Cannot read file
mikeemouse
Post Wed Nov 13, 2013 7:28 pm
Cannot read file
I am new to Serviio, and I have a Panasonic ET60B TV
Anyway I ran into a problem with an mkv file (3d half over-under), it starts up but stutters and stops within about 1 second with the error 'cannot read file'. The TV doesn't try to render it in 3d by default anyway (you have to select it manually), so it wouldn't appear to be a 3d problem.
Format : Matroska
Format version : Version 3 / Version 2
File size : 12.9 GiB
Overall bit rate : 14.0 Mbps
Writing application : mkvmerge v5.8.0 ('No Sleep / Pillow') built on Sep 2 2012 15:37:04
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Format : AVC
Format profile : High@L4.1
MultiView_Count : 2
MultiView_Layout : Top-Bottom (left eye first)
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 12.3 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.247
Stream size : 11.2 GiB (87%)
Language : English
Default : Yes
Forced : No
Format : DTS
Mode : 16
Codec ID : A_DTS
Bit rate mode : Constant
Bit rate : 1 509 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.38 GiB (11%)
Language : English
Default : Yes
Forced : No
This one meanwhile works fine:
Format : Matroska
File size : 7.32 GiB
Overall bit rate : 10.9 Mbps
Encoded date : UTC 2013-10-31 12:46:20
Format : AVC
MultiView_Count : 2
Bit rate : 9 219 Kbps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.185
Stream size : 6.16 GiB (84%)
Language : English
Default : Yes
Forced : No
Format : DTS
Format profile : ES
Mode : 16
Codec ID : A_DTS
Bit depth : 24 bits
Stream size : 1.01 GiB (14%)
Language : English
Default : Yes
Forced : No
According to the manual
MKV supported with these codecs:
Video codec:
H.264 BP/MP/HP, MPEG1, MPEG2, MPEG4 SP/ASP
Audio codec:
AAC, Dolby Digital, Dolby Digital Plus, DTS core, HE-AAC, MPEG Audio, MP3
I have tried the following profiles:
Panasonic 2013/Generic: doesn't work
Panasonic 2011/2012: works, but I guess this is transcoding which shouldn't be necessary
Any ideas on how to fix this?
mikeemouse
Post Wed Nov 13, 2013 7:29 pm
Re: Cannot read file
Just to add, I am connecting over gigabit ethernet, so it's not a bandwidth issue.
mikeemouse
Post Wed Nov 13, 2013 11:18 pm
Looks like this might be a similar issue:
viewtopic.php?f=13&t=14301
Perhaps a lack of CPU power with the TV?
Post Thu Nov 14, 2013 9:31 am
This is a very big stream, so if it was remuxed or transcoded by ffmpeg on the temporary folder, it will grow up, check that you have enough space on this folder.
mikeemouse
Post Thu Nov 14, 2013 3:19 pm
If I allow it to transcode, by selecting the 2011 profile, it plays.
If I turn off transcoding, e.g., by selecting the Generic DLNA Profile, that's when it doesn't work.
mikeemouse
Post Thu Nov 14, 2013 8:38 pm
This is what it transcodes to:
Complete name : V:\transcoding-temp-1044-viera2011-ORIGINAL.stf
Format : MPEG-TS
File size : 12.6 GiB
Duration : 2h 11mn
Overall bit rate : 13.8 Mbps
Menu ID : 1 (0x1)
Format : AVC
Codec ID : 27
Duration : 2h 11mn
Bit rate : 12.9 Mbps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.259
Stream size : 11.8 GiB (94%)
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 129
Duration : 2h 11mn
Bit rate : 192 Kbps
Bit depth : 16 bits
Delay relative to video : -5ms
Stream size : 180 MiB (1%)
Language : English
Menu
Menu ID : 1 (0x1)
Duration : 2h 11mn
List : 256 (0x100) (AVC) / 257 (0x101) (AC-3, English)
Language : / English
Service name : Service01
Service provider : FFmpeg
Service type : digital television
That plays fine, though obviously I don't want it to transcode....
Post Mon Dec 02, 2013 9:36 pm
If the file doesn't play natively then it's up to the TV, or the way the file has been encoded.
Return to Panasonic
