Humax HDR-2000T TS files
sturge
Post Thu Dec 12, 2013 11:23 pm
Hi I have Serviio running successfully and working on normal files, but am trying to access Humax files on my new Humax HDR-2000T. They are TS files so assume same as older ones. They don't get recognised by Serviio and this is the error on ffmpeg:
ffmpeg.exe -i "C:\Test-media\Peep Show\Peep Show_20131210_2200.ts"
C:\Test-media\Peep Show\Peep Show_20131210_2200.ts: could not find codec parameters
Serviio log shows the following
2013-12-12 22:33:40,866 DEBUG [LibraryAdditionsCheckerThread] Found file 'Peep Show_20131210_2200.ts', checking if it's already in the Library
2013-12-12 22:33:40,866 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item C:\Test-media\Peep Show\Peep Show_20131210_2200.ts
2013-12-12 22:33:40,866 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: C:\Test-media\Peep Show\Peep Show_20131210_2200.ts, ignore case: true
2013-12-12 22:33:40,867 DEBUG [MediaItemDAOImpl] Media item C:\Test-media\Peep Show\Peep Show_20131210_2200.ts doesn't exist in DB yet
2013-12-12 22:33:40,867 DEBUG [LibraryAdditionsCheckerThread] File not in Library, will add it
2013-12-12 22:33:40,867 DEBUG [VideoExtractionStrategy] Extracting metadata of video file: C:\Test-media\Peep Show\Peep Show_20131210_2200.ts
2013-12-12 22:33:40,867 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: C:\Test-media\Peep Show\Peep Show_20131210_2200.ts
2013-12-12 22:33:40,868 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i C:\Test-media\Peep Show\Peep Show_20131210_2200.ts
2013-12-12 22:33:54,330 WARN [LibraryManager] Skipping processing metadata for an unsupported file (Peep Show_20131210_2200.ts). Message: Unknown video file type.
2013-12-12 22:33:54,331 DEBUG [LibraryAdditionsCheckerThread] Found file 'Peep Show_20131210_2235.ts', checking if it's already in the Library
2013-12-12 22:33:54,331 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item C:\Test-media\Peep Show\Peep Show_20131210_2235.ts
2013-12-12 22:33:54,331 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: C:\Test-media\Peep Show\Peep Show_20131210_2235.ts, ignore case: true
2013-12-12 22:33:54,331 DEBUG [MediaItemDAOImpl] Media item C:\Test-media\Peep Show\Peep Show_20131210_2235.ts doesn't exist in DB yet
2013-12-12 22:33:54,332 DEBUG [LibraryAdditionsCheckerThread] File not in Library, will add it
2013-12-12 22:33:54,332 DEBUG [VideoExtractionStrategy] Extracting metadata of video file: C:\Test-media\Peep Show\Peep Show_20131210_2235.ts
2013-12-12 22:33:54,332 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: C:\Test-media\Peep Show\Peep Show_20131210_2235.ts
2013-12-12 22:33:54,332 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i C:\Test-media\Peep Show\Peep Show_20131210_2235.ts
2013-12-12 22:34:05,116 WARN [LibraryManager] Skipping processing metadata for an unsupported file (Peep Show_20131210_2235.ts). Message: Unknown video file type.
Can someone steer me in the right direction to resolve this please?
Post Thu Dec 12, 2013 11:38 pm
Re: Humax HDR-2000T TS files
The .ts files from some Humax devices are encrypted to only play on the device they are recorded on. Suspect that is the case here - can you play the file from a USB stick or otherwise?
sturge
Post Mon Dec 16, 2013 11:19 am
Hi - sorry for the slow response. Yes, the files will play fine on other DLNA devices - I'm using a Samsung Smart blu ray player and also a WD Live player and they can both play fine. I have some Sony TVs and Blu Ray players that wont play, so trying to get these to play via Serviio.
mightymouse2045
Post Tue Dec 17, 2013 6:26 pm
sturge wrote:Hi I have Serviio running successfully and working on normal files, but am trying to access Humax files on my new Humax HDR-2000T. They are TS files so assume same as older ones. They don't get recognised by Serviio and this is the error on ffmpeg:
As this is windows and not linux i dont know the exact command, but perhaps an ffmpeg /? To find what command lists all the available decoders. In linux its ffmpeg -decoders
Run that and search for mpegts or just ts in the output. It could be u need to recompile ffmpeg with support for it....
Sent from my GT-P7500 using Tapatalk
Users browsing this forum: Google [Bot] and 13 guests
