kdl40nx720 subs and video
stormz
Post Sat Dec 14, 2013 3:36 pm
hallo, i am new here i was using windows media for dlna but some large files .avi and some HD didnt even apear on the list of movies.
then i installed serviio and apear and playing with a little delay probably cause of my old pc , but now the old movies dont even show the subittles which are embeded with aviaddsubs program, and also from full screen now only shows them in the 1/3 of the screen. what can i do fix the full screen and see the subtitles i tryed almost all , (same folder same name subs) (embed subs) (-eng sub) nothing changed..
thanks alot.
NX3
Post Sun Dec 15, 2013 8:28 pm
Re: kdl40nx720 subs and video
have you enables transcoding and subs in serviio ?
stormz
Post Fri Dec 20, 2013 10:09 pm
yes , i trying anything i search and thought google for serviio problems but nothing
Post Mon Dec 23, 2013 3:47 am
Which profile are you using for the device (Serviio Console, Status tab). It sounds like your AVI files are being transcoded (which will strip the embedded subs).
Can you please also post MediaInfo information for some of the files that do not work? It may not be related to size of the file, but more likely to the format of the video or audio stream.
stormz
Post Tue Dec 24, 2013 2:57 pm
here is your mediainfo you asked
this file play full screen with subs with windows dlna but with serviio not full screen and without subs
mediafile 1.JPG (99.06 KiB) Viewed 7973 times
this file does not apear with windows media dlna but apear with serviio
mediafile 2.JPG (114.53 KiB) Viewed 7973 times
Post Tue Dec 24, 2013 9:23 pm
What profile are you using?
stormz
Post Wed Dec 25, 2013 8:04 pm
i am using the sony 2010 as i saw in some posts
