OS X Mavericks, Java 8, Future...
• Page 1 of 1
Hello. I am a licensed user of Serviio that just found out that Serviio will not run on Mavericks, using Oracle's Java 8. Will this configuration be supported in the very near future? If not, i will have to search for another media server. Please assist.
Re: OS X Mavericks, Java 8, Future...
What doesn't work exactly? java 8 should not be a problem.
Petr
Help translate Serviio
zip wrote:What doesn't work exactly? java 8 should not be a problem.
Really ? You don't know what is not working in serviio and mavericks ?
viewtopic.php?f=5&t=14289
viewtopic.php?f=5&t=14223
That's not related to Java 8
Petr
Its related to what ?
Serviio can't be used with OSX Mavericks...
See the links i posted before.
I have Mavericks and have no problem running Serviio, so the issues you are having are not Mavericks specific.
drcolossus11 wrote:I have Mavericks and have no problem running Serviio, so the issues you are having are not Mavericks specific.
Does the Serviio 1.4.1.2 icon hyde in the Dock after Serviio starts (like it should) or it stays there ?
It should not hide currently, because OSX thinks it's a an app with UI. That's why it's sometimes stuck, I guess. I'm planning to change that for 1.5, so that there is adaemon for the server and app for the console.
Petr
Ok, thanks (a lot !) for the info. I will wait for the 1.5.
• Page 1 of 1
Users browsing this forum: No registered users and 67 guests
