Live stream problem with Serviio on WD TV Play
arphid
Post Sat Oct 12, 2013 12:37 am
I'm having issues playing streams on the WD TV Play. I just bought a new one from Amazon (http://www.amazon.com/WD-TV-Play-Media- ... B008YDUTRO). Files work normally, but live streams won't play. It brings up a blue cursor, loads the video player (like the one with the play/pause button) but the video itself is black and never starts. In the logs, I found warnings like this when I tried to play streams:
2013-10-11 19:18:07,224 WARN  [GETMethodProcessor] A range header was found on the incoming request for a live stream, sending back the whole stream
Any help would be appreciated. Thanks.
Post Sat Oct 12, 2013 12:50 am
Re: Live stream problem with Serviio on WD TV Play
Did you even try to search? there is the same article 3 lines below yours.
arphid
Post Sat Oct 12, 2013 4:09 am
Yeah, I don't think it's the same issue. I tried deleting that line from that thread and streams still did not work. Also there's no mention of the warning from my logs in that thread.
Post Sat Oct 12, 2013 10:46 am
It is the same problem. Make sure to restart the PC after the change.
arphid
Post Sat Oct 12, 2013 11:58 am
I did restart the PC to no avail, but I do have some new information. I let the WD TV Play sit for awhile and after about 8-15 minutes it has about a 2/3 chance to start playing the stream smoothly, and the other 1/3rd it comes up with a frozen picture. The stream is lagged by the amount of time it took to start, like it's buffered for 10 mins or so. It's not a connection issue either, I tried over wifi and directly connected to the ethernet. When the stream starts playing, there's some new information in the logs:
2013-10-12 03:30:05,223 WARN  [GETMethodProcessor] A range header was found on the incoming request for a live stream, sending back the whole stream
2013-10-12 03:30:05,224 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000020001270 (online)
2013-10-12 03:30:05,224 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2013-10-12 03:30:05,224 DEBUG [VideoDeliveryEngine] Delivering item '1000000020001270' for client 'Identifier=192.168.1.5, Profile=WDTV Live'
2013-10-12 03:30:05,224 DEBUG [VideoDeliveryEngine] Delivering file 'mms://stream1.france24.yacast.net/f24_liveen' using transcoding
2013-10-12 03:30:05,224 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.1.5, Profile=WDTV Live'
2013-10-12 03:30:05,224 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: mmsh://stream1.france24.yacast.net/f24_liveen
2013-10-12 03:30:05,225 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -analyzeduration 10000000 -threads auto -i mmsh://stream1.france24.yacast.net/f24_liveen -y -threads auto -c:v mpeg2video -qscale:v 1 -r 25 -g 15 -c:a ac3 -b:a 384k -ac 1 -map 0:0 -map 0:1 -sn -f vob pipe:
2013-10-12 03:30:11,907 DEBUG [ServiioHttpService] Incoming request from /192.168.1.5:46103: GET /resource/1000000020001270/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.1, headers = [User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks,Host: 192.168.1.3:8895,Accept: */*,Range: bytes=0-1023]]
2013-10-12 03:30:11,907 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-10-12 03:30:11,908 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-10-12 03:30:11,908 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.5, Profile=WDTV Live'
2013-10-12 03:30:11,908 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000020001270 and type 'MEDIA_ITEM' received
2013-10-12 03:30:11,908 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000020001270 (online)
2013-10-12 03:30:11,908 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2013-10-12 03:30:11,909 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000020001270, format MPEG_PS_PAL and profile WDTV Live
2013-10-12 03:30:11,909 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file mms://stream1.france24.yacast.net/f24_liveen
2013-10-12 03:30:11,909 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mms://stream1.france24.yacast.net/f24_liveen: MPEG_PS_PAL
2013-10-12 03:30:11,909 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mms://stream1.france24.yacast.net/f24_liveen: MPEG_PS_NTSC
2013-10-12 03:30:11,909 WARN  [GETMethodProcessor] A range header was found on the incoming request for a live stream, sending back the whole stream
2013-10-12 03:30:11,909 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000020001270 (online)
2013-10-12 03:30:11,909 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2013-10-12 03:30:11,910 DEBUG [VideoDeliveryEngine] Delivering item '1000000020001270' for client 'Identifier=192.168.1.5, Profile=WDTV Live'
2013-10-12 03:30:11,910 DEBUG [VideoDeliveryEngine] Delivering file 'mms://stream1.france24.yacast.net/f24_liveen' using transcoding
