OS X Mavericks, Java 8, Future...
eyeprotocol
Post Wed Apr 02, 2014 3:18 pm
Hello. I am a licensed user of Serviio that just found out that Serviio will not run on Mavericks, using Oracle's Java 8. Will this configuration be supported in the very near future? If not, i will have to search for another media server. Please assist.
eyeprotocol
Post Wed Apr 02, 2014 10:24 pm
Re: OS X Mavericks, Java 8, Future...
Goodbye.
Post Sat Apr 05, 2014 11:51 pm
What doesn't work exactly? java 8 should not be a problem.
z_h
Post Mon Apr 07, 2014 7:37 pm
zip wrote:What doesn't work exactly? java 8 should not be a problem.
Really ? You don't know what is not working in serviio and mavericks ?
viewtopic.php?f=5&t=14289
viewtopic.php?f=5&t=14223
Post Tue Apr 08, 2014 12:35 pm
That's not related to Java 8
z_h
Post Wed Apr 09, 2014 2:43 pm
Its related to what ?
Serviio can't be used with OSX Mavericks...
See the links i posted before.
drcolossus11
Post Wed Apr 09, 2014 10:37 pm
I have Mavericks and have no problem running Serviio, so the issues you are having are not Mavericks specific.
z_h
Post Thu Apr 10, 2014 12:58 pm
drcolossus11 wrote:I have Mavericks and have no problem running Serviio, so the issues you are having are not Mavericks specific.
Does the Serviio 1.4.1.2 icon hyde in the Dock after Serviio starts (like it should) or it stays there ?
Post Thu Apr 10, 2014 6:24 pm
It should not hide currently, because OSX thinks it's a an app with UI. That's why it's sometimes stuck, I guess. I'm planning to change that for 1.5, so that there is adaemon for the server and app for the console.
z_h
Post Thu Apr 10, 2014 7:07 pm
Ok, thanks (a lot !) for the info. I will wait for the 1.5.
