Remux/Audio Transcoding Only Option
Xmantium
Post Thu Jan 02, 2014 12:22 am
Please can you also add the option for Remux/Audio Transcoding Only option
My main Serviio is run on a low power efficient ARM CPU to run 24/7
Theres alot of NAS that run ARM, their cheaper than the Intel version. 3 in 1 Serviio QPKG Serviio for my QNAP package downloaded are ARM chips.
This ARM CPU has the capability to transcode audio and remux video files but not good at transcoding video at all!
If i uncheck Enable transcoding, the video files could play by remux/audio transcoding dissappear from my Sony TV
My request to include one extra option on Transcoding tab:
[ ] Enable Full Transcoding
[ ] Enable Remux/Audio Transcoding only
Post Mon Jan 06, 2014 7:59 am
Re: Remux/Audio Transcoding Only Option
Not quite sure what you need. You want the files that cannot be played due to the power not appear? It seems more confusing for people, they will be complaining that their files are not added.
Xmantium
Post Mon Jan 06, 2014 11:53 pm
Yes. By not ticking "Enable transcoding", only the native files appear on my devices.
If by having Remux only option, native files and files than can be remuxed will appear (alot more files than turning off "Enable Transcoding")
It causes a big issue on my low powered server when a file is fully transcoded (ie CPU 100% for long periods, heat that stock ARM fan cant cool down, slows down other services i need running).
I have to manually kill the process.
To avoid accidental playing files thats fully transcoded ive resorted edit the profile.xml to avi and other files that require full transcode on my Sony TV. I have to do this everytime in install a new build.
To avoid the confusion, possible a message saying "Not all your videos will appear if this option is enabled"
I rather avoid attemping playing .avi files on my TV that would cause a massive strain on my sever. So hiding them would be easier.
Im sure other NAS users want this rather to turn off Enable transcoding alltogether! I would love this!
probedb
Post Mon Jan 20, 2014 2:33 pm
Wouldn't creating a custom profile work, then you can tell it what to do?
Serviio can't know whether a particular file will cause lots of CPU usage. I guess the remux option will assume this is always OK and just remux the video/audio with no transcoding. I just assumed you could do that in profiles.
Xmantium
Post Sun Jan 26, 2014 9:01 pm
That's what I've been doing, removing all the file types in profiles that I know Serviio will full transcode, example mkv files don't show up on Xbox 360, avi files don't appear on my Sony TV
Return to Feature requests
