Mkv and m4v support and longer buffering
freaknik
Post Sat Dec 13, 2014 12:39 pm
Hey, how can I get Serviio to see mkv files and m4v files?
It says unknown format in the log.
Updating ffmpeg fixed it for everything but these two for me.
Also, my server is on wireless so it would be helpful to change the buffer so videos don't stutter when playing.
Thanks in advance.
Post Sun Dec 14, 2014 12:50 am
Re: Mkv and m4v support and longer buffering
Serviio can stream MKV and M4V just fine. There's nothing wrong there.
Remember that MKV and M4V are just containers. The error is telling you that Serviio can't figure out the codec (video or audio) within the container. We need the file information using either MediaInfo or by running ffmpeg -I {file name}.
Serviio doesn't buffer the video, your player does. What you are encountering is insufficient bandwidth. There are two remedies for this: hard wire Serviio and the player to the network (difficult to impossible for some locations), or reduce the video bitrate that Serviio sends. To help with that, we need to know what your media player is, and what Serviio profile you are currently using. If you don't know what profile is selected, look on the Serviio console on the status tab, find your player (depending on what's on your network, there may only be the Serviio computer and the player), and look at the far right column to see the selected profile.
If the profile selected doesn't seem to be a match for your player, see if something else in the list fits better. After changing the selection, remember to press the Save button.
NX3
Post Sun Dec 14, 2014 11:03 am
As all of the above great post but also homeplugs could help with buffer issues if you can't hardwire.
freaknik
Post Sun Dec 14, 2014 11:31 am
Thank you so much.
My players are a Panasonic Bluray player and android phones and iphones.
The Panasonic Bluray has the Panasonic BD player profile, the others have generic.
Phones play everything they see in the menu (still not these m4v files, but mkv started showing in menu and playing).
So I couldn't get mediainfo to work but here are the results from a ffmpeg -i in the command prompt on one of the ones I really want to watch on my tv:
ffmpeg -i "Y:\\aint you seen my movies\\12 Stimpy's Fan Club.m4v"
ffmpeg version git-2014-06-13-043bcdc Copyright (c) 2000-2014 the FFmpeg developers
  built on Jun 13 2014 22:27:56 with gcc 4.9.0 (Rev4, Built by MSYS2 project)
  configuration: --arch=x86_64 --target-os=mingw32 --prefix=/local64 --bindir=/local64/bin-video --disable-debug --disable-shared --enable-gpl --enable-version3 --enable-runtime-cpudetect --enable-avfilter --enable-bzlib --enable-zlib --enable-librtmp --enable-gnutls --enable-avisynth --enable-frei0r --enable-filter=frei0r --enable-libbluray --enable-libcaca --enable-libopenjpeg --enable-fontconfig --enable-libfreetype --enable-libass --enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvo-amrwbenc --enable-libschroedinger --enable-libsoxr --enable-libtwolame --enable-libutvideo --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libvo-aacenc --enable-libopus --enable-libvidstab --enable-libvpx --enable-libwavpack --enable-libxavs --enable-libx264 --enable-libx265 --enable-libxvid --enable-libzvbi
  libavutil      52. 89.100 / 52. 89.100
  libavcodec     55. 66.100 / 55. 66.100
  libavformat    55. 43.100 / 55. 43.100
  libavdevice    55. 13.101 / 55. 13.101
  libavfilter     4.  8.100 /  4.  8.100
  libswscale      2.  6.100 /  2.  6.100
  libswresample   0. 19.100 /  0. 19.100
Splitting the commandline.
Reading option '-report' ... matched as option 'report' (generate a report) with argument '1'.
Reading option '-i' ... matched as input file with argument 'Y:\aint you seen my movies\12 Stimpy's Fan Club.m4v'.
Finished splitting the commandline.
Parsing a group of options: global .
Applying option report (generate a report) with argument 1.
Successfully parsed a group of options.
Parsing a group of options: input file Y:\aint you seen my movies\12 Stimpy's Fan Club.m4v.
Opening an input file: Y:\aint you seen my movies\12 Stimpy's Fan Club.m4v.
