Sony Bravia KDL-46W5500 and MKV files
Gilles
Post Sun Nov 03, 2013 8:49 am
I am not able to watch MKV movies : they play very fast, there is no audio and it is very difficult to stop them using the remote control.
I run :
- Windows seven + Serviio v1.3.1 (last version)
- TV Sony Bravia KDL-46W5500 with the recommended firmware (PKG1.752EA)
- The profile used by Serviio is : Sony Bravia TV (2009) . The Device name is : KDL-46W5500
I went through the forum and I know that some recommend to update some parameters in the profiles.xml file but I don't really understand which one and in which section.
Is it possible to Watch MKV movies on this TV and if so, can someone (Illico :-) ? ) let me know which profile I have to use ?
Anyway, thanks for your work to let us enjoy this free media server.
Gilles
Post Sun Nov 03, 2013 11:09 am
Re: Sony Bravia KDL-46W5500 and MKV files
Does mkv files have embedded subtitle tracks?
What are subtitle settings on your serviio console ?
Could you provide some information about one mkv file that does not play fine ? (see signature links)
You can try to edit the 2010 section by replacing 4.1 by 3.0 value (2009 inherits of 2010 profile):
by
<Matches container="*" vCodec="h264" profile="high" levelGreaterThan="3.0" />
<Matches container="*" vCodec="h264" profile="main" levelGreaterThan="3.0" />
then restart serviio services or reboot PC.
Gilles
Post Sun Nov 03, 2013 2:15 pm
1) There is no subtitle.
The settings of the subtitle tab are :
- enable subtitles is ticked
- enable extrction ... is ticked
- enable burned-in subtitles is ticked with "only when required"
- subtitle character encoding : UTF-8
- preferred language : eng,en,fr (I am french)
2) Here are the output of the ffmpeg -i command :
Input #0, matroska,webm, from 'd:\mint\films\Laurent Lafitte (Comme son nom l'in
dique).mkv':
Duration: 01:36:56.00, start: 0.000000, bitrate: 1301 kb/s
Stream #0:0(eng): Video: h264 (High), yuv420p, 720x576 [SAR 64:45 DAR 16:9],
25 fps, 25 tbr, 1k tbn, 180k tbc (default)
Stream #0:1(fra): Audio: aac, 48000 Hz, stereo, fltp (default)
Stream #0:2(fra): Audio: ac3, 48000 Hz, stereo, fltp, 224 kb/s
3) I have changed 4.1 with 3.0 in Bravia 2010 profile and I have rebooted the PC. Now, the audio is good but the TV screen remains black or has too much pixels to be readable.
Let me know if you need more.
Gilles
Gilles
Post Sun Nov 03, 2013 5:10 pm
I have installed the 'Intel upnp' software to provide the supported formats of my TV. Here is the output display:
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:audio/L16:DLNA.ORG_PN=LPCM;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;SONY.COM_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_AC3;SONY.COM_PN=AVC_TS_HD_24_AC3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_AC3_T;SONY.COM_PN=AVC_TS_HD_24_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_50_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_60_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_50_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_60_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_50_L2_ISO;SONY.COM_PN=HD2_50_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_60_L2_ISO;SONY.COM_PN=HD2_60_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_50_L2_T;SONY.COM_PN=HD2_50_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_60_L2_T;SONY.COM_PN=HD2_60_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_50_AC3_ISO;SONY.COM_PN=AVC_TS_HD_50_AC3_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_60_AC3_ISO;SONY.COM_PN=AVC_TS_HD_60_AC3_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_50_AC3;SONY.COM_PN=AVC_TS_HD_50_AC3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3;SONY.COM_PN=AVC_TS_HD_60_AC3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_50_AC3_T;SONY.COM_PN=AVC_TS_HD_50_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3_T;SONY.COM_PN=AVC_TS_HD_60_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/x-mp2t-mphl-188:*
hope it helps
Regards,
Gilles
Post Sun Nov 03, 2013 5:34 pm
Your device should support h264 video, but it seems that something in your mkv/h264 troubles your Bravia TV.
After profile modification, your mkv file should be transcoded to mpegts/mpeg2video/ac3 format. (supported by your device).
Could you provide MediaInfo result ( in text format) of your mkv file ?
