No stored files found
Richard
Post Sat Mar 01, 2014 12:49 am
I've got a Samsung UN60F7100 and I am using serviio 1.4.
Start serviio.sh and then serviio-console.sh.
Samsung in its "All Content" page displays a "sub-window" named Serviio.
(I, earlier this week tried to get tvmobili to work - actually, I
was trying to get the Samsung to recognize any media server on my
Linux box - and it, tvmobili, had installed itself as a daemon, so that
Samsung also recognizes tvmobili as a device each time I am on its
"All Content" page.)
I then add the Library local directories: Pictures, Videos and Music.
Note that with serviio 1.4 there is NO Save button on the TAB so just
about all of the discussions about saving and all serviio Library TAB
images showing the Save button are not applicable. The "Force refresh"
button which is active prior to adding the first directory, becomes
greyed out and -NEVER- goes back to an active, pushable state.
When I kill serviio (both serviio.sh and serviio-console.sh) and
the restart them, the previously added Library locally directories
are no longer there in the console Library TAB).
When I select Serviio on the Samsung page and then select either the
Audio, Video or Image sub-window, any of the "Presentation" sub-category
names I had set to "Display category" are represented as lower
sub-windows, but clicking on any of them yields the message:
"No stored files found". If any of the sub-categories are marked as
"Display content only", they display nothing - no sub-window.
An interesting note, tvmobili, which is listed on Samsung as a device
also displays the sub-windows: Audio, Video and Image; but, in this
case all of the content is present in lower level windows and all of
it can be displayed/listened-to on the Samsung.
So, how do I configure Serviio so that the Library directories I
enter on in the console actually get saved and used?
Richard
Richard
Post Sat Mar 01, 2014 2:25 am
Re: No stored files found
If one can not store Library setting using Serviio version 1.4, where can I download an earlier version (which has a Samsung F support)
which can store Library settings?
Post Sat Mar 01, 2014 4:34 am
I am running serviio 1.4 and the save button is at the bottom right of the console.
make sure that you can see all the console.
can you post screen shot of the console.
Richard
Post Sat Mar 01, 2014 3:45 pm
SUCCESS
Apparently, the console which is a set of TAB does not determine the
maximum window size required for each TAB and then selects its top-level
window size based upon the largest of those maximums.
Rather, it sizes itself based upon the first TAB. It also does not
provide visual feedback with scroll-bars for those TABs that require
greater area than provide by th current top-level window size.
All that is to say, when I am viewing the Library TAB with the size that
the console used by default, there is NO "Save" button. But, if I then
enlarge the size of the top-level window, behold, there is the "Save"
button.
If you have never used Serviio and do not know that there ought to
be a "Save" button, the fact that you do not see one, is not user
error.
Richard
Post Sat Mar 01, 2014 6:22 pm
What operating system are you running? and what screen resolution.
normanw18
Post Thu Sep 11, 2014 9:40 pm
Hi moltra
I had the extract same problem. Very frustrating until you find out the problem is the 'Save' button you can't see until the window is dragged larger. I am running the Linux OS 3.14.17.1 and the 32 bit Manjaro distro version 0.8.10 with Serviio 1.4.1.2. Screen resolution is 1440 x 900
normanw18
