Twitch.tv/Justin.tv
jules
Post Thu Sep 25, 2014 10:08 pm
Re: Twitch.tv/Justin.tv
you could let us have a look at a detailed log for starters. make sure to overwrite the ffmpeg.exe from the post linked from OP again.
Cryo426
Post Fri Sep 26, 2014 5:17 pm
Hello i have the same issue, i checked the detailed log and copy pasted the relevant info
2014-09-26 19:38:27,317 WARN [FeedUpdaterThread] An error occured while parsing the online resource http://www.twitch.tv/basetradetv, will try again soon: Unexpected error while invoking plugin (twitch.tv): Server returned HTTP response code: 403 for URL: http://usher.justin.tv/find/basetradetv ... scription=
org.serviio.library.online.metadata.OnlineResourceParseException: Unexpected error while invoking plugin (twitch.tv): Server returned HTTP response code: 403 for URL: http://usher.justin.tv/find/basetradetv ... scription=
at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:78)
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:181)
at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:198)
at org.serviio.library.online.metadata.FeedUpdaterThread.getOnlineItems(FeedUpdaterThread.java:185)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:108)
Caused by: java.io.IOException: Server returned HTTP response code: 403 for URL: http://usher.justin.tv/find/basetradetv ... scription=
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.configuredInputStream(DefaultGroovyMethods.java:16692)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.newReader(DefaultGroovyMethods.java:16760)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.getText(DefaultGroovyMethods.java:15130)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.getText(DefaultGroovyMethods.java:15102)
at org.codehaus.groovy.runtime.dgm$375.doMethodInvoke(Unknown Source)
at org.codehaus.groovy.reflection.GeneratedMetaMethod$Proxy.doMethodInvoke(GeneratedMetaMethod.java:70)
at groovy.lang.MetaClassImpl$GetBeanMethodMetaProperty.getProperty(MetaClassImpl.java:3465)
at org.codehaus.groovy.runtime.callsite.GetEffectivePojoPropertySite.getProperty(GetEffectivePojoPropertySite.java:61)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callGetProperty(AbstractCallSite.java:227)
at Twitch.extractItems(twitch.groovy:70)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:32)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:29)
at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
jules
Post Fri Sep 26, 2014 6:39 pm
that's a very old version, try the one from the OP.
Noobie123
Post Sat Sep 27, 2014 2:10 am
Ok so, I can see the twitch files within the folder, each file for the different quality. When I open any of them, the screen is just black. Local files work fine.
log:
2014-09-27 14:06:42,922 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.2.8, Profile=Sony Bravia TV (2013)'
2014-09-27 14:06:43,533 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2014-09-27 14:06:43,533 DEBUG [TimeoutStreamDelegator] Scheduling stream stop to happen in 20 seconds if there is no traffic
2014-09-27 14:06:43,922 DEBUG [StreamBasedTranscodingDeliveryStrategy] Transcoded stream is empty, connection may have been lost
2014-09-27 14:06:43,922 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://video22.lax01.hls.twitch.tv/hls2 ... 95ee6e6e88: AVC_TS_MP_HD_AC3_ISO
2014-09-27 14:06:43,922 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2014-09-27 14:06:43,922 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2014-09-27 14:06:43,923 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Accept-Ranges: none,Date: Sat, 27 Sep 2014 02:06:43 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-09-27 14:06:49,600 DEBUG [ServiioHttpService] Incoming request from /192.168.2.8:38176: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40W600B";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40W600B"; mv="1.7";,Host: 192.168.2.3:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 276,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"]]
2014-09-27 14:06:49,600 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.8
2014-09-27 14:06:49,600 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.2.8
2014-09-27 14:06:49,601 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.8
2014-09-27 14:06:49,896 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2014-09-27 14:07:00,710 DEBUG [SearchManager] Committing search index
2014-09-27 14:07:01,616 DEBUG [WebServer] I/O error: Connection reset
2014-09-27 14:07:27,501 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2014-09-27 14:07:27,501 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2014-09-27 14:07:27,502 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 8)
2014-09-27 14:07:27,502 DEBUG [SearchIndexer] Adding term 'tsm_theoddone-hls [Source/2416K]' to search index
2014-09-27 14:07:27,503 DEBUG [SearchIndexer] Adding term 'Oddone' to search index
2014-09-27 14:07:27,504 DEBUG [SearchIndexer] Adding term 'tsm_theoddone-hls [High/1718K]' to search index
2014-09-27 14:07:27,506 DEBUG [SearchIndexer] Adding term 'Oddone' to search index
2014-09-27 14:07:27,507 DEBUG [SearchIndexer] Adding term 'tsm_theoddone-hls [Medium/906K]' to search index
2014-09-27 14:07:27,508 DEBUG [SearchIndexer] Adding term 'Oddone' to search index
2014-09-27 14:07:27,509 DEBUG [SearchIndexer] Adding term 'tsm_theoddone-hls [Low/582K]' to search index
2014-09-27 14:07:27,510 DEBUG [SearchIndexer] Adding term 'Oddone' to search index
2014-09-27 14:07:27,512 DEBUG [SearchIndexer] Adding term 'tsm_theoddone-hls [Mobile/160K]' to search index
2014-09-27 14:07:27,513 DEBUG [SearchIndexer] Adding term 'Oddone' to search index
2014-09-27 14:07:30,712 DEBUG [SearchManager] Committing search index
the log is quite big im not sure how much to show. does that help at all?