Gilles
Post Sun Nov 03, 2013 7:14 pm
Hi Illico,
here is the Mediainfo output in txt format:
Unique ID : 71699070421117813595120334114449010893 (0x35F0BD1988D6E6A691BD50BEFEA430CD)
Complete name : D:\Mint\Films\Laurent Lafitte (Comme son nom l'indique).mkv
Format : Matroska
Format version : Version 2
File size : 902 MiB
Duration : 1h 36mn
Overall bit rate : 1 302 Kbps
Writing application : HandBrake 0.9.5
Writing library : libmkv 0.6.4.1
Format : AVC
Format profile : High@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 36mn
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Writing library : x264 core 112
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=3 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Color primaries : BT.601 NTSC
Matrix coefficients : BT.601
Audio #1
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 1h 36mn
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Language : French
Default : Yes
Forced : No
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 1h 36mn
Bit rate mode : Constant
Bit rate : 224 Kbps
Bit depth : 16 bits
Stream size : 155 MiB (17%)
Language : French
Default : No
Forced : No
Post Mon Nov 04, 2013 8:03 am
I'm confused... your mkv file seems good but :
- In native format, the original h264 video track disrupts your Bravia TV.
- When transcoded to mpeg2video, the video track is pixelized.
Could you enable detailed logging and check the ffmpeg command line used during transcoding of your mkv file, then retry the same command line in a local windows terminal, then check ffmpeg output result and log ?
Gilles
Post Mon Nov 04, 2013 7:41 pm
Here is the log output.
nb : I still use the updated profile as requested but this evening, the movie is too fast to be readable and the audio is hashed again.
C:\Program Files\Serviio\lib>ffmpeg.exe -fflags +genpts -threads auto -i "D:\Mint\Films\Laurent Lafitte (Comme son nom l'indique).mkv" -y -threads auto -c:v copy -bsf:v h264_m
p4toannexb -c:a ac3 -b:a 384k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-816-sony2009-ORIGINAL.stf
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-libass --enable-librtmp --enable-font
config --enable-libfreetype --enable-zlib --enable-libx264 --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-runtime-cpude
tect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-mingw32- --enable-gpl --pkg-config=pkg-config
Input #0, matroska,webm, from 'D:\Mint\Films\Laurent Lafitte (Comme son nom l'indique).mkv':
Stream #0:0(eng): Video: h264 (High), yuv420p, 720x576 [SAR 64:45 DAR 16:9], 25 fps, 25 tbr, 1k tbn, 180k tbc (default)
Output #0, mpegts, to 'C:\Windows\TEMP\Serviio\transcoding-temp-816-sony2009-ORIGINAL.stf':
encoder : Lavf55.9.100
Stream #0:0(eng): Video: h264, yuv420p, 720x576 [SAR 64:45 DAR 16:9], q=2-31, 25 fps, 90k tbn, 1k tbc (default)
Stream #0:1(fra): Audio: ac3, 48000 Hz, stereo, fltp, 384 kb/s (default)
Stream mapping:
Stream #0:0 -> #0:0 (copy)
Stream #0:1 -> #0:1 (aac -> ac3)
Read error at pos. 27655228 (0x1a5fc3c)0kB time=00:01:05.72 bitrate=3362.9kbits/s
[matroska,webm @ 01A49E40] Read error at pos. 31324177 (0x1ddf811)
[matroska,webm @ 01A49E40] Read error at pos. 36696899 (0x22ff343)
[matroska,webm @ 01A49E40] Read error at pos. 39055805 (0x253f1bd)
[matroska,webm @ 01A49E40] Read error at pos. 41415469 (0x277f32d)
[matroska,webm @ 01A49E40] Read error at pos. 44692337 (0x2a9f371)
[matroska,webm @ 01A49E40] Read error at pos. 47313717 (0x2d1f335)
[matroska,webm @ 01A49E40] Read error at pos. 50918028 (0x308f28c)
[matroska,webm @ 01A49E40] Read error at pos. 54325417 (0x33cf0a9)
[matroska,webm @ 01A49E40] Read error at pos. 57471529 (0x36cf229)
[aac @ 01A5BF20] decode_band_types: Input buffer exhausted before END element found
Error while decoding stream #0:1: Error number -1 occurred
[matroska,webm @ 01A49E40] Read error at pos. 61534610 (0x3aaf192)
[matroska,webm @ 01A49E40] Read error at pos. 62976196 (0x3c0f0c4)
