yanakkis
Post Thu Mar 13, 2014 10:12 pm
Re: PACKAGE: Serviio 1.4 - Synology NAS (ARMv5&v7 Intel QorI
Hi there. After upgrade to DSM 5.0 its not working anymore on DS412+ :(. I uninstalled, resinstalled, tried Java 6, 7 from community packages. nu luck. Serviio appears to be running but I cannot connect to it. Pls help, its the best media server!.
thanks,
gunther
Post Fri Mar 14, 2014 10:15 am
Hi all,
I have exactly the problem, Serviio's status shows 'running' but I cannot connect either from browser or console. Both state: server is not running.
Synology DS 412+ and Serviio 1.4.
Is there any help available?
Kind regards
Gunther
bsandor77
Post Sun Mar 16, 2014 8:45 am
hi there,
I had the same problem with my upgraded DSM 5.0 (DS212j) with Serviio. First I uninstall Serviio and Java too, fresh install didn't help. Then I tried some settings to change but nothing, my last action was to remove the new default shares (e.g. music, photo, ...) and now Serviio is alive, I can manage it via the android app (seviidroid) and I can access it via mediabrowser but the serviio web ui is not working. I'm not sure to remove these shares is the solution but it helps for me.
regards,
sandor
yanakkis
Post Mon Mar 17, 2014 8:10 pm
bsandor77 wrote:hi there,
regards,
sandor
YEP, it worked! Thanks a lot mate!!!
ianfretwell
Post Mon Mar 17, 2014 9:46 pm
Anybody know if we/when patters will be giving us a 1.4.1 release ? The release note states something about a settings change to keep NAS drives from waking up too often - that'd be nice!!
Anyone ?
red71
Post Tue Mar 18, 2014 1:59 am
Worked for me too !
Here what I did:
1) Uninstall Java Embedded and Serviio.
2) Empty shared direcrtories.
3) Re-install Java Embedded and Serviio.
4) Serviio is alive and re-configuring it with ServiiDroid Android app.
patters
Post Wed Mar 19, 2014 1:17 pm
Re: PACKAGE: Serviio 1.4.1.1 - Synology NAS (ARMv5&v7 PPC In
I can confirm that Serviio is fine on DSM 5.0. You just need to remove and reinstall Java first. Make sure you do this before attempting to update Serviio.
1.4.1.1 version is on my package repo now.
red71
Post Wed Mar 19, 2014 4:09 pm
Does Synology cpu INTEL still needs JAVA 6 or may use 7 or 8 ?
cyberdog
Post Wed Mar 19, 2014 8:59 pm
Hello
Work good between Samsung TV F-séries (Samsung Link Player app)
And DS214.
But in Serviio-Console, how to make choice " IOS Profile " for m'y iPad Air ?
Thank You for your Work !!!
:D
Alaska99
Post Thu Mar 20, 2014 12:41 am
I use java 8 and all look working fine on my synology 1512+ .
Synology DS1512+ with DSM 6.0 beta 3gig ram | Blueray Sony BDP-S390 firmware M11.R.0422 | Blueray Sony BDP-BX58 | PS3 with latest firmware | Router Asus RT-AC68U Merlin firmware | Samsung TV UN65HU9000
gsayer
Post Thu Mar 20, 2014 10:50 am
Hi Folks,
I seem to not be able to browse to the console from windows now.I have installed only the console on my pc and put -Dserviio.remoteHost=192.168.1.50 into the ServiioConsole.exe.vmoptions file.
'Sorry, the page you are looking for is not found.'
Installed Java SE Embedded 7 hopefully I am missing something glaringly obvious as at the moment I cannot upload my license into serviio itself. (Edit was able to via my Nexus 7)
Any ideas welcome.
