Sony Bravia add subtitles destroy the resolution
• Page 1 of 1
Whenever i try to play mkv files with subtitles on them servio resizing the image and it is pushed on the midle. i change the tv settings but still is pushed. I tryed other media servers but they all saw it normal but they lag. Servio dont lag but push the screen.
Re: Sony Bravia add subtitles destroy the resolution
What is your TV model ?
What is the profile used on serviio console ?
my tv model is sony bravia kdl40ex720
what you mean about the profile used on serviio?
aristos90 wrote:my tv model is sony bravia kdl40ex720
Ok, and is it an UK or an US model ?
aristos90 wrote:what you mean about the profile used on serviio?
Open serviio console, on Status tab, look at the renderer profile list and check what is the profile selected for your Bravia TV.
EDIT: What are your TV screen settings ?
http://pdf.crse.com/manuals/iManuals/en ... notpc.html
i think its a uk model cause i am from greece.
the profile is sony bravia tv 2011.
i tested all the settings to help the image become better, on wolverine hd it helped but stil is not that good and he make all peoples short. The only movie i had no problem was pacific rim cause it was 1900x1020. Wolverine was 1900x798
aristos90 wrote:i think its a uk model cause i am from greece.
Could you try to change the profile on serviio console and select "Sony Bravia 2011 US", then press save ?
EDIT : Do you try with the zoom button (Screen format) on remote control ?
viewtopic.php?f=11&t=2396&p=17682#p17682
i tryed it. on wolverine it helped me a little but on an other movie it cuts right and left when i zoom, on wolverine it didnt but still it was pushed.
i just tryed to use sony bd profile and it works but it shutters, i dont know if it helps
i dont know why but when i changed it back to bravia 2011 its keep shutter soo i tryed to close everything and test bdp-sx70 again and its playing fine. no shutter no pushing the image. maybe this is a solution. i set it to use all 4 cores too
i am wrong. still shutterson my other movie.
the file that shutters is mp4 and wolverine is on mkv. is it normal that mp4 shutter and mkv dont?
Illico wrote:What are your TV screen settings ?
Illico wrote:Do you try with the zoom button (Screen format) on remote control ?
yeah i tryed it and it cut the right and left side on the mp4. on mkv it dont but it dont help me.
Illico wrote:Illico wrote:What are your TV screen settings ?
i can change this settings when i still play the movie. whatever i try it dont make it normal.
i still have problems with mkv files. when i choose the sony bsp-sx70 the image stay the same but i only see the english letter subtitles, whenever its greek it dont show me the subs, not even strange letters. the srt is in utf-8 if you ask.
• Page 1 of 1