[matroska,webm @ 01A49E40] Read error at pos. 65073978 (0x3e0f33a)
channel element 0.0 is not allocated33264kB time=00:05:29.64 bitrate= 826.6kbits/s
[matroska,webm @ 01A49E40] Read error at pos. 68743199 (0x418f01f)
[matroska,webm @ 01A49E40] Read error at pos. 72021596 (0x44af65c)
[matroska,webm @ 01A49E40] Read error at pos. 75952975 (0x486f34f)
[matroska,webm @ 01A49E40] Read error at pos. 78311517 (0x4aaf05d)
[matroska,webm @ 01A49E40] Read error at pos. 81818055 (0x4e071c7)
[matroska,webm @ 01A49E40] Read error at pos. 84734253 (0x50cf12d)
[matroska,webm @ 01A49E40] Read error at pos. 87882258 (0x53cfa12)
[matroska,webm @ 01A49E40] Read error at pos. 90896652 (0x56af90c)
[matroska,webm @ 01A49E40] Read error at pos. 94041796 (0x59af6c4)
[matroska,webm @ 01A49E40] Read error at pos. 97188912 (0x5cafc30)
[matroska,webm @ 01A49E40] Read error at pos. 100201219 (0x5f8f303)
[matroska,webm @ 01A49E40] Read error at pos. 104591437 (0x63bf04d)
[matroska,webm @ 01A49E40] Read error at pos. 107082206 (0x661f1de)
[matroska,webm @ 01A49E40] Read error at pos. 109834504 (0x68bf108)
[matroska,webm @ 01A49E40] Read error at pos. 113045588 (0x6bcf054)
Read error at pos. 119403197 (0x71df2bd)0kB time=00:10:10.87 bitrate= 496.8kbits/s
[matroska,webm @ 01A49E40] Read error at pos. 122812877 (0x751f9cd)
frame=59390 fps=3352 q=-1.0 Lsize= 411557kB time=00:49:04.49 bitrate=1145.0kbits/s
video:254885kB audio:111380kB subtitle:0 global headers:0kB muxing overhead 12.366111%
********************************** then a lot of lines with different bitrates like : frame= 4306 fps=2150 q=-1.0 size= 46003kB time=00:12:21.10 bitrate= 508.5kbits
I have stopped the program using CTRL + C ****************************************************************
Received signal 2: terminating.
Post Tue Nov 05, 2013 8:20 am
The h264 video was still copied...not transcoded
dpbMbs = (720* 576* 4 ) / 256 = 6480 => Your file is a 2.2 h264level (http://wiki.serviio.org/doku.php?id=get_h264_level)
Could you try with 2.0 value instead of 4.1 (restart services or reboot after modification)?
by
<Matches container="*" vCodec="h264" profile="high" levelGreaterThan="2.0" />
<Matches container="*" vCodec="h264" profile="main" levelGreaterThan="2.0" />
EDIT: There were many errors on your mkv container.
Gilles
Post Thu Nov 07, 2013 6:37 am
I have changed 3.0 to 2.0 , the 1st minute is quite nice, b ut then, image and audio freeze. I have run the debug . Here is the output ( lot of errors).
C:\Program Files\Serviio\lib>ffmpeg.exe -threads auto -i "D:\Mint\Films\Laurent Lafitte (Comme son nom l'indique).mkv" -y -threads auto -c:v mpeg2video -b:v 17000k -maxrate:v
17000k -bufsize:v 17000k -r 25 -g 15 -c:a ac3 -b:a 384k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-816-sony2009-ORIGINAL.stf
[mpeg2video @ 0408B900] impossible bitrate constraints, this will fail
Stream #0:0(eng): Video: mpeg2video, yuv420p, 720x576 [SAR 64:45 DAR 16:9], q=2-31, 17000 kb/s, 90k tbn, 25 tbc (default)
Stream mapping:
Stream #0:0 -> #0:0 (h264 -> mpeg2video)
error while decoding MB 37 11, bytestream (td)=00:00:39.96 bitrate=319066.2kbits/s
[h264 @ 0369B4A0] concealing 1137 DC, 1137 AC, 1137 MV errors in P frame
error while decoding MB 5 11, bytestream (td)e=00:01:08.47 bitrate=213391.4kbits/s
[h264 @ 0369C040] concealing 1169 DC, 1169 AC, 1169 MV errors in P frame
Read error at pos. 27655228 (0x1a5fc3c)kB time=00:01:13.88 bitrate=198595.2kbits/s
[matroska,webm @ 0361A0E0] Read error at pos. 31324177 (0x1ddf811)
[h264 @ 0369B880] error while decoding MB 26 12, bytestream (td)
[h264 @ 0369B880] concealing 1103 DC, 1103 AC, 1103 MV errors in P frame
error while decoding MB 24 16, bytestream (td)=00:01:49.53 bitrate=134301.9kbits/s
[h264 @ 0369BC60] concealing 925 DC, 925 AC, 925 MV errors in P frame
error while decoding MB 15 10, bytestream (td)=00:01:50.04 bitrate=134888.2kbits/s dup=877 drop=0
[h264 @ 0369B880] concealing 1204 DC, 1204 AC, 1204 MV errors in P frame
[h264 @ 0369B4A0] error while decoding MB 40 4, bytestream (td)
