Stumped with Metadata lookup
jimmernet
Post Sat Oct 26, 2013 9:02 pm
Hope this is a simple one...I'm trying to get my files named right to get a series looked up on line...Here's the log line that's failing..
2013-10-26 21:49:37,359 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Downton Abbey S02 E02.mpeg [VideoDescription [type=FILM, names=[downton abbey s02 e02, downton abbey], year=null, season=null, episode=null]]
2013-10-26 21:49:37,510 INFO [LibraryAdditionsCheckerThread] Added file 'Downton Abbey S02 E02.mpeg' (title: Downton Abbey S02 E02) to Library
It exists in www.thetvdb.com sure enough. The name and episodes are correct yet still it fails..The only think i can see is that it's somehow classifying it as a fim, does this mean it's not even looking up against www.thetvdb.com.
Can anyone help ?
cheers
Post Sun Oct 27, 2013 1:36 am
Re: Stumped with Metadata lookup
For my TV series, I have the season and episode together with no spaces.
Hawaii Five-O S01E03 Full Fathom Five.mkv
Don't know if it makes a difference. I use Filebot to ensure my file names are acceptable to theTVDB.com, since that is one of the available on line sources it will check against. Sometimes it's as simple as a space missing or needed.
Post Mon Oct 28, 2013 4:36 pm
The file name is not supported for series lookup, see http://www.serviio.org/index.php?option ... icle&id=12
Try removing the space between Sxx and Exx
Users browsing this forum: Bing [Bot] and 41 guests