[mov,mp4,m4a,3gp,3g2,mj2 @ 0000000004ac4b80] Format mov,mp4,m4a,3gp,3g2,mj2 probed with size=2048 and score=100
[mov,mp4,m4a,3gp,3g2,mj2 @ 0000000004ac4b80] ISO: File Type Major Brand: M4V
[mov,mp4,m4a,3gp,3g2,mj2 @ 0000000004ac4b80] stream 0, timescale not set
[mov,mp4,m4a,3gp,3g2,mj2 @ 0000000004ac4b80] Before avformat_find_stream_info() pos: 1576645 bytes read:764399 seeks:3
[mjpeg @ 0000000004ac8dc0] marker=d8 avail_size_in_buf=166575
[mjpeg @ 0000000004ac8dc0] marker parser used 0 bytes (0 bits)
[mjpeg @ 0000000004ac8dc0] marker=e0 avail_size_in_buf=166573
[mjpeg @ 0000000004ac8dc0] marker parser used 16 bytes (128 bits)
[mjpeg @ 0000000004ac8dc0] marker=db avail_size_in_buf=166555
[mjpeg @ 0000000004ac8dc0] index=0
[mjpeg @ 0000000004ac8dc0] qscale[0]: 1
[mjpeg @ 0000000004ac8dc0] marker parser used 67 bytes (536 bits)
[mjpeg @ 0000000004ac8dc0] marker=db avail_size_in_buf=166486
[mjpeg @ 0000000004ac8dc0] index=1
[mjpeg @ 0000000004ac8dc0] qscale[1]: 2
[mjpeg @ 0000000004ac8dc0] marker=c0 avail_size_in_buf=166417
[mjpeg @ 0000000004ac8dc0] sof0: picture: 640x640
[mjpeg @ 0000000004ac8dc0] component 0 1:1 id: 0 quant:0
[mjpeg @ 0000000004ac8dc0] component 1 1:1 id: 1 quant:1
[mjpeg @ 0000000004ac8dc0] component 2 1:1 id: 2 quant:1
[mjpeg @ 0000000004ac8dc0] pix fmt id 11111100
[mjpeg @ 0000000004ac8dc0] marker parser used 17 bytes (136 bits)
[mjpeg @ 0000000004ac8dc0] marker=c4 avail_size_in_buf=166398
[mjpeg @ 0000000004ac8dc0] class=0 index=0 nb_codes=11
[mjpeg @ 0000000004ac8dc0] marker parser used 30 bytes (240 bits)
[mjpeg @ 0000000004ac8dc0] marker=c4 avail_size_in_buf=166366
[mjpeg @ 0000000004ac8dc0] class=1 index=0 nb_codes=242
[mjpeg @ 0000000004ac8dc0] marker parser used 92 bytes (736 bits)
[mjpeg @ 0000000004ac8dc0] marker=c4 avail_size_in_buf=166272
[mjpeg @ 0000000004ac8dc0] class=0 index=1 nb_codes=10
[mjpeg @ 0000000004ac8dc0] marker parser used 29 bytes (232 bits)
[mjpeg @ 0000000004ac8dc0] marker=c4 avail_size_in_buf=166241
[mjpeg @ 0000000004ac8dc0] class=1 index=1 nb_codes=242
[mjpeg @ 0000000004ac8dc0] marker parser used 74 bytes (592 bits)
[mjpeg @ 0000000004ac8dc0] escaping removed 493 bytes
[mjpeg @ 0000000004ac8dc0] marker=da avail_size_in_buf=166165
[mjpeg @ 0000000004ac8dc0] component: 0
[mjpeg @ 0000000004ac8dc0] component: 1
[mjpeg @ 0000000004ac8dc0] component: 2
[mjpeg @ 0000000004ac8dc0] marker parser used 165671 bytes (1325361 bits)
[mjpeg @ 0000000004ac8dc0] marker=d9 avail_size_in_buf=0
[mjpeg @ 0000000004ac8dc0] decode frame unused 0 bytes
[mov,mp4,m4a,3gp,3g2,mj2 @ 0000000004ac4b80] max_analyze_duration 5000000 reached at 5015510 microseconds
[mov,mp4,m4a,3gp,3g2,mj2 @ 0000000004ac4b80] Could not find codec parameters for stream 1 (Video: none (drmi / 0x696D7264), 640x480, 1573 kb/s): unknown codec
Consider increasing the value for the 'analyzeduration' and 'probesize' options
[mov,mp4,m4a,3gp,3g2,mj2 @ 0000000004ac4b80] After avformat_find_stream_info() pos: 2804590 bytes read:2042355 seeks:5 frames:338
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Y:\aint you seen my movies\12 Stimpy's Fan Club.m4v':
    major_brand     : M4V
    minor_version   : 0
    compatible_brands: M4V mp42isom
    creation_time   : 2009-05-12 11:53:46
    title           : Stimpy's Fan Club
    artist          : Ren & Stimpy
    album_artist    : Ren & Stimpy
    album           : Best of Ren & Stimpy, Vol. 1
    genre           : Animation
    track           : 12
    disc            : 1/1
    compilation     : 0
    gapless_playback: 0
    date            : 1993-04-24T07:00:00Z
    copyright       : © 2009 Viacom Inc.
