Convert Profile to use with Serviio
File is attached.
This is all related to this topic:
viewtopic.php?f=5&t=16461&p=90185#p90185
http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM;DLNA.ORG_OP=11;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM;DLNA.ORG_OP=11;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM;DLNA.ORG_OP=11;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM;DLNA.ORG_OP=11;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_OP=11;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_OP=11;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_OP=11;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T;DLNA.ORG_OP=11;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_OP=11;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU;DLNA.ORG_OP=11;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T;DLNA.ORG_OP=11;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_OP=11;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_FULL;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_PRO;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:audio/wav:DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:application/ogg:DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_OP=11;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/avi:DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/x-ms-asf:DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:image/bmp:DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:image/png:DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000<Profile id="HPmedia" name="HP MediaSmart Connect" extendsProfileId="1">
<!-- HP MediaSmart Connect -->
<Detection>
<UPnPSearch>
<FriendlyName>HP MediaSmart Connect</FriendlyName>
<Manufacturer>Hewlett-Packard</Manufacturer>
</UPnPSearch>
</Detection>
<MediaFormatProfiles>
<!-- rename native WMA formats to those supported by the device -->
<MediaFormatProfile mime-type="audio/x-ms-wma" name="WMABASE">WMA_BASE</MediaFormatProfile>
<MediaFormatProfile mime-type="audio/x-ms-wma" name="WMAFULL">WMA_FULL</MediaFormatProfile>
</MediaFormatProfiles>
<!--For WLAN system mp3 target could be used -->
<!--Audio targetContainer="mp3" aBitrate="192" aSamplerate="44100" -->
<Matches container="mp4" />
<Matches container="flv" />
<Matches container="asf" />
<Matches container="rtp" />
<Matches container="rtsp" />
<Matches container="wavpack" />
<Matches container="mpc" />
<Matches container="ape" />
<Matches container="ogg" />
</Audio>
</Profile>Return to Serviio Support & Help
Users browsing this forum: Baidu [Spider] and 29 guests