jules
Post Sat Sep 27, 2014 2:27 pm
that log doesn't say much, just that it seems to extract the urls fine. the problem may be rooted in your transcoding settings or profile, and lacking a tv of that series, i can't help you to set that up. do you have an alternative device like a phone/tablet with a upnp capable video player to try this out on?
andreyv
Post Sat Sep 27, 2014 2:40 pm
BTW, I use a Sony Bravia TV with the "Sony Bravia 2013" profile, and twitch.tv streams work fine without transcoding.
Noobie123
Post Wed Oct 01, 2014 12:13 pm
I have tried all profiles with transcoding on and off. I tried using VLC as you said but it just crashes whenever i try...
The files are visible but just a black screen when i open them. Local files work fine :\
jules
Post Wed Oct 01, 2014 2:26 pm
i think vlc's upnp support may be broken in the 2.x versions... try a 1.x version
Noobie123
Post Thu Oct 02, 2014 12:34 pm
Ok, tested on VLC on my mobile and it works perfectly.
So whats wrong with my TV! It is a KDL-40W600B model (Serviio sees the device name) and is a 2013 series. When selecting the "Sony Bravia TV(2013)" profile, I can connect, view, and play local files. I can view the Twitch files but they don't actually play (they open but simply black screen & no audio - no errors in the log or anything obvious pertaining to this).
Is it a problem with the plugins interaction with this model or perhaps the TV renderer? Shouldn't transcoding fix rendering issues?
jules
Post Thu Oct 02, 2014 1:51 pm
in all likelihood, it shouldn't need transcoding anyway because most modern tvs handle h264 and mp3/aac just fine. you could post an entire debug log for this process:
1. turn on serviio
2. hit force refresh in serviio console/library/online
3. wait a minute or so until this has been processed
4. try to view the stream from your tv
the earlier log didn't show any problems. you can just go through the log and remove all lines containing a ".mkv", or private data, if you don't want to post those parts.
Noobie123
Post Fri Oct 03, 2014 4:50 am
Ok, log should show everything from starting the server, through the process you mentioned, and stopping it. I don't know if there is any "private" data :S
Thanks for your help Jules!
(440.43 KiB) Downloaded 1580 times
shelby_
Post Fri Oct 03, 2014 10:59 am
Hello Jules,
first of all thanks for your time and support of your great plugin, which I'm unfortunately having a little problem with. I only found it on a sidenote in this thread.
I'm running a twitch stream on the ps3 and the audio is fine, but the video stops for about two seconds, then it's super fast forward a second. Rinse and repeat. This does occur on all quality settings.
This am having absolutely no problems using the serviio stream in highest quality in VLC.
Log: http://pastebin.com/8p3hha3e
The oddone stream is not what i am streaming, i guess it's just offline. I'm streaming riotgames.
Any idea?
jules
Post Sat Oct 04, 2014 12:48 am
Noobie123 wrote:Ok, log should show everything from starting the server, through the process you mentioned, and stopping it. I don't know if there is any "private" data :S
that really doesn't show any issues. i'm afraid that i unfortunately know too little about transcoding because all of my players play everything (except FLAC) fine. i suggest you take a look at config/profiles.xml which governs what formats are being transcoded for which devices, and try to figure out how to force h264 into being transcoded. it's possible that twitch's august encoding change is producing video streams that are incompatible with your tv's media player's understanding of what an h264 stream is supposed to look like.
i'm sorry, but i can't think of any other way of attacking your issue.
shelby_ wrote:Hello Jules,
Any idea?
i think multiple people have mentioned that in the past, and iirc it was usually in context with PS3s. (un?)fortunately i don't have one and thus can't provide you with any insight, but it seems like the media player is choking on something in the video data. this doesn't occur for local data, i suppose? might be the same issue as above, now that i think of it...
shelby_
Post Sat Oct 04, 2014 7:53 am
jules wrote: it seems like the media player is choking on something in the video data. this doesn't occur for local data, i suppose?
