PS: Donate Key is already bought - hope this helps a little bit
will wrote:
Yes it works over the internet (tested a few days ago while visiting family). You browse your server as normal and then send the video url + metadata to the Chromecast, which then makes the connection to Serviio, so you can even turn your phone off without affecting playback.
spudy12 wrote:I have a Chromecast!
How do I go about testing with Serviio?
==== 4.0 Beta 2 ====
*Requires Android 2.3.3+ and Google Play Services (GPS) 4.3+
*Added integration with SeriesGuide (requires SeriesGuide 13 and Android 3.0+)
**Act as a SeriesGuide extension to link from SeriesGuide's episode view to ServiiGo
**Added an action item to view an episodes/series in SeriesGuide from ServiiGo (Donate version only)
*New inline mini player for controlling the Music Player
*Not having an available connection no longer stops data being loaded from the response cache
*Failing to download the current track in the Music Player no longer shuts down the Music Player
*Improved image loading in the Image Viewer
*Fixed a load of minor bugs
*Replaced standalone AdMob SDK with AdMob from GPS
*Replaced standalone Analytics SDK with Analytics from GPS
*Added ButterKnife
*Added Otto
mike4001 wrote:Small request: I would like an option to close the music player in the notification center. Just a small X on the top right or so. Otherwise the only possibility to close it I found was to tip on the music bar at the bottom of the app and then under settings, close it.
I also tried switching off wlan while watching a video (to simulate me leaving wlan range), then my phone went to 3G but the video stopped. If this is just not possible that the app continues loading via 3G while steaming the video it´s not a big deal. Just wanted to test and let you know
spudy12 wrote:I don't know if I just haven't noticed before or its due to the latest update, but in the thumbnail view, the thumbnails seem to be lower quality? Ie I click on movies and get the front cover thumbnail, seems to be more blurry than usual
==== 4.0 Beta 3 ====
*Improved intial connection speed by re-using authentication tokens on Serviio 1.4.1+ (#77)
*Preperations for Serviio 1.5
*Fixed current track title not updating in the Music Player
*Fixed display of artist and albums that contain '-'
*Fixed lots of minor issues
*Updated Google Play Services to 4.4
*Updated Picasso to 2.3
*Updated ButterKnfire to 5.1
*Updated PhotoView to 1.2.3
==== 4.0 (Summary) ====
*Improved performance, reconnects faster, caches more data, and resumes at the last used folder
*Improved UI, updated App icon, themes tweaks, new action icons
*Improved loading and error screens
*Improved Image Viewer
*Experimental Google TV support
*Uses AppCompat on legacy devices
*Lots of bug fixes and improvements
==== 4.0 ====
*Improved resume support by automatically re-connecting and browsing to the last used folder
*Updated App icon and Themes
*Updated action icons including XXHDPI assets
*Share images from the Image Viewer
*Show low res thumbnails during load in the Image Viewer (#85)
*Changed image loading implementation to use Picasso
*Improved error messages for network related issues
*Force the screen to stay on in the Video Player
*Added support for playing back non-mp3 files natively (requires profile change to be activated)
*Improved performance of Music Player widget and notification updates
*Nicer large style Music Player widget (now requires Android 3.0+)
*Fixed the Music Player widgets controls on Android 4.4+
*Changed the ActionBar implementation for legacy devices from ActionBarSherlock to AppCompat
*Added a Changelog on startup for beta testers (#75)
*Various minor bug fixes and improvements
*Added Google Play Services 4.4
*Added ButterKnife
*Added Otto
*Added Picasso
*Updated PhotoView
Sayte wrote:How do you play an image slideshow? The changelog talks about there being an image slideshow feature but all I can find is the image viewer. You can manually swipe from one image to the next but there does not appear to be an automatic slideshow option. Am I missing something? There is no 'play' button, the only menu option is 'set as wallpaper' and the settings menu does not have any 'slideshow delay: ## seconds' kind of entry.