[h264 @ 0369B4A0] concealing 1449 DC, 1449 AC, 1449 MV errors in P frame
[h264 @ 0369B880] error while decoding MB 31 3, bytestream (td)
[h264 @ 0369B880] concealing 1503 DC, 1503 AC, 1503 MV errors in P frame
[h264 @ 0369C040] error while decoding MB 2 15, bytestream (td)
[h264 @ 0369C040] concealing 992 DC, 992 AC, 992 MV errors in P frame
[matroska,webm @ 0361A0E0] Read error at pos. 36696899 (0x22ff343)
[matroska,webm @ 0361A0E0] Read error at pos. 39055805 (0x253f1bd)
[h264 @ 0369B880] mmco: unref short failure
Read error at pos. 41415469 (0x277f32d)kB time=00:02:29.73 bitrate=100296.4kbits/s dup=1813 drop=0
[h264 @ 0369BC60] reference picture missing during reorder
[h264 @ 0369BC60] Missing reference picture, default is 65688
error while decoding MB 6 5, bytestream (td)me=00:02:49.83 bitrate=88767.4kbits/s dup=2310 drop=0
[h264 @ 0369C040] concealing 1438 DC, 1438 AC, 1438 MV errors in I frame
[h264 @ 0369BC60] error while decoding MB 11 6, bytestream (td)
[h264 @ 0369BC60] concealing 1388 DC, 1388 AC, 1388 MV errors in P frame
Read error at pos. 44692337 (0x2a9f371)kB time=00:02:54.67 bitrate=86597.7kbits/s dup=2310 drop=0
Read error at pos. 47313717 (0x2d1f335)kB time=00:03:09.58 bitrate=80149.7kbits/s dup=2310 drop=0
[h264 @ 0369BC60] Missing reference picture, default is 65746
Read error at pos. 50918028 (0x308f28c)kB time=00:03:29.83 bitrate=73714.6kbits/s dup=3164 drop=0
Read error at pos. 54325417 (0x33cf0a9)kB time=00:03:49.86 bitrate=67670.5kbits/s dup=3650 drop=0
Read error at pos. 57471529 (0x36cf229)kB time=00:03:51.52 bitrate=67346.9kbits/s dup=3650 drop=0
error while decoding MB 4 8, bytestream (td)me=00:04:29.89 bitrate=58088.8kbits/s dup=4605 drop=0
[h264 @ 0369BC60] concealing 1305 DC, 1305 AC, 1305 MV errors in P frame
[h264 @ 0369C040] error while decoding MB 21 6, bytestream (td)
[h264 @ 0369C040] concealing 1378 DC, 1378 AC, 1378 MV errors in P frame
[h264 @ 0369B880] error while decoding MB 23 1, bytestream (td)
[h264 @ 0369B880] concealing 1601 DC, 1601 AC, 1601 MV errors in P frame
[h264 @ 03EBC520] left block unavailable for requested intra mode at 0 13
[h264 @ 03EBC520] error while decoding MB 0 13, bytestream (td)
[h264 @ 03EBC520] concealing 1084 DC, 1084 AC, 1084 MV errors in P frame
decode_band_types: Input buffer exhausted before END element found=57530.9kbits/s dup=4606 drop=0
[matroska,webm @ 0361A0E0] Read error at pos. 61534610 (0x3aaf192)
[h264 @ 0369C040] mmco: unref short failure
decode_band_types: Input buffer exhausted before END element found=54542.0kbits/s dup=4948 drop=0
[matroska,webm @ 0361A0E0] Read error at pos. 62976196 (0x3c0f0c4)
[matroska,webm @ 0361A0E0] Read error at pos. 65073978 (0x3e0f33a)
channel element 0.0 is not allocated432kB time=00:05:29.93 bitrate=48601.2kbits/s dup=5881 drop=0
[matroska,webm @ 0361A0E0] Read error at pos. 68743199 (0x418f01f)
Read error at pos. 72021596 (0x44af65c)kB time=00:05:49.92 bitrate=45824.9kbits/s dup=6359 drop=0
frame= 9282 fps=157 q=2.0 Lsize= 1957432kB time=00:06:11.49 bitrate=43164.4kbits/s dup=6833 drop=0
video:130623kB audio:4710kB subtitle:0 global headers:0kB muxing overhead 1346.380462%
Regards,
Gilles
Gilles
Post Fri Nov 15, 2013 5:55 pm
No idea or advise ?
If it comes from the file (I don't have any other mkv file), I may delete it but I just would need to be sure.
Regards,
Gilles
Post Fri Nov 15, 2013 7:03 pm
Gilles wrote:If it comes from the file (I don't have any other mkv file), I may delete it but I just would need to be sure.
Yes, from my point of view, it comes from the file.
You can try with the latest ffmpeg build : http://ffmpeg.zeranoe.com/builds/
simply replace the ./lib/ffmpeg.exe file (make a backup)
Gilles
Post Sun Dec 01, 2013 5:39 pm
I have tried the latest ffmpeg version, I still have the same issue.
The issue must be related to this file.
I give up.
Thanks for your help and your patience.
Gilles
Users browsing this forum: Google [Bot] and 13 guests
