Bravia 2014 not playing sound on TS
mrico78
Post Mon Sep 22, 2014 8:01 pm
I have a BRAVIA KDL-50W828B, and I'm trying to play a live stream.
Taking a look at the logs I found this:
2014-09-22 21:38:52,382 DEBUG [ServiioHttpService] Incoming request from /192.168.1.19:48585: GET /resource/1000000010001342/MEDIA_ITEM/AVC_TS_MP_HD_MPEG1_L3_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-50W828B";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-50W828B"; mv="1.7";,Host: 192.168.1.137:8895]]
So I added this line to the Sony Bravia (2013) profile:
<MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_HD_MPEG1_L3_ISO</MediaFormatProfile>
Now, I'm able to see the video, but I can't play the audio. I've tried a few things in the profile.xml file, but to no result.
The codec in the stream is this:
MPEG Audio Layer 1/2/3(mpga)
Does anyone know if it's posiible to play the audio in this stream on my Bravia.
Thanks in advance
mrico78
Post Mon Sep 22, 2014 8:04 pm
Re: Bravia 2014 not playing sound on TS
A few more lines of the blog, in case it helps:
2014-09-22 21:38:52,382 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.19
2014-09-22 21:38:52,385 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.19
2014-09-22 21:38:52,387 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.19, Profile=Sony Bravia TV (2013)'
2014-09-22 21:38:52,387 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000010001342 and type 'MEDIA_ITEM' received
2014-09-22 21:38:52,387 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000010001342 (online)
2014-09-22 21:38:52,389 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000010001342, format AVC_TS_MP_HD_MPEG1_L3_ISO and profile Sony Bravia TV (2013)
2014-09-22 21:38:52,390 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000010001342 (online)
2014-09-22 21:38:52,392 DEBUG [VideoDeliveryEngine] Delivering item '1000000010001342' for client 'Identifier=192.168.1.19, Profile=Sony Bravia TV (2013)'
2014-09-22 21:38:52,393 DEBUG [VideoDeliveryEngine] Delivering file 'http://127.0.0.1:8902/tv.ts' in native format
2014-09-22 21:38:52,394 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2014-09-22 21:38:52,394 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Content-Length: 50000000000,Date: Mon, 22 Sep 2014 19:38:52 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=8D500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-09-22 21:38:52,395 DEBUG [OnlineInputStream] Reading 1512000 bytes starting at 0
2014-09-22 21:38:52,404 DEBUG [OnlineInputStream] Byte range not supported for http://127.0.0.1:8902/tv.ts, returning the whole stream
Post Tue Sep 23, 2014 3:03 pm
Could you provide detailed information about your file format not supported (see signature links, ffmpeg -i and MediaInfo tools result) ?
BRAVIA KDL-50W828B
Supported Codec for DLNA / USB device :
http://pdf.crse.com/manuals/14HE468111/ ... st.html#10
MPEG1L3 : not supported, should be transcoded probably.
mrico78
Post Tue Sep 23, 2014 4:55 pm
Here it is:
ffmpeg -i:
[mpegts @ 018BE840] max_analyze_duration 5000000 reached at 5015467 microseconds
Input #0, mpegts, from 'http://127.0.0.1:8902/tv.ts':
  Duration: N/A, start: 31677.332733, bitrate: 96 kb/s
  Program 1
    Stream #0:0[0x58]: Audio: mp3 ([3][0][0][0] / 0x0003), 44100 Hz, stereo, s16p, 96 kb/s
    Stream #0:1[0x59]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc
Mediainfo:
I couldn't get any information since I'm dealing with a stream, and Mediainfo seems to work only with files.
