mike4001
Post Sat Apr 05, 2014 12:18 pm
Glad to hear :)
PS: Donate Key is already bought - hope this helps a little bit :)
NX3
Post Sat Apr 05, 2014 4:52 pm
will wrote:
Yes it works over the internet (tested a few days ago while visiting family). You browse your server as normal and then send the video url + metadata to the Chromecast, which then makes the connection to Serviio, so you can even turn your phone off without affecting playback.
Excellent news, this makes ServiioGo with Serviio a far better solution than Plex. Plex transcodes more than it needs too so needs a faster cpu . Plex could be so good but imo they get the hard bits right but easy stuff wrong still.
Sent from my HTC One mini using Tapatalk
spudy12
Post Tue Apr 08, 2014 11:13 am
I have a Chromecast!
How do I go about testing with Serviio?
Post Wed Apr 09, 2014 7:02 am
spudy12 wrote:I have a Chromecast!
Its not quite ready yet, mainly because I've just not had the time needed to work on it properly. I'm going to try to do a limited beta at the weekend to active forum users, and then a full beta the weekend after.
mike4001
Post Wed Apr 09, 2014 7:20 am
Would be appreciated.
My Chromecast arrives tomorrow :)
Pleblo
Post Thu Apr 10, 2014 3:04 pm
Will,
Looking forward to the chromecast testing. Easter weekend ill be able to do testing remotely from my parents house if you have the beta out by then. Should be able to help with any bugs from there.
Thanks,
Jim
Post Thu Apr 17, 2014 4:59 pm
I've just uploaded a new beta to Google Play, no Chromecast support yet due to lack of time, but there are a number of other changes that had to be made for it which need testing (Google Play Services in particular) as well as lots of bug fixes from Beta 1 that I had already done. As a bonus for those of you that use SeriesGuide to manage your TV shows, you can now quickly navigate back between the two apps, very useful for marking something as viewed, or finding what to watch next and then opening it in ServiiGo. Going from ServiiGo -> SeriesGuide requires the donate version, as I have to look up the show's tvdb id.
==== 4.0 Beta 2 ====
*Requires Android 2.3.3+ and Google Play Services (GPS) 4.3+
*Added integration with SeriesGuide (requires SeriesGuide 13 and Android 3.0+)
**Act as a SeriesGuide extension to link from SeriesGuide's episode view to ServiiGo
**Added an action item to view an episodes/series in SeriesGuide from ServiiGo (Donate version only)
*New inline mini player for controlling the Music Player
*Not having an available connection no longer stops data being loaded from the response cache
*Failing to download the current track in the Music Player no longer shuts down the Music Player
*Improved image loading in the Image Viewer
*Fixed a load of minor bugs
*Replaced standalone AdMob SDK with AdMob from GPS
*Replaced standalone Analytics SDK with Analytics from GPS
*Added ButterKnife
*Added Otto
And a small update for the production stream:
==== 3.3.2 ====
*Fixed crash when trying to play a video on some Samsung devices running Android 4.3
*Various minor bug fixes
Post Fri Apr 18, 2014 8:13 am
Just uploaded a revised 4.0 Beta 2 which fixes crash on Android 2.3
mike4001
Post Fri Apr 18, 2014 10:10 pm
Thanks for the update, everything works fine for me.
Small request: I would like an option to close the music player in the notification center. Just a small X on the top right or so. Otherwise the only possibility to close it I found was to tip on the music bar at the bottom of the app and then under settings, close it.
I also tried switching off wlan while watching a video (to simulate me leaving wlan range), then my phone went to 3G but the video stopped. If this is just not possible that the app continues loading via 3G while steaming the video it´s not a big deal. Just wanted to test and let you know :)
Post Sat Apr 19, 2014 8:13 am
mike4001 wrote:Small request: I would like an option to close the music player in the notification center. Just a small X on the top right or so. Otherwise the only possibility to close it I found was to tip on the music bar at the bottom of the app and then under settings, close it.
I've added a ticket on bitbucket for that.
No unfortunately its not possible, the media library releases everything if the connection is interrupted.
spudy12
Post Sat Apr 19, 2014 2:02 pm
EDIT: sorry for the triple post, not sure what happened there!
spudy12
Post Sat Apr 19, 2014 2:03 pm
I don't know if I just haven't noticed before or its due to the latest update, but in the thumbnail view, the thumbnails seem to be lower quality? Ie I click on movies and get the front cover thumbnail, seems to be more blurry than usual
spudy12
Post Sat Apr 19, 2014 2:35 pm
spudy12 wrote:I don't know if I just haven't noticed before or its due to the latest update, but in the thumbnail view, the thumbnails seem to be lower quality? Ie I click on movies and get the front cover thumbnail, seems to be more blurry than usual
Nothing should have changed in Beta 2. Is it only for movies, for all videos, or for everything, and is it only in the list of items, or also in the details view?
