Twitch.tv/Justin.tv
OMEN42
Post Tue Nov 26, 2013 10:06 am
Re: Twitch.tv/Justin.tv
Hi all
I opened yesterday in the main support forum the text below. But I guess it is well placeds directly within this thread.
If there is any discrepancies pls delete the other one:
Subj: Twitch plug in with WDTV Gen3?!
Hey Guys
First of all many thanks to your support and developing those great applications.
As I mentioned in the subject line above, I have the serviio software on my PC and want to stream eSports games through my WD TV Live to my TV downstairs.
The problem is that I buyed a WD TV Live of the third generation. That means that we are currently not able to use a customize firmware on it.
If I use the media server the WD shows me the twitch channels but the device said: This format are not supported.
Is anybody out there to have an idea to solve these problem? Otherwise I have to wait for a custom firmware or have to buy an older version of the WD TV device ;)
Thanks and bye,
OMEN
jules
Post Tue Nov 26, 2013 3:58 pm
have you set the wdtv live profile in the status tab of serviio?
OMEN42
Post Tue Nov 26, 2013 5:09 pm
Hi
Hmm interesting I didn´t know the option to set it..thanks for the hint...
Now I get the message;: There is no media in the current folder.
Yesterday WD gave me the option to choose the stream quality and next came the message format not supported.
Any other ideas? Many thanks for help.
OMEN42
Post Tue Nov 26, 2013 6:18 pm
Arghhhhhhh... I can not believe it...it works :D
I suppose the Profile set was the key..many thanks to jules...
Thanks to all developer and eSports Fans let the battle begin my couch is waiting for me:)
just instant buy the full version...
so far OMEN
jules
Post Tue Nov 26, 2013 6:33 pm
and remember, if you watch dota instead of starcraft, you're a total loser!
OMEN42
Post Tue Nov 26, 2013 7:22 pm
I am a full time SC2 watcher xD
by the way 1080 is too high for streaming I guess? 720 runs smooth but not higher solution....
jules
Post Wed Nov 27, 2013 12:04 am
depends on the device. my samsung tv's internal media player handles 1080p30 just fine, it just won't run 1080p60.
bjurran
Post Thu Nov 28, 2013 5:45 pm
Trying to get this to work with the dreamhack streams and watch it on my Samsung C6700.
My first mistake was to add the dreamhack.tv links, but that obviously doesn't work.
Added http://www.twitch.tv/dreamhack instead and now I have the online folder up and running, but every now and then the files are not played and it's complaining about unsupported format.
If I try again, it will start but only the first few video frames are played and after that only the audio is live.
Any suggestions where to go from here?
(Unfortunatelly I can't test it with VLC as my library is massive and dreamhack would be over before I can try)
jules
Post Thu Nov 28, 2013 7:43 pm
several things:
1. dreamhack's "live" streams are 720p60. my es6100 struggles with that (may be the bitrate?) and plays audio with stuttering video. maybe "high" is better for you?
2. you need to force refresh (console's context menu) the library entries every other minute because that's about the time that it takes for the tokens that the plugin acquires to expire. that may explain your unsupported format messages.
Amaze
Post Thu Dec 05, 2013 3:24 pm
Thanks for this. Watching live content worked just fine, but is it possible to view past broadcasts with this as well?
jules
Post Sat Dec 07, 2013 5:49 pm
nope
andreyv
Post Sun Dec 08, 2013 7:52 pm
Hi, and thanks for this awesome plugin!
Do I understand correctly that ffmpeg is only used to forward the RTMP stream and does not transcode/modify the data in any way?
jules
Post Sun Dec 08, 2013 9:24 pm
depends on your profile. if your renderer understands and handles the codecs, ffmpeg is essentially an rtmp client and only forwards data, yes.
clanner
Post Sun Dec 08, 2013 9:57 pm
I have a Olevia LT26HVE with my PS3 hooked up through a component cable. The max resolution the monitor supports is 1080i and im having issues with the edges on streams being cutoff when selecting 720/1080p streams. Any ideas how to fix this? I've already tried playing with the scaling/aspect ratio settings on the monitor and none of it seems to have any affect on fixing the issue.
jules
Post Sun Dec 08, 2013 10:25 pm
maybe you can toy with the ps3 settings? this really has nothing to do with this plugin, i can't help you, sorry
clanner
Post Sun Dec 08, 2013 10:28 pm
Understood, figured i might as well ask, thanks anyawys. :)
andreyv
Post Mon Dec 09, 2013 10:16 am
jules wrote:depends on your profile. if your renderer understands and handles the codecs, ffmpeg is essentially an rtmp client and only forwards data, yes.
I have disabled transcoding in the Serviio console. So I suppose ffmpeg just forwards the stream unmodified. Thanks!
jules
Post Mon Dec 09, 2013 9:19 pm
i've updated the first post with a new version.
new in this is, among a few older, un-published bugfixes, support for the mobile stream api of twitch. this is used by the android and ipad/iphone apps and is sometimes useful if the (default, better quality) rtmp choices are laggy.
V7: mobile streams now also display the source quality
andreyv
Post Thu Dec 12, 2013 1:09 pm
Hello again :)
With the latest V7 I get this error in Serviio log when opening a stream:
2013-12-12 15:03:44,829 WARN  [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
libavresample   1.  1.  0 /  1.  1.  0
libswscale      2.  5.101 /  2.  5.101
libswresample   0. 17.104 /  0. 17.104
"rtmp://199.9.254.235/app playpath=jtv_aZ2j9IMDupoR8ckc swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.rd730d7268f3f46ec36fc591028917d9568f1fdf9.swf swfVfy=1 jtv=37214088c77d492a5a71493bc4f03c6eacca673e:{"swfDomains":\20["justin.tv",\20"jtvx.com",\20"xarth.com",\20"twitchtv.com",\20"twitch.tv",\20"newjtv.com",\20"jtvnw.net",\20"wdtinc.com",\20"imapweather.com",\20"facebook.com",\20"starcrafting.com"],\20"streamName":\20"jtv_aZ2j9IMDupoR8ckc",\20"expiration":\201386857002,\20"server":\20"video15-1.fra01"} live=1": No such file or directory
V4, however, works fine. What could be wrong here? Can I help debug this? (My OS is Arch Linux.)
drecko
Post Fri Dec 13, 2013 6:32 pm
I received the follow error via the log file. The error still persisted even after follow your direction and updating ffmeg.exe.
2013-12-13 13:22:35,955 WARN  [FeedUpdaterThread] Failed to retrieve online item information for "rtmp://199.9.253.153/app playpath=jtv_LMhCqdMCo6NTkAVM swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.r63276f112912c920ca1c0bb17d8eee84e8062304.swf swfVfy=1 jtv=9a2a8eb4604aee61cda71a7d1b89d8b8db603f73:{\"swfDomains\":\20[\"justin.tv\",\20\"jtvx.com\",\20\"xarth.com\",\20\"twitchtv.com\",\20\"twitch.tv\",\20\"newjtv.com\",\20\"jtvnw.net\",\20\"wdtinc.com\",\20\"imapweather.com\",\20\"facebook.com\",\20\"starcrafting.com\"],\20\"streamName\":\20\"jtv_LMhCqdMCo6NTkAVM\",\20\"expiration\":\201386962548,\20\"server\":\20\"video32-1.sfo01\"} live=1". It might not play.
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:320)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:237)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:116)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:454)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:97)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:135)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:297)
   ... 2 more
Return to Available plugins
