[SOLVED] KDL-32EX720
francebeau
Post Fri Dec 13, 2013 6:16 pm
I'm running Win7 on a laptop and just installed servio 1.3.1 for the first time. I've set up the console for Sony Bravia 2011, but I don't get the green dot. My TV does show Serviio in media so it is apparently recognised over the WiFi. What do I need to do to fix it?
NX3
Post Sun Dec 15, 2013 8:19 pm
Re: KDL-32EX720
Can you ping your tv from the PC ?
Have you tried ethernet cable between all devices ?
francebeau
Post Sun Dec 15, 2013 10:06 pm
Re: KDL-32EX720
I can't ping :evil:
in cmd.exe i get:
'ping'is not recognized as an internal or external operable program or batch file.
Also, can't connect with ethernet cable because of location of modem. That's why I'm connected over WiFi
Post Sun Dec 15, 2013 11:48 pm
Re: KDL-32EX720
Ignoring the green dot issue, can you play your media?
Some of my devices have never produced a green dot but work perfectly.
francebeau
Post Mon Dec 16, 2013 7:47 am
Re: KDL-32EX720
TV now doesn't even show serviio server anymore.
Have checked firewall and serviio is listed allowed in both incoming and outgoing rules ...
NX3
Post Mon Dec 16, 2013 11:10 am
Re: KDL-32EX720
What firewall app do you have ?
What router do you have ?
Have you tried disabling the firewall completely just to test if serviio / laptop can see the the pc ?
This is how to fix your ping missing problem
http://www.howtogeek.com/forum/topic/pi ... al-command
francebeau
Post Mon Dec 16, 2013 5:52 pm
Re: KDL-32EX720
Ping with firewall on and off gave 100% score. So TV visible in network. Can also access internet TV (like YouTube) from TV.
Also with firewall "off" no server visible, also scan for server negative.
Tried adding TV mac-address in modem (zyxel P-2601HN(L)-F1 series) but no still no server visible / scannable on TV.
francebeau
Post Tue Dec 17, 2013 8:16 pm
Re: KDL-32EX720
Problem solved. I'm using an access point (which I had forgotten about) and after I entered the TV's MAC address there it was instantenously recognised by serviio.
Thank you for your assistance!
