so.3 => /volume1/@appstore/Serviio/bin/../lib/libshine.so.3 (0x41500000)
   /lib/ld-linux.so.3 (0x40000000)
   libfreetype.so.6 => /lib/libfreetype.so.6 (0x41512000)
   libfribidi.so.0 => /volume1/@appstore/Serviio/bin/../lib/libfribidi.so.0 (0x415d1000)
   libfontconfig.so.1 => /volume1/@appstore/Serviio/bin/../lib/libfontconfig.so.1 (0x415f0000)
   libssl.so.1.0.0 => /lib/libssl.so.1.0.0 (0x41627000)
   libcrypto.so.1.0.0 => /lib/libcrypto.so.1.0.0 (0x41675000)
   libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x41809000)
   libexpat.so.1 => /lib/libexpat.so.1 (0x4181d000)
   libdl.so.2 => /lib/libdl.so.2 (0x41844000)
/volume1/@tmp$
Can you also run "ldd ./ffmpeg" as above and post that output back here too.
Once I know this works, I can build the Intel and QorIQ binaries. Thanks!
timbolina
Post Mon Oct 14, 2013 7:32 am
patters wrote:Hi all - the big delay has been caused by the fact that something has changed in FFmpeg's build scripts for libs that link to other libs when cross compiling and my methods no longer worked (for libass in particular). It has been an absolute mission to get working, but I think I have it done now. I've had repeated starts and stops on this over several months, and unfortunately I really haven't had much available time. As before I have compiled with shared libraries, using libraries native to Synology DSM where possible, but having the linking done with a relative path so the system's libs are not interfered with.
Appreciate the effort patters. I have a DS1511+ if that helps?
Koramchad
Post Mon Oct 14, 2013 7:34 am
Ok, so here is what I see on my DS213j.
For ./ffmpeg:
DiskStation> ./ffmpeg
ffmpeg version 2.0-fa7e9f9-compiled_by_patters_for_Serviio Copyright (c) 2000-2013 the FFmpeg developers
  built on Oct 14 2013 00:38:28 with gcc 4.6.4 (Linaro GCC branch-4.6.4. Marvell GCC 201303-1655.6f19debc) 20120731 (prerelease)
  configuration: --arch=arm --enable-cross-compile --cross-prefix=/usr/local/arm-marvell-linux-gnueabi/bin/arm-marvell-linux-gnueabi- --target-os=linux --prefix=/usr/local/arm-marvell-linux-gnueabi --extra-cflags=-I/usr/local/arm-marvell-linux-gnueabi/include --enable-shared --disable-static --enable-pic --disable-ffplay --disable-ffserver --disable-neon --enable-thumb --disable-debug --enable-pthreads --enable-libmp3lame --enable-libshine --enable-librtmp --enable-libass --enable-libx264 --enable-gpl --pkg-config=pkg-config --extra-version=compiled_by_patters_for_Serviio
  libavutil      52. 46.101 / 52. 46.101
  libavcodec     55. 35.100 / 55. 35.100
  libavformat    55. 19.100 / 55. 19.100
  libavdevice    55.  4.100 / 55.  4.100
  libavfilter     3. 88.101 /  3. 88.101
  libswscale      2.  5.101 /  2.  5.101
For ldd ./ffmpeg I get the following error:
DiskStation> ldd ./ffmpeg
-sh: ldd: not found
Let me know if I can do anything else...
AND THANKS!
patters
Post Mon Oct 14, 2013 7:48 am
Awesome. Can you re-install my Java package? Then you'll have the ldd command. It gets trashed if you update DSM.
Koramchad
Post Mon Oct 14, 2013 7:54 am
I just uninstalled your Java7 and reinstalled it. Got the same error...
I'm gonna try restarting the NAS.
Any other ideas to make it work?
Koramchad
Post Mon Oct 14, 2013 8:09 am
Nothing, ldd still not working...
patters
Post Mon Oct 14, 2013 8:29 am
Hmm. Maybe I didn't put it in the armv7 version because the tool may have been missing in the toolchain.
I remember that it was certainly missing from the Intel one. Ah well, ffmpeg seems to work - it wouldn't run at all if the library dependencies weren't satisfied. I'll get the other builds compiled and build a package...
Koramchad
Post Mon Oct 14, 2013 8:31 am
Awesome!
Let me know if you need any more testing!
