Serviio and Mavericks
I use OS Mavericks. I can not start Serviio.
I am obliged to leave by forcing Serviio.
Is Serviio Mavericks is compatible with?
hillaj1 wrote:I have downgraded to Apple Java 6
jaruzek wrote:hillaj1 wrote:I have downgraded to Apple Java 6
Why have you downgraded your Java installation? Actually, the question is should we be using Apple's implementation of Java or the official Oracle release?
zip wrote:I have Mavericks, Java 7 _25. Note that Serviio is not using Java 7 on OSX, it only works with Apple's Java 6.
What I'm seeing is that Serviio bounces on the dock, then I run Console, all works. If you want to quit Serviio, right-click on Serviio Console and Exit Serviio.
Does the server not work for you at all? Ie, do you have anything in the log?
Users browsing this forum: Google [Bot] and 73 guests
