problem with summary and picture on tv show
bengio
Post Sun Feb 09, 2014 2:20 pm
hi. i'm installed serviio on my NAS synology ds231j and i use seviiodroid like console but i have some problem to show image and summary of tv show (metadata), For the film i have not prolem. For example i have like this in the folder
but in the folder "show tv" i saw only 6 fle on 10 on i don't seen the picture ad sunmary. I saw like that:
I tried to change the name of file in "castle S01E01" but there is the same problem
in app serviidroid i set up search on metadata on line
please help me
thanks
ServiiGo beta tester
bobsmo
Post Sun Feb 09, 2014 7:40 pm
Re: problem with summary and picture on tv show
Has to be named Castle 2009 as per thetvdb.com.......
bengio
Post Wed Feb 12, 2014 9:46 pm
bobsmo wrote:Has to be named Castle 2009 as per thetvdb.com.......
thks. you were right. I resolved.
Bye
bengio
Post Fri Feb 14, 2014 10:37 pm
another tv serire with problem of recognize: Psycho-Pass that there is in thetvdb.com
thks
Post Sat Feb 15, 2014 6:12 pm
Try to remove the '-'
bengio
Post Mon Feb 17, 2014 8:21 pm
zip wrote:Try to remove the '-'
it works now. How did you know?
thanks
Post Mon Feb 17, 2014 10:12 pm
The file name parser in Serviio removes everything after a - (it assumes it's rubbish data)
bengio
Post Mon Feb 17, 2014 10:59 pm
zip wrote:The file name parser in Serviio removes everything after a - (it assumes it's rubbish data)
Thanks for explaining it to me
bobsmo
Post Tue Feb 18, 2014 12:22 am
Ha! No wonder Hawaii Five-0 is messed up most of the times.......
lgvlgv
Post Wed Apr 02, 2014 7:05 pm
Hi all Cant for my life get tvshow "Bitten" to show the poster picture? and useing XBMC nfo files dosent seem to work, all shows show poster if i use online source exept "Bitten"?
anyone get any idea how to use XBMC only and be able to se posters in tvshows? the rest movies seems to work.
i have this in bitten folder.
In XBMC all works perfekt.
//regards L
bengio
Post Sun Sep 28, 2014 1:47 pm
Hi. I don't understood because the cover of singol episode of house of Cards is correct but the principal cover of the serie is wrong. It shows the cover of house of Cards trinity. The name of file is "house of Cards (2013) 1x1.mkw". Thanks
Inviato dal mio GT-P6200 utilizzando Tapatalk
Post Sun Sep 28, 2014 8:44 pm
That's strange. I have mine named "Hawaii Five-O SxxExx.MKV" with no issues. However, if I use 0 instead of O (number instead of capital letter) I get the remake, not the original.
Post Sun Sep 28, 2014 8:49 pm
lgvlgv wrote:Hi all Cant for my life get tvshow "Bitten" to show the poster picture? and useing XBMC nfo files dosent seem to work, all shows show poster if i use online source exept "Bitten"?
//regards L
You can't choose to use local files for just one series. It's all or nothing, in that if you use the online databases, it uses online for everything. It doesn't matter if you have anything local for a particular movie or series. There's been discussion about Serviio using local files if found, and use online otherwise, but I have no idea if it went anywhere.
bobsmo
Post Mon Sep 29, 2014 8:25 am
I tried that many moons ago and it did not work.
In any case, I got Hawaii.Five0.2010 to work in the end.
bengio
Post Tue Oct 07, 2014 6:43 pm
Re: R: problem with summary and picture on tv show
bengio wrote:Hi. I don't understood because the cover of singol episode of house of Cards is correct but the principal cover of the serie is wrong. It shows the cover of house of Cards trinity. The name of file is "house of Cards (2013) 1x1.mkw". Thanks
Anybody can help me about this little problem with house of Cards?
Inviato dal mio Xperia S utilizzando Tapatalk
bobsmo
Post Thu Oct 09, 2014 7:41 am
All I know is that House.Of.Cards.2013.SnnEnn works for me.
bengio
Post Thu Oct 09, 2014 7:57 am
bobsmo wrote:All I know is that House.Of.Cards.2013.SnnEnn works for me.
also the principal image of series?
the name of my file is "house of Cards (2013) 1x1.mkw"
the imagine of single episodie is correct
but the image of the series is wrong (House of card trilogy http://www.play.com/DVD/DVD/4-/41746818 ... oduct.html)
Post Fri Oct 10, 2014 2:45 pm
it's probably got the series image earlier wrong. You'd have to remove the whole series, refresh, add it back, refresh.
bengio
Post Fri Oct 10, 2014 9:10 pm
zip wrote:it's probably got the series image earlier wrong. You'd have to remove the whole series, refresh, add it back, refresh.
Thks Zip. The first card now is correct after remove refresh and add but the second card image is wrong. See under
Post Sun Oct 12, 2014 10:55 pm
Which second card? Seasons dont have any image.
Return to General discussion
