Samsung D Series has issues with certain characters
Markus
Post Fri Nov 15, 2013 3:19 pm
fyi: I finally fixed an issue I had for ages and couldn't find out about with debug log. the d series samsung had problems with only one specific video folder, it couldnt have been the amount of files (there were bigger folders) until I finally figured it out yesterday. there were 2 files with a TM character in the file name (perfectly fine for windows). After I had renamed those, the tv can now access and list that folder.
maybe serviio should filter those files out?
Markus
Post Fri Nov 15, 2013 3:21 pm
Re: Samsung D Series has issues with certain characters
were the files added to the library and only failed to be browsed /played? or were they not even added?
Do you have a filename example?
Markus
Post Fri Nov 15, 2013 3:39 pm
the files were added to the library, but once you tried to access the folder containing theses files the tv just jumped up to the highest folder (crashed?). The specific character in the file name was, in this case "™".
Markus
Post Fri Nov 15, 2013 3:49 pm
oh btw i'm pretty sure that the ominous "WARN [ContentDirectory] Object with id V_L doesn't exist" is caused by this
Post Sun Nov 17, 2013 11:40 am
Markus wrote:oh btw i'm pretty sure that the ominous "WARN [ContentDirectory] Object with id V_L doesn't exist" is caused by this
Where did you see this? Can you post detailed log reproducing this?
Markus
Post Mon Nov 18, 2013 6:52 pm
I don't have the specific log anymore, got overwritten, but this was an extract out of the detailed log at the time stamps the TV showed the faulty behavior. As i don't wanna mess around with the configuration anymore, couldn't you just create a file with certain characters in question and debug the problem far better than me? besides the "object doesn't exist" there was nothing else in the log file hinting at the specific problem anyway :-)
Post Wed Nov 20, 2013 8:10 pm
Ok, thanks
