Tracks (2013) showing as Tracks (1977)
danman45
Post Sat Oct 25, 2014 11:31 pm
Hi
I added the movie 'Tracks (2013) about a month ago with no issue. It showed the correct metadata.
Recently it has changed to the 1977 version of the movie featuring Dennis Hopper.
I've tried a few things with no success. Deleted file & re-added it, moved it to another drive, re-named it as 'Tracks' I've ensured the that file name is as the movie db.
I've had a similar problem before & think there could be a problem with the API.
Just wondering if you could please shed some light.
Post Sun Oct 26, 2014 7:06 pm
Re: Tracks (2013) showing as Tracks (1977)
You can name the folder or file name to include the year in brackets.
danman45
Post Mon Oct 27, 2014 9:34 pm
Thanks Zip but I do that to all my files. They all have the year in brackets.
Trying it without the year was an option I tried to see if it would correct itself.
Post Mon Oct 27, 2014 11:49 pm
danman45 wrote:Thanks Zip but I do that to all my files. They all have the year in brackets.
I had one (and only one) file that would not get its data correctly. What finally worked was to make a folder just for that file with the full name, then name the file with the year. The movie was Cherry 2000, and I had to name the file itself Cherry (1987).mpg. I did not include the year in the file name. This was the only way it grabbed the correct metadata.
No other file made me work so hard. :)
danman45
Post Wed Oct 29, 2014 4:57 am
Hi atc98092
I've tried changing the folder to 'Tracks' & the file to Tracks (2013) & that didn't work.
Also tried changing the folder to Tracks (2013) & file to 'Tracks' that still didn't work
Tried also changing the folder to Tracks & file to Tracks (1977) & that also didn't work and folder to Tracks (1977) & file to Tracks.
None of these options seem to be working. Am I doing it incorrectly?
Cheers
Post Fri Oct 31, 2014 9:45 am
I suspect the year field in themoviedb database is wrong - it works if you rename the file as "Tracks (2014)" despite themoviedb clearly labelling it as a 2013 movie :?
danman45
Post Fri Oct 31, 2014 11:23 am
Thanks Denyall
That sure worked. Thanks for that. Your an absolute legend
