PACKAGE: Serviio 1.5 for QNAP NAS (ARM & x86 Intel)
Post Sat Mar 15, 2014 8:01 pm
Re: PACKAGE: Serviio 1.4 for QNAP NAS (ARM & x86 Intel)
I got myself a 470 Pro, so will try to give the Qnap users some love :-)
As a start, I built static ffmpeg for Intel (based on sources from serviio.org - the same as the Windows / Mac version), try it out here: http://download.serviio.org/temp/qnap/x86/ffmpeg
Xmantium
Post Sat Mar 15, 2014 8:10 pm
What!? This is the best news yet, I'm currently doin my best to maintain the package but my compiling skills are poor. N8ing4le (known as Swoop in this forum) who maintains the web ui helps users make the latest ffmpeg here - http://forum.qnap.com/viewtopic.php?f=252&t=84702, I get the ARM version from csholmq.
Can you build the latest ffmpeg? the QNAP Serviio forum is full of users trying their hand compiling latest ffmpeg from git using Swoops script - https://gist.github.com/SwoopX/5335016# ... _ffmpeg-sh
I'm just waiting for the current beta to finish to release a QPKG. Qnap QPKG development kit can be found here - http://forum.qnap.com/viewtopic.php?f=128&t=36132
You've a good choice in choosing QNAP! :D
Post Sat Mar 15, 2014 11:45 pm
Currently I would rather give the Ffmpeg the other distros are using.
hoping to make it a cidtomizable build job so that I can release a new one without problems. Hopefully I will be able to pick up the whole package atsome point too, but probably only after the new console, which migh t be some time.
in the meantime thanks for the great job
Raptor1966
Post Thu Mar 20, 2014 7:12 pm
hi
i have a 470 and have installed Serviio and am very happy with it and have no issues to speak of.
i bought the pro licence but it will not install. the page on the serviio website showing how to install the licence has a different look than the page on my console.
when i click load new licence and browse to the location where licence is stored, it says new data loaded but it does not update to pro version.
i have restarted NAS
Xmantium
Post Thu Mar 20, 2014 7:27 pm
I'm going to be uploading the latest build of Serviio QPKG very soon, my motherboard on my PC died on me.
Theres three ways to upload the licence (its a .lic file when you buy the Pro licenc)
1: Remote access with windows console
You would simple have to download the new Windows Serviio v1.4.1 from http://www.serviio.org/download
Only install the console, then edit C:\Program Files\Serviio\bin\ServiioConsole.exe.vmoptions with a text editor by adding:
-Dserviio.remoteHost=XXX.XXX.X.XXX
Replacing XXX.XXX.X.XXX with the IP Address your Serviio server
2: Use your Android phone
Use ServiiDroid for Android which is v1.4.1 compatible - https://play.google.com/store/apps/deta ... erviidroid
3: Install the latest unofficial web ui
http://wiki.serviio.org/doku.php?id=phpwebui
Post Thu Mar 20, 2014 8:41 pm
Xmantium
Post Sat Mar 29, 2014 12:21 am
Qnappers im happy to say ive updated both ARM and Intel versions to latest 1.4.1.2. The Intel version the ffmpeg is compiled by Petr Nejedly (zip)
Ive tested it, no more grey thumbnails too, not tested the burned in subtitles though as I never use this feature
Both QPKG have been updated with the latest Web UI
ARM: TS-x10, x12, x19, x20, x21
Serviio 1.4.1.2 Revision 1
x86: TS-x39, x59, x69, x70, x70U, x79
Serviio 1.4.2 Revision 1
Raptor1966
Post Sat Mar 29, 2014 4:59 pm
[quote="Xmantium"]I'm going to be uploading the latest build of Serviio QPKG very soon, my motherboard on my PC died on me.
Thanks, using my Android phone did the trick
Raptor1966
Post Mon Apr 21, 2014 1:50 pm
i have another issue, this time with servii0 not showing m2ts files. i can see it in the browser but not on my blu-ray player steaming from my qnap ts-470
Xmantium
Post Mon Apr 21, 2014 2:14 pm
Post your logs in the support section.