You could try clearing the image caches, restarting the app, view the video details, and then checking the images under /sdcard/ServiiGo/ThumbnailCache. They should be upto 320x320.
Post Sat Apr 19, 2014 3:59 pm
I have an experimental preview of Chromecast support ready, send me an email (or a PM with your email address) if you are interested in helping with testing.
Tobias
Post Sun Jun 01, 2014 7:18 am
Hi
this is some awesome things.
Post Sun Jun 15, 2014 8:41 am
Hi All, I've just released 4.0 Beta 3 to Google Play. This one is mostly internal fixes and work for Serviio 1.5.
==== 4.0 Beta 3 ====
*Improved intial connection speed by re-using authentication tokens on Serviio 1.4.1+ (#77)
*Preperations for Serviio 1.5
*Fixed current track title not updating in the Music Player
*Fixed display of artist and albums that contain '-'
*Fixed lots of minor issues
*Updated Google Play Services to 4.4
*Updated Picasso to 2.3
*Updated ButterKnfire to 5.1
*Updated PhotoView to 1.2.3
4.0 is already a massive update, and I'm not going to have time to get Chromecast support nicely polished for a while now, so I'm going to release 4.0 soonish, and then work on Chromecast support for the next version.
Post Sat Jun 21, 2014 8:49 am
I've just uploaded 4.0 to Google Play, and as it has been going for so long I had kind of forgotten how much has changed! Also thanks again to all of the testers!
So here is a quick summary
==== 4.0 (Summary) ====
*Improved performance, reconnects faster, caches more data, and resumes at the last used folder
*Improved UI, updated App icon, themes tweaks, new action icons
*Improved loading and error screens
*Improved Image Viewer
*Experimental Google TV support
*Uses AppCompat on legacy devices
*Lots of bug fixes and improvements
And for those who are interested, a more complete (although not absolute) changelog.
==== 4.0 ====
*Improved resume support by automatically re-connecting and browsing to the last used folder
*Updated App icon and Themes
*Updated action icons including XXHDPI assets
*Share images from the Image Viewer
*Show low res thumbnails during load in the Image Viewer  (#85)
*Changed image loading implementation to use Picasso
*Improved error messages for network related issues
*Force the screen to stay on in the Video Player
*Added support for playing back non-mp3 files natively (requires profile change to be activated)
*Improved performance of Music Player widget and notification updates
*Nicer large style Music Player widget (now requires Android 3.0+)
*Fixed the Music Player widgets controls on Android 4.4+
*Changed the ActionBar implementation for legacy devices from ActionBarSherlock to AppCompat
*Added a Changelog on startup for beta testers (#75)
*Various minor bug fixes and improvements
*Added Google Play Services 4.4
*Added ButterKnife
*Added Otto
*Added Picasso
*Updated PhotoView
Compared to the last beta, there are a few minor bugfixes, and I've also removed the requirement for Google Play Services, so although I do not officially support it, you should be able to sideload the app on non-google devices.
Sayte
Post Mon Jun 23, 2014 1:08 pm
How do you play an image slideshow? The changelog talks about there being an image slideshow feature but all I can find is the image viewer. You can manually swipe from one image to the next but there does not appear to be an automatic slideshow option. Am I missing something? There is no 'play' button, the only menu option is 'set as wallpaper' and the settings menu does not have any 'slideshow delay: ## seconds' kind of entry.
Post Mon Jun 23, 2014 7:02 pm
Sayte wrote:How do you play an image slideshow? The changelog talks about there being an image slideshow feature but all I can find is the image viewer. You can manually swipe from one image to the next but there does not appear to be an automatic slideshow option. Am I missing something? There is no 'play' button, the only menu option is 'set as wallpaper' and the settings menu does not have any 'slideshow delay: ## seconds' kind of entry.
The slideshow feature hasn't actually been implemented yet. Some of the old changelogs mentioned an image slideshow as the viewer itself which was confusing which is why anything recent just talks about an image viewer.
There isn't really a reason that it cannot been done, there just hasn't been any interest from users, but I'll bump it up the priority list as its about time I got round to doing it.
Users browsing this forum: Baidu [Spider] and 2 guests
