Serviio on a RPi ? (Raspberry Pi)
NX3
Post Sat Jan 04, 2014 9:35 am
Re: Serviio on a RPi ? (Raspberry Pi)
Raspberry Pi doesn't have the processing power to burn in subtitles. Do you have transcode enabled? What is your playback device?
Sent from my HTC One mini using Tapatalk
NX3
Post Thu Feb 20, 2014 10:01 pm
Xmantium wrote:Anyone care to make an image file of your SD card contents for Linux noobs?
http://www.raspberrypi.org/phpBB3/viewt ... 26&t=13664
back to this.... as updated wiki for latest build.
I could do it now I guess but Oracle wouldn't allow Java to be distributed, that's a legal problem we don't want.
Xmantium
Post Thu Mar 27, 2014 6:41 am
Ive noticed you dont use Shine as your audio encoder - https://github.com/savonet/shine
More info about this is found here - viewtopic.php?f=7&t=6458
How fast is it? Tests from the gibhub show:
On a Raspberry Pi (ARM, no FPU):
Lame, 8minutes 53seconds:
pi@raspbmc:/tmp$ lame /tmp/bla.wav /tmp/bla.mp3
LAME 3.98.4 32bits (http://www.mp3dev.org/)
Using polyphase lowpass filter, transition band: 16538 Hz - 17071 Hz
Encoding /tmp/bla.wav to /tmp/bla.mp3
Encoding as 44.1 kHz j-stereo MPEG-1 Layer III (11x) 128 kbps qval=3
Frame | CPU time/estim | REAL time/estim | play/CPU | ETA
5763/5764 (100%)| 8:44/ 8:44| 8:53/ 8:53| 0.2871x| 0:00
kbps LR MS % long switch short %
128.0 47.8 52.2 98.1 1.2 0.7
Writing LAME Tag...done
ReplayGain: -4.9d
Shine, 47seconds:
pi@raspbmc:/tmp$ shineenc /tmp/bla.wav /tmp/bla.mp3
shineenc (Liquidsoap version)
WAV PCM DATA, stereo 44100Hz 16bit, Length: 0: 2:30
MPEG-I layer III, stereo Psychoacoustic Model: Shine
Bitrate=128 kbps De-emphasis: none Original
Encoding "/tmp/bla.wav" to "/tmp/bla.mp3"
Finished in 0: 0:47
The difference is quite remarkable!!
NX3
Post Fri Mar 28, 2014 7:10 pm
Impressive, I'd have transcoding off though on a Pi as its not really up to it other than on audio.
Xmantium
Post Fri Mar 28, 2014 10:01 pm
Where files are remuxed (video untouched, audio transcoded), the RPi encoded with Shine should handle this when transcoding is on.
This way there will be more compatible files viewed (example .mkv videos for Bravia and PS3)
My plans for Serviio on RPi has been abandoned as i wanted a low cost running hardware to run Serviio 24/7
Opted for QNAP TS-121 - http://www.qnap.com/i/en/product/model.php?II=103, theres a cheaper TS-120
Costs £100 more than RPi but gives alot more grunt - 2Ghz ARM chip, alot more RAM to run Serviio smoothly and looks alot cooler!
Very low running costs - Only downside it doesnt do Video transcoding but with Shine encoder, remuxing is a breeze!
NX3
Post Sat Mar 29, 2014 7:56 am
I've got two RPi setup for family remuxing for Sony ok. I've not got benchmarks and agree Shine could help some situations but it works ok as is ...
I went self build, ITX Atom mobo £50, cheap case, stick of mem, 2tb HDD and Ubuntu. I liked the look of several NAS but ARM based didn't have the cpu grunt I needed and atom based NAS are so expensive for what you get v self build
laster13
Post Tue May 13, 2014 6:42 pm
I set up Serviio on RPI B version from wiki.
Java works, serviio also, i compiled ffmpeg.. it seems That it works. I manage everything from servidroid. The mp3 and jpeg files are recognized on the serviio folder. But the videos, .avi, are not recognized. I don't see them on serviigo neither on tv, even after several set up. Is there someone who could help me ?
Thanks in advance.
PS : sorry for my english but I'm french
NX3
Post Tue May 13, 2014 6:51 pm
Glad the guide worked for you [SMILING FACE WITH OPEN MOUTH] avi should work, do for RPi I've setup. What tv do you have? Did you compile your own ffmpeg? Ps good English!
laster13
Post Tue May 13, 2014 8:52 pm
I compiled ffmpeg with your tuto (3 hours)..what's i want to say..when i actualise in servidroid, the mp3 is OK, JPEG OK but avi or mkv not. in serviigo (for Android) i can hear music ans see JPEG but i don t see files video.
Thanks for jour answer.
laster13
Post Thu May 15, 2014 7:00 pm
just a question.. can you see and read your video via serviiogo in local and ethernet on your android.. is it possible?
thanks
laster13
Post Sat May 17, 2014 9:09 pm
Nobody?
Envoyé de mon Nexus 5 en utilisant Tapatalk
NX3
Post Sun May 18, 2014 7:40 am
Avi on ServiioGo working fine for me even on android.
NX3
Ps I'm connected over WiFi on my phone and tablet
mmarvin
Post Mon Feb 08, 2016 8:23 pm
What version of java are you using? It's safe update to 8u73?
I'm using Raspberry Pi 2 with Java 8u65.
Samsung UN46D5500 | Samsung UN40H5103 | Denon AVR-X3000 | Mobile: Android and iPhone
Serviio running on Raspiberry Pi 2
Previous
Users browsing this forum: Baidu [Spider] and 2 guests
