Xmantium
Post Sat Jan 11, 2014 4:44 pm
Re: PACKAGE: Serviio 1.4 - Synology NAS (ARMv5&v7 Intel QorI
For those wanting a Web UI to manage your Serviio v1.4, download it from here - https://github.com/SwoopX/Web-UI-for-Se ... io-1.4.zip
More info here - http://wiki.serviio.org/doku.php?id=phpwebui
Image Image
Ramses2000
Post Sun Jan 19, 2014 11:24 am
I run this build on XPEnology system, DSM 4.3
The HW is a HP Proliant Gen8 Server.
My problem is that I cannot make the transcoding to work to embed the subtitles, for my Sharp Aquos dumb "SmartTV".
See the problem here.
Ryster
Post Mon Jan 27, 2014 11:03 pm
Hey Patters, I'm thinking of trying the beta of DSM 5.0 on my DS213+ NAS box. Have you had chance to test this yet? I'm informed by the Beta FAQ that new versions of packages would be required.
Let me know please as 5.0 of DSM looks very nice and I'd like to have a play, but don't want to lose Serviio.
http://www.synology.com/en-uk/dsm/dsm5_0_beta
Serviio Pro Purchaser - 24/07/2012
Six
Post Tue Jan 28, 2014 10:32 am
Same here.
Please Patters, let us know, will Serviio work on 5.0 beta?
VoidCutter
Post Sun Feb 02, 2014 4:50 pm
Will probably run after re-installing Java - had the same with the beta version of DSM 4.3 :geek:
But I would still like some confirmation before I try the 5.0 beta... Patters :?:
patters
Post Mon Feb 03, 2014 11:15 am
Yes, I'm running it on DSM 5.0 beta now. The good news is that if you have a 2010 model NAS with a PowerPC CPU, you can now also use Java and Serviio finally :)
VoidCutter
Post Thu Feb 06, 2014 9:39 pm
Thx! Works like a charm! :idea:
Aleste
Post Tue Feb 11, 2014 11:58 am
Regarding ffmpeg thumbnail generation speed. I am stubborn and insisted on thumbnail generation on my Synology DS212j. Generating a thumbnail for a 1920x1080@25i home video takes anywhere from 30 seconds to a couple minutes by default (fast increase depending on the seek parameter).
I found that if you use a less accurate seek in ffmpeg-wrapper.sh you can consistantly speed up the thumbnail generation to about 10 seconds by moving the seek parameter (-ss XX) in front of the input file parameter (-i). As I understand it will then seek on index frames only. It's less accurate and it throws a couple of warnings but it works for me.
default: ffmpeg -threads auto -i <input-file> -an -frames:v -ss <seek> -f image2 <output>
on index: ffmpeg --threads auto -ss <seek> -i <input-file> -an -frames:v -f image2 <output>
I have altered the ffmpeg-wrapper.sh script to move the -ss parameter in front of the -i paremeter. If anyone is interested I can post the changes.
laspo
Post Fri Feb 28, 2014 3:18 pm
Re: PACKAGE: Serviio 1.3.1 - Synology NAS (ARMv5&v7 Intel Qo
patters wrote:No OpenCL then, and apparently no VDPAU support either. Despite the marketing hype about those Intel Atom Evansport SoCs, I doubt there will be any functional transcoding benefit. Very odd that they disabled yasm too. I think Synology will just stick to using the integrated GPU to render media to this NAS's HDMI port. I can't really imagine that the FFmpeg team would spend lots of time and effort optimizing for a single GPU that's in a particular SoC. They haven't for instance added support for QuickSync in the 4th Gen Core i series CPUs.
I suppose the good news is that I don't need to release a whole new compile of FFmpeg. Four architectures for Synology is quite enough!
Can someone with a DS214 (armadaxp) check if my ARMv7 build of FFmpeg can use the two CPU cores? In the Delivery, Transcoding section of Serviio Console can you select 2 cores in the dropdown?
Does this mean that there is no added value of a DS214 Play compared to a DS214 in terms of running a Serviio Server? Or what does it mean exactly? :)
blase
Post Mon Mar 10, 2014 10:02 am
The final version of DSM 5.0 is now available.
ianfretwell
Post Mon Mar 10, 2014 9:44 pm
It is indeed available....and after upgrading to it, my Serviio 1.4 install will no longer run on my DS413J...simply won't start - don't know where I should be looking for error logs etc ? The Java install did come through the upgrade fine and appears to be running fine too.
Any ideas anybody ?
...I should have just read a bit harder above - removing and re-installing Java does indeed fix things....
