Convert Profile to use with Serviio
DaFerociousBeast
Post Sat Apr 19, 2014 2:25 pm
If you can help me create a profile for my device, I'd really appreciate it.
File is attached.
This is all related to this topic:
viewtopic.php?f=5&t=16461&p=90185#p90185
HPMediaSmart.txt
(5.58 KiB) Downloaded 509 times
DaFerociousBeast
Post Sat Apr 26, 2014 2:58 pm
Re: Convert Profile to use with Serviio
Nobody?
Anything?
Post Sat Apr 26, 2014 6:16 pm
According to mezzmo profile, all formats are transcoded to mpeg. Similar to "DirecTV HD-DVR" profile with serviio (you can try it).
Could you provide format supported by your device using Intel Spy Tool ? see my signature link
DaFerociousBeast
Post Sun Apr 27, 2014 4:11 pm
Here's The UPnP Info.
I actually have transcoding off in Mezzmo, but maybe it just has to know that Serviio supports it's DLNA protocol.
Thanks in advance.
GetProtocolInfo (Loopback Address 127.0.0.1).txt
(11.26 KiB) Downloaded 442 times
GetProtocolInfo.txt
(3.94 KiB) Downloaded 443 times
DLNA Test Certificate.pdf
(166.47 KiB) Downloaded 443 times
Post Sun Apr 27, 2014 6:56 pm
According to GetProtocolInfo result, these following formats ares supported by your MediaSmart Connect product (KC816AA)
http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM;DLNA.ORG_OP=11;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM;DLNA.ORG_OP=11;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM;DLNA.ORG_OP=11;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM;DLNA.ORG_OP=11;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_OP=11;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_OP=11;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_OP=11;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T;DLNA.ORG_OP=11;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_OP=11;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU;DLNA.ORG_OP=11;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T;DLNA.ORG_OP=11;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_OP=11;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_FULL;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_PRO;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:audio/wav:DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:application/ogg:DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_OP=11;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/avi:DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:video/x-ms-asf:DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:image/bmp:DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000,
http-get:*:image/png:DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=9C100000000000000000000000000000
The best format for transcoding is : MPEG_TS_SD_NA mpegts/mpegvideo/ac3
1/ Could you provide device description.xml (INTEL Spy tool) of your device?
2/ First start with "Generic Profile", check with your file library format that are supported natively by your device.
3/ Post format that are not supported (for example mkv seems not supported)
DaFerociousBeast
Post Mon Apr 28, 2014 12:56 am
LVV2QGSY.xml
(3.07 KiB) Downloaded 608 times
Device Spy, right clicked device, get device xml, this is what I got.
ds_ce_x280n.pdf
(318.33 KiB) Downloaded 498 times
This is the formats the device supports from the HP Support page.
Not sure what you want in steps 2 & 3?
If I use generic profile in Serviio or Mezzmo, I get a "not authorized" error on the device. If I use the "HP Media Smart" profile which is included in Mezzmo, Mezzmo connects and works.
Mezzmo is able to connect/communicate with the HP MediaSmart Connect, through something in the profile, because the generic doesn't connect.
Post Mon Apr 28, 2014 8:53 am
Could you edit your ./serviio/config/profiles/xml file and add the following just before the last </Profiles> element :
<Profile id="HPmedia" name="HP MediaSmart Connect" extendsProfileId="1">
      <!-- HP MediaSmart Connect -->
      <Detection>
         <UPnPSearch>
            <FriendlyName>HP MediaSmart Connect</FriendlyName>
            <Manufacturer>Hewlett-Packard</Manufacturer>
         </UPnPSearch>
      </Detection>
      <MediaFormatProfiles>
         <!-- rename native WMA formats to those supported by the device -->
         <MediaFormatProfile mime-type="audio/x-ms-wma" name="WMABASE">WMA_BASE</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/x-ms-wma" name="WMAFULL">WMA_FULL</MediaFormatProfile>
      </MediaFormatProfiles>
         <!--For WLAN system mp3 target could be used -->
         <!--Audio targetContainer="mp3" aBitrate="192" aSamplerate="44100" -->
            <Matches container="mp4" />
            <Matches container="flv" />
            <Matches container="asf" />
            <Matches container="rtp" />
            <Matches container="rtsp" />
            <Matches container="wavpack" />
            <Matches container="mpc" />
            <Matches container="ape" />
            <Matches container="ogg" />
         </Audio>
Restart serviio services or reboot your PC.
Check on serviio console (device list) that the "HP MediaSmart Connect" profile is automatically selected.
Try to play some popular file format :
mpeg, avi, mp4, mkv
DaFerociousBeast
Post Tue Apr 29, 2014 2:10 am
I will give it a try tomorrow.
Yard work...plus have extenders in use right now too.
Thanks for your help, I'll post my results tomorrow.
DaFerociousBeast
Post Wed Apr 30, 2014 12:07 am
PC that Serviio is on shows as HP MediaSmart Connect too.PNG (46.96 KiB) Viewed 9823 times
Ok, Serviio sees HP MediaSmart Connect and assigns profile, but still getting "Not Authorized To Browse Server" when trying to access Serviio from device.
Here's something weird, Serviio also sees My PC as a HP MediaSmart Connect.
I'm assuming...that Loopback is doing something that doesn't agree with Serviio, possible causing the Access error on the MediaSmart Connect.
I know you can bound the server IP in Serviio, is there a way to bound the DLNA device IP in the profile. All my devices are assigned IP's through DHCP Reservations.
DaFerociousBeast
Post Thu May 01, 2014 11:14 pm
Anything else to try?
DaFerociousBeast
Post Thu May 01, 2014 11:32 pm
Looks like someone else had the same problem and just gave up.
viewtopic.php?f=13&t=10741&start=20
DaFerociousBeast
Post Sat May 10, 2014 1:13 am
Way beyond my knowledge, and problem shouldn't be occurring.
Thanks to any who tried.
I give up!!
Users browsing this forum: Baidu [Spider] and 29 guests