2013-10-12 03:30:15,864 DEBUG [SearchManager] Committing search index
2013-10-12 03:30:18,599 DEBUG [ServiioHttpService] Incoming request from /192.168.1.5:46104: GET /resource/1000000020001270/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.1, headers = [User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks,Host: 192.168.1.3:8895,Accept: */*,Range: bytes=0-1023]]
2013-10-12 03:30:18,599 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-10-12 03:30:18,600 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.5, Profile=WDTV Live'
2013-10-12 03:30:18,600 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000020001270 and type 'MEDIA_ITEM' received
2013-10-12 03:30:18,600 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000020001270 (online)
2013-10-12 03:30:18,600 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2013-10-12 03:30:18,600 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000020001270, format MPEG_PS_PAL and profile WDTV Live
2013-10-12 03:30:18,601 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file mms://stream1.france24.yacast.net/f24_liveen
2013-10-12 03:30:18,601 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mms://stream1.france24.yacast.net/f24_liveen: MPEG_PS_PAL
2013-10-12 03:30:18,601 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mms://stream1.france24.yacast.net/f24_liveen: MPEG_PS_NTSC
2013-10-12 03:30:18,601 WARN  [GETMethodProcessor] A range header was found on the incoming request for a live stream, sending back the whole stream
2013-10-12 03:30:18,601 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000020001270 (online)
2013-10-12 03:30:18,601 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2013-10-12 03:30:18,601 DEBUG [VideoDeliveryEngine] Delivering item '1000000020001270' for client 'Identifier=192.168.1.5, Profile=WDTV Live'
2013-10-12 03:30:18,601 DEBUG [VideoDeliveryEngine] Delivering file 'mms://stream1.france24.yacast.net/f24_liveen' using transcoding
2013-10-12 03:30:25,225 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.5, Profile=WDTV Live'
2013-10-12 03:30:25,225 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mms://stream1.france24.yacast.net/f24_liveen: MPEG_PS_PAL
2013-10-12 03:30:25,225 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mms://stream1.france24.yacast.net/f24_liveen: MPEG_PS_NTSC
2013-10-12 03:30:25,225 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-10-12 03:30:25,225 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-10-12 03:30:25,225 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Date: Sat, 12 Oct 2013 07:30:25 GMT,Server: Windows 8, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-12 03:30:25,235 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-10-12 03:30:25,235 DEBUG [TimeoutStreamDelegator] Scheduling stream stop to happen in 20 seconds if there is no traffic
2013-10-12 03:30:25,236 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-10-12 03:30:25,236 DEBUG [TimeoutStreamDelegator] Scheduling stream stop to happen in 20 seconds if there is no traffic
2013-10-12 03:30:25,375 DEBUG [ServiioHttpService] Incoming request from /192.168.1.5:46105: GET /resource/1000000020001270/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.1, headers = [User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks,Host: 192.168.1.3:8895,Accept: */*,Range: bytes=0-1023]]
2013-10-12 03:30:25,375 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-10-12 03:30:25,376 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-10-12 03:30:25,376 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.5, Profile=WDTV Live'
2013-10-12 03:30:25,376 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000020001270 and type 'MEDIA_ITEM' received
2013-10-12 03:30:25,376 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000020001270 (online)
2013-10-12 03:30:25,376 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2013-10-12 03:30:25,377 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000020001270, format MPEG_PS_PAL and profile WDTV Live
2013-10-12 03:30:25,377 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file mms://stream1.france24.yacast.net/f24_liveen
2013-10-12 03:30:25,377 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mms://stream1.france24.yacast.net/f24_liveen: MPEG_PS_PAL
2013-10-12 03:30:25,377 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mms://stream1.france24.yacast.net/f24_liveen: MPEG_PS_NTSC
2013-10-12 03:30:25,377 WARN  [GETMethodProcessor] A range header was found on the incoming request for a live stream, sending back the whole stream
2013-10-12 03:30:25,377 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000020001270 (online)