Morbeas
Post Tue Mar 11, 2014 6:06 pm
I'm in the same boat. Everything went well with my DSM 5 upgrade but the Serviio package simply won't start.
subora
Post Tue Mar 11, 2014 7:15 pm
also waiting for fix...
blase
Post Tue Mar 11, 2014 8:05 pm
Desinstalar java he instalarlo desde la app del propio sysnology.
Disculpar por escribir en español
Enviado desde mi GT-I9300 mediante Tapatalk
subora
Post Wed Mar 12, 2014 6:46 am
sorry yes. just reintstall java from community repositroy for DS413
blase
Post Wed Mar 12, 2014 11:54 am
En el repositorio de Synology viene el "Java Manager"
Ver imagen adjunta "Captura.png"
In the repository Synology comes the "Java Manager"
See attached image "Captura.png"
Six
Post Wed Mar 12, 2014 12:05 pm
I made clean DSM 5 install to my DS213+, then installed Java 7, then Serviio, but the Serviio package won't start.
From log I can see, that Serviio stops on this point:
[IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
Attached also detailed log.
(7.5 KiB) Downloaded 1440 times
gsayer
Post Wed Mar 12, 2014 10:29 pm
Hi Folks,
I had to re-install serviio and java, then it would at least finally run having also upgraded, my new problem is the browser part wont connect.
It says 'sorry the page you are looking for is not found' when I browse to finish the install.
My device is a DS214 Marvell Armada XP 1.07GHz
DSM version DSM 5.0-4458 (having upgraded, then the issue started)
Any advice really appreciated.
edit: I now notice that my DS214 goes to sleep, which indicates that the serviio is indeed not running even though it says that it is.
hreintke
Post Thu Mar 13, 2014 9:48 am
LS,
I have the same issue as above.
Checked the apache logs with following results :
Apache access log
10.0.0.219 - - [13/Mar/2014:10:27:18 +0100] "GET /serviioweb HTTP/1.1" 500 505 "-" "Mozilla/5.0 (Windows NT 6.3; WOW64; rv:27.0) Gecko/20100101 Firefox/27.0"
10.0.0.219 - - [13/Mar/2014:10:27:18 +0100] "GET /favicon.ico HTTP/1.1" 404 505 "-" "Mozilla/5.0 (Windows NT 6.3; WOW64; rv:27.0) Gecko/20100101 Firefox/27.0"
Apache error log
[Thu Mar 13 10:27:18 2014] [alert] [client 10.0.0.219] /var/services/web/serviioweb/.htaccess: Invalid command 'php_value', perhaps misspelled or defined by a module not included in the server configuration
The I renamed the .htaccess file in the web/serviioweb directory an retried.
Then the site showed response but was not showing correct results.
Duplicates removed from the error log shows these results.
[Wed Mar 12 13:52:03 2014] [error] [client 10.0.0.219] FastCGI: server "/php-fpm-handler" stderr: PHP message: PHP Warning:  Invalid argument supplied for foreach() in /volume1/web/serviioweb/lib/serviio.php on line 88, referer: http://10.0.0.201/serviioweb/
[Wed Mar 12 13:52:03 2014] [error] [client 10.0.0.219] FastCGI: server "/php-fpm-handler" stderr: PHP message: PHP Notice:  Undefined index: ip in /volume1/web/serviioweb/view/status.php on line 95, referer: http://10.0.0.201/serviioweb/
[Wed Mar 12 13:52:16 2014] [error] [client 10.0.0.219] FastCGI: server "/php-fpm-handler" stderr: PHP message: PHP Notice:  Undefined variable: maxOnlineFeeds in /volume1/web/serviioweb/view/library.php on line 199, referer: http://10.0.0.201/serviioweb/
[Wed Mar 12 13:52:16 2014] [error] [client 10.0.0.219] FastCGI: server "/php-fpm-handler" stderr: PHP message: PHP Warning:  file_exists(): open_basedir restriction in effect. File(/) is not within the allowed path(s): (/etc:/etc.defaults:/tmp:/usr/bin/php:/usr/syno/synoman:/var/packages/MailStation/target/roundcubemail:/var/run:/var/services/blog:/var/services/homes:/var/services/photo:/var/services/web:/var/spool/php:/volume1/@tmp/php:/volume1/web) in /volume1/web/serviioweb/tree/jquery_folder_tree/jquery.foldertree.php on line 18, referer: http://10.0.0.201/serviioweb/
Herman
red71
Post Thu Mar 13, 2014 12:28 pm
Same problem for me. Upgrading to DSM 5.0-4458 on my DS412+ and Serviio doesn't start. I re-installed JAVA 6 and Serviio but nothings works.
Here my log.
Users browsing this forum: Baidu [Spider] and 17 guests
