Re: Serviio on a RPi ? (Raspberry Pi)
Sent from my HTC One mini using Tapatalk
Xmantium wrote:Anyone care to make an image file of your SD card contents for Linux noobs?
http://www.raspberrypi.org/phpBB3/viewt ... 26&t=13664
Lame, 8minutes 53seconds:
pi@raspbmc:/tmp$ lame /tmp/bla.wav /tmp/bla.mp3
LAME 3.98.4 32bits (http://www.mp3dev.org/)
Using polyphase lowpass filter, transition band: 16538 Hz - 17071 Hz
Encoding /tmp/bla.wav to /tmp/bla.mp3
Encoding as 44.1 kHz j-stereo MPEG-1 Layer III (11x) 128 kbps qval=3
Frame | CPU time/estim | REAL time/estim | play/CPU | ETA
5763/5764 (100%)| 8:44/ 8:44| 8:53/ 8:53| 0.2871x| 0:00
kbps LR MS % long switch short %
128.0 47.8 52.2 98.1 1.2 0.7
Writing LAME Tag...done
ReplayGain: -4.9d
Shine, 47seconds:
pi@raspbmc:/tmp$ shineenc /tmp/bla.wav /tmp/bla.mp3
shineenc (Liquidsoap version)
WAV PCM DATA, stereo 44100Hz 16bit, Length: 0: 2:30
MPEG-I layer III, stereo Psychoacoustic Model: Shine
Bitrate=128 kbps De-emphasis: none Original
Encoding "/tmp/bla.wav" to "/tmp/bla.mp3"
Finished in 0: 0:47