2013-10-12 03:30:25,377 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2013-10-12 03:30:25,378 DEBUG [VideoDeliveryEngine] Delivering item '1000000020001270' for client 'Identifier=192.168.1.5, Profile=WDTV Live'
2013-10-12 03:30:25,378 DEBUG [VideoDeliveryEngine] Delivering file 'mms://stream1.france24.yacast.net/f24_liveen' using transcoding
2013-10-12 03:30:25,378 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.5, Profile=WDTV Live'
2013-10-12 03:30:26,378 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mms://stream1.france24.yacast.net/f24_liveen: MPEG_PS_PAL
2013-10-12 03:30:26,378 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mms://stream1.france24.yacast.net/f24_liveen: MPEG_PS_NTSC
2013-10-12 03:30:26,378 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-10-12 03:30:26,378 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-10-12 03:30:26,378 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Date: Sat, 12 Oct 2013 07:30:26 GMT,Server: Windows 8, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-12 03:30:26,542 DEBUG [ServiioHttpService] Incoming request from /192.168.1.5:46106: HEAD /resource/1000000020001270/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.1.3:8895,Accept: */*]]
2013-10-12 03:30:26,542 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-10-12 03:30:26,542 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.5, Profile=WDTV Live'
2013-10-12 03:30:26,542 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000020001270 and type 'MEDIA_ITEM' received
2013-10-12 03:30:26,542 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000020001270 (online)
2013-10-12 03:30:26,542 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2013-10-12 03:30:26,543 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000020001270, format MPEG_PS_PAL and profile WDTV Live
2013-10-12 03:30:26,543 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file mms://stream1.france24.yacast.net/f24_liveen
2013-10-12 03:30:26,543 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mms://stream1.france24.yacast.net/f24_liveen: MPEG_PS_PAL
2013-10-12 03:30:26,543 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mms://stream1.france24.yacast.net/f24_liveen: MPEG_PS_NTSC
2013-10-12 03:30:26,543 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Date: Sat, 12 Oct 2013 07:30:26 GMT,Server: Windows 8, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-12 03:30:26,546 DEBUG [ServiioHttpService] Incoming request from /192.168.1.5:46106: GET /resource/1000000020001270/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.1.3:8895,Accept: */*,Range: bytes=0-]]
2013-10-12 03:30:26,546 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-10-12 03:30:26,547 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-10-12 03:30:26,547 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.5, Profile=WDTV Live'
2013-10-12 03:30:26,547 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000020001270 and type 'MEDIA_ITEM' received
2013-10-12 03:30:26,547 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000020001270 (online)
2013-10-12 03:30:26,547 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2013-10-12 03:30:26,547 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000020001270, format MPEG_PS_PAL and profile WDTV Live
2013-10-12 03:30:26,548 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file mms://stream1.france24.yacast.net/f24_liveen
2013-10-12 03:30:26,548 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mms://stream1.france24.yacast.net/f24_liveen: MPEG_PS_PAL
2013-10-12 03:30:26,548 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mms://stream1.france24.yacast.net/f24_liveen: MPEG_PS_NTSC
2013-10-12 03:30:26,548 WARN  [GETMethodProcessor] A range header was found on the incoming request for a live stream, sending back the whole stream
2013-10-12 03:30:26,548 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000020001270 (online)
2013-10-12 03:30:26,548 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2013-10-12 03:30:26,548 DEBUG [VideoDeliveryEngine] Delivering item '1000000020001270' for client 'Identifier=192.168.1.5, Profile=WDTV Live'
2013-10-12 03:30:26,548 DEBUG [VideoDeliveryEngine] Delivering file 'mms://stream1.france24.yacast.net/f24_liveen' using transcoding
2013-10-12 03:30:26,548 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.5, Profile=WDTV Live'
2013-10-12 03:30:26,584 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-10-12 03:30:26,584 DEBUG [TimeoutStreamDelegator] Scheduling stream stop to happen in 20 seconds if there is no traffic
2013-10-12 03:30:27,548 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mms://stream1.france24.yacast.net/f24_liveen: MPEG_PS_PAL
