No subtitles in Samsung UE42F5500
Achilles2
Post Mon Dec 30, 2013 8:16 pm
Hi.
I've recently purchased a new LED TV (UE42F5500) and I don't see any subtitles when I try to stream any movies from my computer. Everything works fine with my other Samsung TV (UE55D8000). Is this something related to the fact that serviio doesn't support subtitles on this model or do I need to change something on my setup?
Iveky
Post Mon Dec 30, 2013 8:57 pm
Re: No subtitles in Samsung UE42F5500
should work on F same as on D....
Achilles2
Post Tue Dec 31, 2013 10:08 am
Iveky,
That was my thought also, but it just doesn't work. Only difference between both TVs is that serviio is streaming to the D series through cable and to the F series through wifi.
Iveky
Post Tue Dec 31, 2013 10:16 am
check profile choosen for both?
wifi could have impact on quality (waitings), but not on displaying of subtitles.
in serviio console, subtitles section, disable everything except first option: Enable subtitles
Achilles2
Post Wed Jan 01, 2014 1:35 am
That's already the current setup :)
Iveky
Post Wed Jan 01, 2014 7:37 am
and have you tried wired connection on F, just to check out?
Achilles2
Post Thu Jan 02, 2014 9:50 am
Nevermind.
Seems the TV's default setup doesn't have the subtitles option active. Stupid enough, you need to hit the tools button only when you select the HDMI source to be able to access the option.
Iveky
Post Thu Jan 02, 2014 1:30 pm
ok. i forgot that option too
Users browsing this forum: Baidu [Spider] and 10 guests