And this are the supported formats of my Bravia:
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,
http-get:*:audio/L16:DLNA.ORG_PN=LPCM;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3_T;SONY.COM_PN=AVC_TS_HD_60_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_50_AC3_T;SONY.COM_PN=AVC_TS_HD_50_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3;SONY.COM_PN=AVC_TS_HD_60_AC3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_50_AC3;SONY.COM_PN=AVC_TS_HD_50_AC3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_60_AC3_ISO;SONY.COM_PN=AVC_TS_HD_60_AC3_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_50_AC3_ISO;SONY.COM_PN=AVC_TS_HD_50_AC3_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_EU_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_EU;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_EU_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_KO_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_JP_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_MPEG1_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_60_L2_T;SONY.COM_PN=HD2_60_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_50_L2_T;SONY.COM_PN=HD2_50_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_MPEG1_L2_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_60_L2_ISO;SONY.COM_PN=HD2_60_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_50_L2_ISO;SONY.COM_PN=HD2_50_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_60_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_50_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_JP_MPEG1_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_MPEG1_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_60_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_50_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_MPEG1_L2_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG1;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_FULL;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPLL_BASE;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPML_BASE;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/x-ms-asf:DLNA.ORG_PN=VC1_ASF_AP_L1_WMA;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/x-ms-asf:DLNA.ORG_PN=VC1_ASF_AP_L2_WMA;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_AC3_T;SONY.COM_PN=AVC_TS_HD_24_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_AC3;SONY.COM_PN=AVC_TS_HD_24_AC3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;SONY.COM_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_JP_AAC_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/x-mp2t-mphl-188:*,
http-get:*:image/jpeg:*,
http-get:*:audio/mpeg:*,
http-get:*:audio/L16:*,
http-get:*:audio/x-ms-wma:*,
http-get:*:audio/mp4:*,
http-get:*:audio/x-m4a:*,
http-get:*:video/mpeg:*,
http-get:*:video/vnd.dlna.mpeg-tts:*,
http-get:*:video/mp4:*,
http-get:*:video/x-msvideo:*,
http-get:*:video/avi:*,
http-get:*:video/x-ms-wmv:*,
http-get:*:video/x-ms-asf:*,
http-get:*:video/3gpp:*,
http-get:*:video/3gpp2:*,
http-get:*:audio/3gpp:*,
http-get:*:audio/3gpp2:*,
http-get:*:video/x-mkv:*,
http-get:*:video/x-matroska:*,
http-get:*:video/webm:*,
http-get:*:video/quicktime:*,
http-get:*:video/x-avi:*,
http-get:*:video/x-xvid:*,
http-get:*:application/x-mpegURL:*,
http-get:*:application/vnd.apple.mpegURL:*
Post Wed Sep 24, 2014 4:13 pm
Try to edit the ./serviio/config/profiles.xml file on "id=sony2013" section
Add this line
<Matches container="mpegts" vCodec="h264" aCodec="mp3" />
after the third <video:
<Video targetContainer="mpegts" targetACodec="ac3" forceInheritance="true">
like this
         <!-- Remux all other h264 video to MPEG-TS stream with ac3 audio transcoding -->
         <!-- Remux all other matroska/mpeg2video to MPEG-TS stream with ac3 audio transcoding -->
You have to restart serviio service (not server) after profiles.xml modification (or reboot pc).
Enable transcoding on serviio console.
Check on log that your file will be transcoded...
mrico78
Post Wed Sep 24, 2014 8:53 pm
Well, I've made a couple of tests:
Playing the stream from my TV, it seems to start, but the creen goes to black. In the log I can see this:
2014-09-24 22:31:10,922 DEBUG [ServiioHttpService] Incoming request from /192.168.1.19:48826: GET /resource/1000000010001612/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-50W828B";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-50W828B"; mv="1.7";,Host: 192.168.1.137:8895]]
2014-09-24 22:31:10,922 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.19
2014-09-24 22:31:10,922 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.19, Profile=Sony Bravia TV (2013)'
2014-09-24 22:31:10,922 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000010001612 and type 'MEDIA_ITEM' received
2014-09-24 22:31:10,932 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000010001612 (online)
2014-09-24 22:31:10,932 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2014-09-24 22:31:10,932 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000010001612, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2013)
2014-09-24 22:31:10,932 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file http://127.0.0.1:8902/tv.ts
2014-09-24 22:31:10,932 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://127.0.0.1:8902/tv.ts: AVC_TS_MP_HD_AC3_ISO
2014-09-24 22:31:10,932 DEBUG [VideoDeliveryEngine] Delivering item '1000000010001612' for client 'Identifier=192.168.1.19, Profile=Sony Bravia TV (2013)'
2014-09-24 22:31:10,932 DEBUG [VideoDeliveryEngine] Delivering file 'http://127.0.0.1:8902/tv.ts' using transcoding
2014-09-24 22:31:10,932 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.19, Profile=Sony Bravia TV (2013)'
2014-09-24 22:31:11,952 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://127.0.0.1:8902/tv.ts: AVC_TS_MP_HD_AC3_ISO
2014-09-24 22:31:11,952 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2014-09-24 22:31:11,952 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2014-09-24 22:31:11,952 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Date: Wed, 24 Sep 2014 20:31:11 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-09-24 22:31:15,302 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.218:52389s
Second test.