2013-10-12 03:30:27,548 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mms://stream1.france24.yacast.net/f24_liveen: MPEG_PS_NTSC
2013-10-12 03:30:27,548 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-10-12 03:30:27,548 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-10-12 03:30:27,548 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Date: Sat, 12 Oct 2013 07:30:27 GMT,Server: Windows 8, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-12 03:30:27,559 DEBUG [ServiioHttpService] Incoming request from /192.168.1.5:46107: GET /resource/1000000020001270/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.1.3:8895,Accept: */*,Range: bytes=0-]]
2013-10-12 03:30:27,560 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-10-12 03:30:27,561 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.5, Profile=WDTV Live'
2013-10-12 03:30:27,561 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000020001270 and type 'MEDIA_ITEM' received
2013-10-12 03:30:27,561 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000020001270 (online)
2013-10-12 03:30:27,561 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2013-10-12 03:30:27,561 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000020001270, format MPEG_PS_PAL and profile WDTV Live
2013-10-12 03:30:27,562 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file mms://stream1.france24.yacast.net/f24_liveen
2013-10-12 03:30:27,562 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mms://stream1.france24.yacast.net/f24_liveen: MPEG_PS_PAL
2013-10-12 03:30:27,562 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mms://stream1.france24.yacast.net/f24_liveen: MPEG_PS_NTSC
2013-10-12 03:30:27,562 WARN  [GETMethodProcessor] A range header was found on the incoming request for a live stream, sending back the whole stream
2013-10-12 03:30:27,562 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000020001270 (online)
2013-10-12 03:30:27,562 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2013-10-12 03:30:27,562 DEBUG [VideoDeliveryEngine] Delivering item '1000000020001270' for client 'Identifier=192.168.1.5, Profile=WDTV Live'
2013-10-12 03:30:27,563 DEBUG [VideoDeliveryEngine] Delivering file 'mms://stream1.france24.yacast.net/f24_liveen' using transcoding
2013-10-12 03:30:27,563 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.5, Profile=WDTV Live'
2013-10-12 03:30:28,125 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2013-10-12 03:30:28,125 DEBUG [TimeoutStreamDelegator] Scheduling stream stop to happen in 20 seconds if there is no traffic
2013-10-12 03:30:28,563 DEBUG [StreamBasedTranscodingDeliveryStrategy] Transcoded stream is empty, connection may have been lost
2013-10-12 03:30:28,563 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mms://stream1.france24.yacast.net/f24_liveen: MPEG_PS_PAL
2013-10-12 03:30:28,563 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mms://stream1.france24.yacast.net/f24_liveen: MPEG_PS_NTSC
2013-10-12 03:30:28,563 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-10-12 03:30:28,563 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-10-12 03:30:28,563 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Date: Sat, 12 Oct 2013 07:30:28 GMT,Server: Windows 8, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-12 03:30:31,173 DEBUG [ServiioHttpService] Incoming request from /192.168.1.5:46108: GET /resource/1000000020001270/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.1.3:8895,Accept: */*,Range: bytes=0-]]
2013-10-12 03:30:31,173 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-10-12 03:30:31,174 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-10-12 03:30:31,174 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.5, Profile=WDTV Live'
2013-10-12 03:30:31,174 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000020001270 and type 'MEDIA_ITEM' received
2013-10-12 03:30:31,174 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000020001270 (online)
2013-10-12 03:30:31,174 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2013-10-12 03:30:31,175 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000020001270, format MPEG_PS_PAL and profile WDTV Live
2013-10-12 03:30:31,175 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file mms://stream1.france24.yacast.net/f24_liveen
2013-10-12 03:30:31,175 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mms://stream1.france24.yacast.net/f24_liveen: MPEG_PS_PAL
2013-10-12 03:30:31,175 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mms://stream1.france24.yacast.net/f24_liveen: MPEG_PS_NTSC
2013-10-12 03:30:31,175 WARN  [GETMethodProcessor] A range header was found on the incoming request for a live stream, sending back the whole stream
2013-10-12 03:30:31,175 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000020001270 (online)