This post is support for anyone installing Serviio on QNAP
kykpeng
Post Sat May 17, 2014 5:42 am
Hello
I have a QNAP TS-220 with 4.0.7 firmware (dated 2014/4/12). I installed JRE directly from QNAP's App Center ("JRE_ARM 7.0.45"). No issue. Doing a command line "java -version" and "env" both show the setup seems ok:
[~] # java -version
java version "1.7.0_45"
Java(TM) SE Embedded Runtime Environment (build 1.7.0_45-b15, headless)
Java HotSpot (TM) Embedded Client VM (build 24.45-b08, mixed mode)
[~] # env
JAVA_HOME=/usr/local/jre
I downloaded
Serviio_1.4.1.2-R1_arm-x19.qpkg
from this forum, tried to install manually inside QNAP's "App Center", and I got the following error:
Serviio 1.4.1.2-R1 installation failed.  The following QPKG must be installed and enabled: JRE >= 6.
What is not working here???
Xmantium
Post Sat May 17, 2014 10:15 pm
Please install Java for ARM the manual method and not from the QNAP's App Centre. This JRE package is renamed wrongly and has been raised.
Followthis guide here - http://advancedhomeserver.com/serviio/
Download Java JRE QPKG installer here - http://forum.qnap.com/viewtopic.php?f=163&t=45963
Download ARMv5 Linux - Headless EABI, SoftFP ABI, Little Endian from here - http://www.oracle.com/technetwork/java/ ... index.html
Dont rename any files and should look like this - http://advancedhomeserver.files.wordpre ... viio08.jpg
This way you also have the latest Java installed.
Then run the JRE QPKG to install Java and finally install Serviio QPKG
wolfymozart
Post Wed May 21, 2014 2:41 pm
Hi, i received a qnap jre update message and i did update it.
Now serviio 1.4 doesn't work anymore (i receive e 404 not found errore when opening serviio from my qnap)
Can you help me, please?
I've a qnap ts-121 and i need to know what's the right jre version i've to install.
Thank you
Xmantium
Post Wed May 21, 2014 2:59 pm
The update is renamed wrong. The manual method works fine. This way it's the latest jre. Follow the previous post - viewtopic.php?f=14&t=5324&p=91520#p91180
wolfymozart
Post Wed May 21, 2014 3:06 pm
Xmantium wrote:The update is renamed wrong. The manual method works fine. This way it's the latest jre. Follow the previous post - viewtopic.php?f=14&t=5324&p=91520#p91180
I've installed JRE version 7 Update 55 by the JRE QPKG installer with the manual method and now serviio does work. In my qnap i can see it as a v6 version, but i think it's only a "number" issue. Is there a way to insall jre v8 by manual method and jre qpkg installer, please?
If i put the v8 file in Public folder, i think it won't install it...will it?
Thank you!
EDIT: after reboot, it doesn't work!! Why???
Xmantium
Post Wed May 21, 2014 5:00 pm
Restart the Serviio QPKG from app centre. I think the start script has issues, so disable and enable from app centre
The package is titled v6, even though you have v7 installed
wolfymozart
Post Wed May 21, 2014 5:24 pm
Xmantium wrote:Restart the Serviio QPKG from app centre. I think the start script has issues, so disable and enable from app centre
It seems to work now. I'll try to reboot. So, does it mean that I cannot install jre update from qnap app center?
Now i've installed jre v7 (titled v6), if I download v8 and change the filename as the v7 one, i can install it manually, but i see the error GUI on the top of the page... Have I to keep the jre v7 installed forever?
Thank you very much!
EDIT: the same issue: after reboot, it doesn't work!! If i install v7 titles v6 with manual method, it works; then i reboot and i get the 404 error... and if i turn off and then on serviio from app center, it's the same! Can you help me please?
I used serviio for months without any matter (but i rember install process was very tricky...)!
IndividualLover
Post Tue Jun 10, 2014 9:21 am
I have a same issue.. :?
Xmantium
Post Mon Jun 16, 2014 7:29 pm
Theres a guide here to install Serviio on QNAPs - http://advancedhomeserver.com/serviio/
Dont install the JRE ARM from the App Centre as its not compatible the way this QPKG is installed
powernap
Post Tue Jun 24, 2014 9:07 am
Most of the links are outdatet and i cant find any download link for jre armv5. Even google does not help me this time. Please help me!