Using a dlna client in my android called 'MediaHouse' I try to play the stream from serviio to the TV. It says "failed to play: -1", and in the log there is this:
2014-09-24 22:35:14,926 DEBUG [ServiioHttpService] Incoming request from /192.168.1.19:48924: GET /resource/1000000010001431/MEDIA_ITEM/AVC_TS_MP_HD_MPEG1_L3_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-50W828B";,X-AV-Client-Info: av="5.0"; cn="Sony Corporation"; mn="BRAVIA KDL-50W828B"; mv="1.7";,Host: 192.168.1.137:8895]]
2014-09-24 22:35:14,926 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.19
2014-09-24 22:35:14,928 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.19
2014-09-24 22:35:14,929 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.19, Profile=Sony Bravia TV (2013)'
2014-09-24 22:35:14,929 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000010001431 and type 'MEDIA_ITEM' received
2014-09-24 22:35:14,930 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000010001431 (online)
2014-09-24 22:35:14,930 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2014-09-24 22:35:14,931 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000010001431, format AVC_TS_MP_HD_MPEG1_L3_ISO and profile Sony Bravia TV (2013)
2014-09-24 22:35:14,933 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file http://127.0.0.1:8902/tv.ts
2014-09-24 22:35:14,934 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://127.0.0.1:8902/tv.ts: AVC_TS_MP_HD_AC3_ISO
2014-09-24 22:35:14,934 WARN  [ResourceDeliveryProcessor] Invalid request, sending back 500 error
org.serviio.dlna.UnsupportedDLNAMediaFileFormatException: No media description available for required version: AVC_TS_MP_HD_MPEG1_L3_ISO
   at org.serviio.delivery.resource.AbstractDeliveryEngine.findMediaInfoForFileProfile(AbstractDeliveryEngine.java:292)
   at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedMediaInfoForVersion(AbstractTranscodingDeliveryEngine.java:158)
   at org.serviio.delivery.resource.AbstractDeliveryEngine.getMediaInfoForMediaItem(AbstractDeliveryEngine.java:124)
   at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResourceInfo(MediaResourceRetrievalStrategy.java:181)
   at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:80)
   at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:86)
   at org.serviio.upnp.webserver.ServiioHttpService.doService(ServiioHttpService.java:77)
   at org.serviio.upnp.webserver.WebServer$WorkerThread.run(WebServer.java:196)
2014-09-24 22:35:15,456 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.218:52389s
2014-09-24 22:35:18,669 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.218:52389s
In both cases it seems to be transcoding, but in any case I can see anything in my TV.
Any ideas??
Post Thu Sep 25, 2014 6:11 am
if your file was transcoded, you can find it on temporary folder (see serviio console for folder path).
Could you retry with modified profile and copy the temp file?
Post transcoded file information.
Whats happen if you add the transcoded file to librery (it should be delivered in native format)?
Post Thu Sep 25, 2014 7:36 am
Could you edit the profiles.xml 2013 section like this ?