2013-10-12 03:30:31,175 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2013-10-12 03:30:31,176 DEBUG [VideoDeliveryEngine] Delivering item '1000000020001270' for client 'Identifier=192.168.1.5, Profile=WDTV Live'
2013-10-12 03:30:31,176 DEBUG [VideoDeliveryEngine] Delivering file 'mms://stream1.france24.yacast.net/f24_liveen' using transcoding
2013-10-12 03:30:31,176 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.5, Profile=WDTV Live'
2013-10-12 03:30:31,176 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mms://stream1.france24.yacast.net/f24_liveen: MPEG_PS_PAL
2013-10-12 03:30:31,176 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mms://stream1.france24.yacast.net/f24_liveen: MPEG_PS_NTSC
2013-10-12 03:30:31,176 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-10-12 03:30:31,176 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-10-12 03:30:31,176 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Date: Sat, 12 Oct 2013 07:30:31 GMT,Server: Windows 8, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-12 03:30:31,982 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2013-10-12 03:30:31,982 DEBUG [TimeoutStreamDelegator] Scheduling stream stop to happen in 20 seconds if there is no traffic
2013-10-12 03:30:36,530 DEBUG [ServiioHttpService] Incoming request from /192.168.1.5:46109: GET /resource/1000000020001270/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.1.3:8895,Accept: */*,Range: bytes=0-]]
2013-10-12 03:30:36,530 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-10-12 03:30:36,531 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-10-12 03:30:36,531 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.5, Profile=WDTV Live'
2013-10-12 03:30:36,531 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000020001270 and type 'MEDIA_ITEM' received
2013-10-12 03:30:36,532 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000020001270 (online)
2013-10-12 03:30:36,532 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2013-10-12 03:30:36,532 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000020001270, format MPEG_PS_PAL and profile WDTV Live
2013-10-12 03:30:36,532 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file mms://stream1.france24.yacast.net/f24_liveen
2013-10-12 03:30:36,532 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mms://stream1.france24.yacast.net/f24_liveen: MPEG_PS_PAL
2013-10-12 03:30:36,532 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mms://stream1.france24.yacast.net/f24_liveen: MPEG_PS_NTSC
2013-10-12 03:30:36,532 WARN  [GETMethodProcessor] A range header was found on the incoming request for a live stream, sending back the whole stream
2013-10-12 03:30:36,533 DEBUG [VideoDeliveryEngine] Delivering item '1000000020001270' for client 'Identifier=192.168.1.5, Profile=WDTV Live'
2013-10-12 03:30:36,533 DEBUG [VideoDeliveryEngine] Delivering file 'mms://stream1.france24.yacast.net/f24_liveen' using transcoding
2013-10-12 03:30:36,533 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.5, Profile=WDTV Live'
2013-10-12 03:30:36,533 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mms://stream1.france24.yacast.net/f24_liveen: MPEG_PS_PAL
2013-10-12 03:30:36,533 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file mms://stream1.france24.yacast.net/f24_liveen: MPEG_PS_NTSC
2013-10-12 03:30:36,533 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-10-12 03:30:36,533 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-10-12 03:30:36,533 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Date: Sat, 12 Oct 2013 07:30:36 GMT,Server: Windows 8, UPnP/1.0 DLNADOC/1.50, Serviio/1.3.1,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-10-12 03:30:36,762 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-10-12 03:30:36,762 DEBUG [TimeoutStreamDelegator] Scheduling stream stop to happen in 20 seconds if there is no traffic
2013-10-12 03:30:39,911 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth4 (Realtek PCIe GBE Family Controller) and address 192.168.1.3, timeout = 0
2013-10-12 03:30:39,911 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 92364609-eb74-3e48-a97f-fb1c988d0a03
2013-10-12 03:30:41,722 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:00 (advertisement duration is 1800 sec.)
2013-10-12 03:30:44,061 DEBUG [RepositoryDAOImpl] Reading all Repositories
Post Sun Oct 13, 2013 12:36 am
Looks like the stream may be the problem
Serviio is not fed any data for a bit when this is logged.
arphid
Post Sun Oct 13, 2013 12:40 am
I've tried more than 5 different streams that all run fine in the browser and vlc, all of them have the same problems. If you have a stream that is known to be working, let me know so I can test if the behavior is the same as the ones I've tried.