Yep. Local data works fine. The youtube plugin works fine, too. Haven't tested any other.
I'd be happy if i could contribute to the solution to this by providing any log data or anything...
Btw i'm using that modified ffmpeg.exe (26mb), because any other wouldn't even show the streams to choose from. Maybe we need an updated modified build?
jules
Post Sat Oct 04, 2014 10:32 am
first thing to try is to force transcoding, because possibly the ps3's media player doesn't like the verbatim stream coming from twitch. i don't think at this point that a modified ffmpeg will help anything (besides the changes necessary to even run streams that you already have).
hiccups1980
Post Mon Oct 13, 2014 6:35 pm
Hey guys,
I have a Sony KDL-40W605B and Serviio 1.4.1.2
Tried with transcoding and without it. Tried it with all the ffmpeg files but could not get it to work.
He finds the streams but I get a blackscreen.
Here is my log:
2014-10-13 20:42:47,749 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2014-10-13 20:42:47,749 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2014-10-13 20:42:47,749 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2014-10-13 20:42:47,749 INFO  [WebServer] WebServer shutting down
2014-10-13 20:42:47,749 INFO  [EventDispatcher] Leaving EventDispatcher
2014-10-13 20:42:50,153 INFO  [WebServer] WebServer starting on port 8895
2014-10-13 20:42:50,184 INFO  [Device] Updated bound IP address of Device with UUID: 92364609-eb74-3e48-a97f-fb1c988d0a03, bound address: 192.168.1.3
2014-10-13 20:42:50,184 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2014-10-13 20:42:50,184 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2014-10-13 20:42:50,184 INFO  [EventDispatcher] Starting EventDispatcher
2014-10-13 20:42:50,218 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.1.3, timeout = 0
2014-10-13 20:42:50,218 INFO  [RendererSearchSender] Searching for Renderer devices
2014-10-13 20:43:11,529 WARN  [ProcessExecutor] Process cmd has a return code of 1! This is a possible error. Detailed output follows.
Stream #0:1 -> #0:0 (copy)
Stream #0:0 -> #0:1 (aac -> ac3)
[mpegts @ 07F241A0] H.264 bitstream malformed, no startcode found, use the h264_mp4toannexb bitstream filter (-bsf h264_mp4toannexb)
av_interleaved_write_frame(): Invalid argument
2014-10-13 20:43:24,649 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2014-10-13 20:43:24,649 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2014-10-13 20:43:24,649 INFO  [EventDispatcher] Leaving EventDispatcher
2014-10-13 20:43:24,649 INFO  [WebServer] WebServer shutting down
2014-10-13 20:43:24,649 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2014-10-13 20:43:52,933 INFO  [WebServer] WebServer starting on port 8895
2014-10-13 20:43:52,965 INFO  [Device] Updated bound IP address of Device with UUID: 92364609-eb74-3e48-a97f-fb1c988d0a03, bound address: 192.168.1.3
2014-10-13 20:43:52,965 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2014-10-13 20:43:52,965 INFO  [EventDispatcher] Starting EventDispatcher
2014-10-13 20:43:52,965 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2014-10-13 20:43:52,999 INFO  [RendererSearchSender] Searching for Renderer devices
2014-10-13 20:43:52,999 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address
jules
Post Mon Oct 13, 2014 8:21 pm
first item in the list of instructions in the original post is your answer
hiccups1980
Post Mon Oct 13, 2014 8:50 pm
I'm using the 64 bit ffmpeg.exe Blackscreen. :(
jules
Post Mon Oct 13, 2014 9:37 pm
i have to ask: are you absolutely 100% certain that you've put it in the correct place? like, were you asked whether you wanted to overwrite the older version?
hiccups1980
Post Mon Oct 13, 2014 9:59 pm
Yes 100% sure. :)
\Program Files\Serviio\lib\ffmpeg.exe
Return to Available plugins