Set "xx_50_xx" mime-type in first position on "name" list
      <MediaFormatProfiles>
         <!-- Rename native WMA formats to those supported by the tv -->
         <MediaFormatProfile mime-type="audio/x-ms-wma" name="WMABASE">WMA_BASE</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/x-ms-wma" name="WMAFULL">WMA_FULL</MediaFormatProfile>
         <!-- Rename 3gp profiles that can be played as AVC -->
         <MediaFormatProfile mime-type="video/mp4" name="AVC_MP4_MP_SD_AAC_MULT5">AVC_3GPP_BL_QCIF15_AAC</MediaFormatProfile>
         <!-- Rename native avi formats to those supported by the tv -->
         <MediaFormatProfile mime-type="video/avi" name="">AVI</MediaFormatProfile>
         <!-- Rename native mpeg2ts with h264+ac3/aac formats to those supported by the tv (aac support is not advertised by the renderer but it works) -->
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3,AVC_TS_HD_24_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_HD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3,AVC_TS_HD_24_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_SD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3,AVC_TS_HD_24_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_HD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3,AVC_TS_HD_24_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_SD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T,AVC_TS_HD_24_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T,AVC_TS_HD_24_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T,AVC_TS_HD_24_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_HP_HD_MPEG1_L2_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T,AVC_TS_HD_24_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_HP_SD_MPEG1_L2_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T,AVC_TS_HD_24_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_HD_AAC_MULT5_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T,AVC_TS_HD_24_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_AAC_MULT5_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T,AVC_TS_HD_24_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T,AVC_TS_HD_24_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_MPEG1_L3_T</MediaFormatProfile>
         <!-- Rename transcoded mpeg2ts with h264 to one of the TV's supported profiles -->
         <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_HP_HD_MPEG1_L2_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_HP_SD_MPEG1_L2_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_HD_AAC_MULT5_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_SD_AAC_MULT5_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_SD_MPEG1_L3_ISO</MediaFormatProfile>
      </MediaFormatProfiles>
mrico78
Post Thu Sep 25, 2014 8:20 pm
YESSSSSSS!!!! It worked!!
Thanks Illico!
Post Fri Sep 26, 2014 12:32 pm
mrico78 wrote:YESSSSSSS!!!! It worked!!
Thanks Illico!
OK Nice.
Do you implement the both modifications or only the mime-type modification ?
Btw: could you try only the mime-type modification ?
Test 1/
<MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_HD_MPEG1_L3_ISO</MediaFormatProfile>
Test 2/
viewtopic.php?f=11&t=17634&p=94562#p94549
mrico78
Post Sat Sep 27, 2014 3:05 pm
I tried only the mime-type modification.
I look for the transcoded file, but I didnt't find it in the "Transcoded files location" folder.
Regarding to the last test:
It didn't work. Only video was delivered to the TV, not audio.
Post Sat Sep 27, 2014 3:29 pm
Ok, ticket opened for next release: https://bitbucket.org/xnejp03/serviio/i ... pport-2014
kissmydrone
Post Thu Nov 20, 2014 6:42 pm
Hi, I'm having the same problem and (probably) i have done sth wrong (modified the profiles.xml badly) ... Could you please tell me how to do that properly ?
Also sometimes after opening twitch vidoes i get the message (translated so may be a bit different) No server access. Check your server settings. And sometimes it opens but its a black screen all the time.
Post Thu Nov 20, 2014 7:38 pm
Edit profiles.xml, replace 2013 profile by following lines, then restart serviio service (not server) or reboot PC to reload profiles.