2014-03-20 10:05:04,974 INFO [ServiioConsole] Initializing Serviio Console
2014-03-20 10:05:05,058 INFO [ServiioConsole] Starting Serviio Console
2014-03-20 10:05:05,227 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2014-03-20 10:05:15,466 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2014-03-20 10:05:25,516 WARN [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2014-03-20 10:05:25,528 INFO [Messages] Loaded console message bundle for locale: en
2014-03-20 10:06:33,721 INFO [ServiioConsole] Exitting Serviio Console
2014-03-20 10:21:21,883 INFO [ServiioConsole] Initializing Serviio Console
2014-03-20 10:21:21,967 INFO [ServiioConsole] Starting Serviio Console
2014-03-20 10:21:22,131 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2014-03-20 10:21:32,361 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2014-03-20 10:21:42,394 WARN [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2014-03-20 10:21:42,403 INFO [Messages] Loaded console message bundle for locale: en
2014-03-20 10:28:08,751 INFO [ServiioConsole] Exitting Serviio Console
Morbeas
Post Fri Mar 21, 2014 3:00 pm
So does Java SE Embedded 8 indeed work? I installed it but doesn't look like I can run the Web UI any longer (it just stays blank). I tried adding media from my laptop but that didn't work either. Is this an issue with the Java version or should I try something else?
PS. I have a Synology 1511+
adski
Post Mon Mar 24, 2014 8:11 am
gunther wrote:Hi all,
Kind regards
Gunther
Same issue here.
adski
Post Mon Mar 24, 2014 8:17 am
Just left mine for some time and then tried to access via media browser and was notified that I had to set a password first. Thought that was strange so I opened the console on my PC and noticed that all the settings have been wiped.
patters
Post Tue Mar 25, 2014 11:33 am
Re: PACKAGE: Serviio 1.4.1.2 - Synology NAS (ARMv5&v7 PPC In
Check to see if there's a folder called /volume1/@appstore/pc5dczc_db_migration
If there is then your database is still intact - perhaps you attempted a Serviio upgrade immediately after a DSM upgrade but had not yet re-installed Java.
In this case stop the Serviio package and run the following commands:
rm -r /volume1/@appstore/Serviio/library/db
cp -R /volume1/@appstore/pc5dczc_db_migration/db /volume1/@appstore/Serviio/library
rmdir /volume1/@appstore/pc5dczc_db_migration
chown -R serviio /volume1/@appstore/Serviio/library
Now start Serviio.
bart69
Post Wed Mar 26, 2014 8:48 pm
goodnight or download Serviio 1.4.1.2 package for Synology NAS 214play I not find it? thank you
floppyn
Post Thu Mar 27, 2014 1:11 am
Good day all,
Please help on a strange behaviour of console. Here the env:
installed DSM 5.0 Update 1
Installed Java 8 from Oracle
Installed Serviio 1.4.1.2.0026
Installed Serviio Console 1.4beta-002
Server looks up and running
I start the console but I get the message "Sorry the page you are looking for is not found"
Tried to change the statement in /volume1/web/serviioweb/.htaccess from "php_value magic_quotes_gpc off" to "php_flag magic_quotes_gpc off" but nothing change
Deleting the .htaccess file from /volume1/web/serviioweb the console starts but I am not able to edit the folders in "library" tab: when I press "add local" come up the "add folder" panel with an home icon in the selection field, but I can not perform any operation (i.e. the home does not expand)
Any hint?
Thanks in advance
hreintke
Post Tue Apr 08, 2014 12:38 pm
LS,
Late reply but maybe this will still be of help.
You should add the "add path" button to be able to update the library.
See this thread for the details : viewtopic.php?f=14&t=11427
Herman
floppyn
Post Tue Apr 08, 2014 8:10 pm
Hi Herman,
you pointed out the right solution, now it works as expected.
Thanks very much!!!
Fabrizio
blase
Post Fri May 02, 2014 6:57 pm
Hola a todos
Desde que instale la version DSM 5.0, he notado tanto con la ultima version 7 como con la ultima version 8 de java, que el consumo de RAM es excesivo, llegando casi al 100% en un par de dias de funcionamiento continuo.
No he conseguido que se mantenja en unos niveles medios como en versiones anteriores del DSM.
A alguien mas le ha pasado, se puede solucionar?
Tengo un synology DS213J
Gracias a todos
Hello everyone
Since installing the DSM version 5.0, I've noticed with both the latest version 7 and with the lates version 8 of java, RAM consumption is excessive, reaching almost 100% in a couple of days of continuous operation.
I have not gotten that mantenja in average levels as in previous versions of the DSM.
Anyone else happened, you can fix?
I have a synology DS213J
Thanks to all
