Wed Mar 12, 2014 10:29 pm by gsayer
Hi Folks,
I had to re-install serviio and java, then it would at least finally run having also upgraded, my new problem is the browser part wont connect.
It says 'sorry the page you are looking for is not found' when I browse to finish the install.
My device is a DS214 Marvell Armada XP 1.07GHz
DSM version DSM 5.0-4458 (having upgraded, then the issue started)
Any advice really appreciated.
edit: I now notice that my DS214 goes to sleep, which indicates that the serviio is indeed not running even though it says that it is.
- Attachments
- 2014-03-13_082624.png (34.76 KiB) Viewed 39391 times
- 2014-03-12_223521.jpg (265.81 KiB) Viewed 39415 times