   <Profile id="sony2013" name="Sony Bravia TV (2013/2014)" extendsProfileId="1">
      <!-- this is WIP, should be included in the inheritance tree if possible -->
      <!-- 2013/2014 models
             Codec list supported 2013 : http://pdf.crse.com/manuals/13MW802111/FR/codeclist.html#5
             Codec list supported 2014 : http://pdf.crse.com/manuals/14HE468111/FR/codeclist.html#10
             - Still images: JPEG (*.jpg / *.jpe / *.jpeg), MPO (*.mpo), RAW (*.arw)
             - Music: LPCM, MP1L1 / MP1L2 / MP1L3 / MP2L1 / MP2L2 / MP2L3 / MP2.5L3 (*.mp3), AAC-LC / HE-AAC v1/v2 (*.mp4 / *.m4a / *.3gp / *.3g2), WMA9 (*.wma)
             - Video: MPEG1 / MPEG2PS / AVCHD , MP4, Xvid, Motion JPEG, VC1, MKV, 3gpp, MOV, WebM
      <Detection>
         <UPnPSearch>
            <FriendlyName>BRAVIA (KDL-\d{2}W[56789]\d{2}[AB].)|(KD-\d{2}X[89]\d{3}[AB].)</FriendlyName>
         </UPnPSearch>
      </Detection>
      <DeviceDescription>
         <!-- act as WMP so that the TV doesn't show root categories -->
         <ModelName>Windows Media Player Sharing</ModelName>
         <ModelNumber>3.0</ModelNumber>
         <Manufacturer>Microsoft Corporation</Manufacturer>
      </DeviceDescription>
      <ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.SonyDLNAMessageBuilder</ContentDirectoryMessageBuilder>
      <ContentDirectoryDefinitionFilter>org.serviio.upnp.service.contentdirectory.definition.WMPContentDirectoryDefinitionFilter</ContentDirectoryDefinitionFilter>
      <H264LevelCheck>FILE_ATTRIBUTES</H264LevelCheck>
         <!-- Transcode all h264 video with HIGH/MAIN > Level 4.2 on MPEG-TS stream with MPEG2VIDEO and ac3 audio transcoding -->
         <!-- expected profile MPEG_TS_SD_EU/MPEG_TS_SD_NA/MPEG_TS_SD_KO -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" DAR="16:9" forceInheritance="true">
            <Matches container="*" vCodec="h264" profile="high_10" />
            <Matches container="*" vCodec="h264" profile="high_444" />
            <Matches container="*" vCodec="h264" profile="high_422" />
            <Matches container="*" vCodec="h264" profile="high" levelGreaterThan="4.2" />
            <Matches container="*" vCodec="h264" profile="main" levelGreaterThan="4.2" />
         <!-- Remux containers with h264 video + AC3 audio to MPEG-TS stream without transcoding -->
         <!-- Remux matroska/mpeg2video + AC3 audio to MPEG-TS stream without transcoding -->
         <Video targetContainer="mpegts" forceInheritance="true">
            <Matches container="avi" vCodec="h264" aCodec="ac3" />
            <Matches container="flv" vCodec="h264" aCodec="ac3" />
            <Matches container="wtv" vCodec="h264" aCodec="ac3" />
            <Matches container="matroska" vCodec="mpeg2video" aCodec="ac3" />
            <Matches container="*" vCodec="h264" aCodec="truehd" />
            <Matches container="*" vCodec="h264" aCodec="flac" />
            <Matches container="wtv" vCodec="h264" />
         <!-- All Others video/audio codec will be transcoded into mpeg2ts, mpeg2video and ac3 audio -->
            <Matches container="mpegts" vCodec="vc1" />
            <Matches container="flv" />
            <!-- example: flv/vp6/mp3 -->
            <Matches container="wtv" />
            <Matches container="ogg" />
            <Matches container="rm" />
            <!--Matches container="3gp" vCodec="mpeg4" /-->
            <!--Matches container="3gp" vCodec="h263" /-->
            <!-- digital camera video formats -->
            <Matches container="asf" vCodec="vc1" aCodec="wmapro" />
            <Matches container="mp4" vCodec="dvvideo" />
         <Audio targetContainer="lpcm" forceInheritance="true">
            <Matches container="rtp" />
            <Matches container="rtsp" />
            <Matches container="flac" />
            <Matches container="adts" />
         </Audio>
      <HardSubsTranscoding>
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" DAR="16:9" />
      </HardSubsTranscoding>
Users browsing this forum: Baidu [Spider] and 3 guests
