Problem with VOB files
akc
Post Mon Sep 23, 2013 5:38 pm
I just installed Serviio last night and I like it alot. I would like to upgrade to the pro version but I am having a serious problem with part of my collection I want to stream.
It seems that about 30 percent of my .vob files are not recognized by Serviio, to test to see if something was wrong with the files themselves I moved them to a Buffallo Tech NAS drive I have that has a built in DLNA server. On that drive. They all are seen and indexed properly. Serviio does not see them at all.
It would appear that all the vob files that are missing are from DVDs that have multiple titles therefore multiple vobs on the dvd. They were all ripped using DvDfab. As I already stated an other dlna server sees them all so I really dont think anything is wrong with them.
Since I just installed Serviio I am assuming I did something wrong. Could someone advise me on this. I would like to keep them in VOB format and not convert them to mp4.
Thanks in advance.
Al
Post Mon Sep 23, 2013 5:52 pm
Re: Problem with VOB files
Could you provide details of this vob file ? see my signature link.
akc
Post Mon Sep 23, 2013 6:30 pm
Here is the information you requested. But as I already stated, it does not show up as a media file, so I cannot even attempt to play it.
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Program Files\Serviio\lib>ffmpeg.exe -i "b:\videos\anime\nuku nuku dash\nuku_nuku_dash_vol_1.title2.vob"
[mpeg @ 019AE540] max_analyze_duration 5000000 reached at 5005000 microseconds
Input #0, mpeg, from 'b:\videos\anime\nuku nuku dash\nuku_nuku_dash_vol_1.title2.vob':
Duration: 00:23:27.39, start: 0.233567, bitrate: 7333 kb/s
Stream #0:0[0x1bf]: Data: dvd_nav_packet
Stream #0:1[0x1e0]: Video: mpeg2video (Main), yuv420p, 720x480 [SAR 8:9 DAR4:3], 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc
Stream #0:2[0x80]: Audio: ac3, 48000 Hz, stereo, fltp, 224 kb/s
Post Fri Sep 27, 2013 8:04 pm
The files you provided are added for me. Did you check the last Added category or Folders category? They might not appear under Movies if the metadata is not found for them.
akc
Post Sat Sep 28, 2013 11:33 pm
I searched for them though "Folder" and the folder was empty.
Should they not always show up under "Folder" ?
akc
Post Sat Sep 28, 2013 11:34 pm
zip wrote:The files you provided are added for me. Did you check the last Added category or Folders category? They might not appear under Movies if the metadata is not found for them.
I could not find them under folders How did you find them?
Post Wed Oct 02, 2013 7:50 pm
Can you see them in MediaBrowser or AV Media Controller (Intel tools)?
akc
Post Sat Oct 05, 2013 1:02 am
No I cannot see them with the media browser.
It is as if they do not exist.
I tried installing a different server and it sees them fine. It is only Serviio that does not.
Machine is running windows 7 64 bit Ultimate Edition ( if this matters )
Al
Post Mon Oct 07, 2013 6:10 pm
Do they have the same access rights as the files you can see? (incl. their parent folders).
