[SOLVED] Files only showing up for some players
Post Mon Nov 17, 2014 12:00 am
I have some video files that doesn't appear on every player. It is visible and playable with MediaBroswer and on my Roku boxes. It appears on my Panasonic but won't play, and my Samsung TV or BD player or Sony BD player doesn't even show it. MediaInfo is below for two of the files.
It's not being a M2TS file, as others show up and play. I don't think it's the HD audio, because again I have both MKV and M2TS files with both Dolby TrueHD and DTS Master Audio, which plays on the Samsung BD player with no issue and full bitstream audio. Thast said, TrueHD is the constant between the two files below.
On 2nd thought, maybe it is the TrueHD. I just checked all my M2TS files and they all have DTS, not Dolby HD audio, except for a couple that I tried with FLAC. Humm.
Complete name                            : W:\Logan's Run (1976).m2ts
Format                                   : BDAV
Format/Info                              : Blu-ray Video
File size                                : 20.4 GiB
Duration                                 : 1h 58mn
Overall bit rate                         : 24.7 Mbps
Maximum Overall bit rate                 : 48.0 Mbps
Menu ID                                  : 1 (0x1)
Format                                   : VC-1
Format profile                           : Advanced@L3
Codec ID                                 : 234
Duration                                 : 1h 58mn
Bit rate                                 : 21.8 Mbps
Height                                   : 1 080 pixels
Bits/(Pixel*Frame)                       : 0.439
Stream size                              : 18.1 GiB (88%)
Audio #1
Menu ID                                  : 1 (0x1)
Format                                   : TrueHD / AC-3
Muxing mode                              : Stream extension
Codec ID                                 : 131
Duration                                 : 1h 58mn
Bit rate mode                            : Variable / Constant
Bit rate                                 : 640 Kbps
Maximum bit rate                         : 3 168 Kbps
Stream size                              : 543 MiB (3%)
Audio #2
Menu ID                                  : 1 (0x1)
Codec ID                                 : 129
Duration                                 : 1h 58mn
Bit rate                                 : 192 Kbps
Channel(s)                               : 1 channel
Channel positions                        : Front: C
Stream size                              : 163 MiB (1%)
Audio #3
Menu ID                                  : 1 (0x1)
Codec ID                                 : 129
Duration                                 : 1h 58mn
Bit rate                                 : 192 Kbps
Audio #4
Menu ID                                  : 1 (0x1)
Codec ID                                 : 129
Duration                                 : 1h 58mn
Bit rate                                 : 640 Kbps
Audio #5
Menu ID                                  : 1 (0x1)
Codec ID                                 : 129
Duration                                 : 1h 58mn
Bit rate                                 : 192 Kbps
Text #1
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Text #2
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Duration                                 : 1h 58mn
Delay relative to video                  : 12s 679ms
Text #3
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Duration                                 : 1h 58mn
Text #4
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Delay relative to video                  : 12s 262ms
Text #5
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Duration                                 : 1h 58mn
Delay relative to video                  : 12s 721ms
Text #6
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Duration                                 : 1h 58mn
Text #7
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Duration                                 : 1h 58mn
Complete name                            : X:\Star Trek II The Wrath of Khan (1982).m2ts
Format                                   : BDAV
File size                                : 32.8 GiB
Duration                                 : 1h 53mn
Overall bit rate                         : 41.5 Mbps
Menu ID                                  : 1 (0x1)
Codec ID                                 : 27
Duration                                 : 1h 53mn
Bit rate                                 : 38.3 Mbps
Maximum bit rate                         : 36.0 Mbps
Bits/(Pixel*Frame)                       : 0.770
Stream size                              : 30.2 GiB (92%)
Audio #1
Menu ID                                  : 1 (0x1)
Codec ID                                 : 131
Duration                                 : 1h 53mn
Bit rate                                 : 640 Kbps
Maximum bit rate                         : 7 029 Kbps
Channel(s)                               : 8 channels / 6 channels
Channel positions                        : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Delay relative to video                  : -144ms
Stream size                              : 517 MiB (2%)
Audio #2
Menu ID                                  : 1 (0x1)
Format profile                           : Dolby Digital
Codec ID                                 : 129
Duration                                 : 1h 53mn
Bit rate                                 : 224 Kbps
Stream size                              : 181 MiB (1%)
Audio #3
Menu ID                                  : 1 (0x1)
Codec ID                                 : 129
Duration                                 : 1h 53mn
Bit rate                                 : 224 Kbps
Audio #4
Menu ID                                  : 1 (0x1)
Codec ID                                 : 129
Duration                                 : 1h 53mn
Bit rate                                 : 224 Kbps
Audio #5
Menu ID                                  : 1 (0x1)
Codec ID                                 : 129
Duration                                 : 1h 53mn
Bit rate                                 : 224 Kbps
Text #1
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Text #2
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Text #3
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Text #4
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Text #5
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Text #6
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Text #7
Menu ID                                  : 1 (0x1)
Format                                   : PGS
Codec ID                                 : 144
Post Mon Nov 17, 2014 12:32 am
Re: Files only showing up for some players
Check the profile, it is possibly missing transcoding rule for this combination. It should probably transcode vc1 to mpeg2 and truehd to ac3.
Post Mon Nov 17, 2014 2:18 am
zip wrote:Check the profile, it is possibly missing transcoding rule for this combination. It should probably transcode vc1 to mpeg2 and truehd to ac3.
I think it might just be the audio. It plays the same files except with DTS Master Audio without transcoding. The profile I'm using right now only transcodes wtv containers, so I'll add a line to change audio to AC3. That's ok, right? I can change the audio without touching the video?
Post Mon Nov 17, 2014 1:38 pm
Yep, it was the TrueHD audio. Apparently it won't play in a M2TS container, but will in a MKV container. By transcoding the audio to AC3, they now appear as expected. Bummer, since I was using M2TS because that allows selecting captions. With MKV, the player recognizes there are captions but doesn't actually display them. As an M2TS file, my guess is the player treats it as an actual BD disc.
Guess I'll switch them back to MKV, so I don't have the overhead of transcoding.
Post Tue Nov 18, 2014 12:42 pm
Re: [SOLVED] Files only showing up for some players
The player might support it, but I assume the codec / container combination is not a valid DLNA profile (or not one implemented by Serviio yet). So Serviio doesn't serve it.
For MKV - it's always served as until recently MKV was not even a DLNA supported format but generally accepted by some players.
Users browsing this forum: No registered users and 64 guests