    description     : Stimpy is receiving fan mail every day. Ren gets more and more jealous until he just can't take it anymore. Stimpy, realizing this, makes Ren President of the fan club in charge of answering all the letters.
    network         : Nick Rewind
    show            : Ren & Stimpy
    episode_id      : 017
    season_number   : 1
    episode_sort    : 12
    media_type      : 10
    iTunEXTC        : us-tv|TV-Y7|200|
    synopsis        : Stimpy is receiving fan mail every day. Ren gets more and more jealous until he just can't take it anymore. Stimpy, realizing this, makes Ren President of the fan club in charge of answering all the letters.
    iTunMOVI        : <?xml version="1.0" encoding="UTF-8"?>
                    : <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
                    : <plist version="1.0">
                    : <dict>
                    :    <key>asset-info</key>
                    :    <dict>
                    :       <key>file-size</key>
                    :       <integer>295092469</integer>
                    :       <key>flavor</key>
                    :       <string>4:640x480LC-128</string>
                    :    </dict>
                    : </dict>
                    : </plist>
    timecode        : 00:00:00:00
  Duration: 00:23:01.80, start: 0.000000, bitrate: 1708 kb/s
    Stream #0:0(eng), 218, 1/44100: Audio: aac (drms / 0x736D7264), 44100 Hz, stereo, fltp, 126 kb/s (default)
      creation_time   : 2009-05-12 13:04:48
      handler_name    : Apple Sound Media Handler
    Stream #0:1(eng), 118, 1/2997: Video: none (drmi / 0x696D7264), 640x480, 1573 kb/s, 23.98 fps, 23.98 tbr, 2997 tbn, 2997 tbc (default)
      handler_name    : Apple Video Media Handler
    Stream #0:2(eng), 1, 1/2997: Data: none (tmcd / 0x64636D74) (default)
      creation_time   : 2009-05-12 13:05:15
      handler_name    : Time Code Media Handler
    Stream #0:3, 1, 1/90000: Video: mjpeg, yuvj444p(pc), 640x640 [SAR 100:100 DAR 1:1], 90k tbr, 90k tbn, 90k tbc
Successfully opened the file.
[AVIOContext @ 0000000004acd2e0] Statistics: 2042355 bytes read, 5 seeks
I will try to set the Serviio program running on a hard line.
Let me know if you think there is a way to get this movie and ones like it to show in the menu and play.
And thanks for such a fast and detailed response on the weekend.
Post Sun Dec 14, 2014 10:28 pm
your ffmpeg couldn't detect the video track and it's codec. Try to use the latest ffmpeg.
freaknik
Post Mon Dec 15, 2014 1:18 am
>ffmpeg -i "Y:\aint you seen my movies\12 Stimpy's Fan Club.m4v"
ffmpeg version N-68399-g10ef8f0 Copyright (c) 2000-2014 the FFmpeg developers
  built on Dec 12 2014 22:12:56 with gcc 4.9.2 (GCC)
  configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av
isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab
le-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --
enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-lib
b --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinge
r --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --en
able-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis
 --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-
libx265 --enable-libxavs --enable-libxvid --enable-decklink --enable-zlib
  libavutil      54. 15.100 / 54. 15.100
  libavcodec     56. 14.100 / 56. 14.100
  libavformat    56. 15.104 / 56. 15.104
  libavdevice    56.  3.100 / 56.  3.100
  libavfilter     5.  3.101 /  5.  3.101
  libswscale      3.  1.101 /  3.  1.101
  libswresample   1.  1.100 /  1.  1.100
  libpostproc    53.  3.100 / 53.  3.100
[mov,mp4,m4a,3gp,3g2,mj2 @ 0000000004802a00] stream 0, timescale not set
[mov,mp4,m4a,3gp,3g2,mj2 @ 0000000004802a00] Could not find codec parameters for
 stream 1 (Video: none (drmi / 0x696D7264), none, 640x480, 1573 kb/s): unknown c
odec
Fan Club.m4v':
    major_brand     : M4V
    minor_version   : 0
    genre           : Animation
    track           : 12
    disc            : 1/1
    compilation     : 0
    gapless_playback: 0
    account_id      : uhuhuhnotwithoutthepassword!uhuhuhnotwithoutthepassword!uhuhuhnotwithoutthepassword!
    copyright       : ┬⌐ 2009 Viacom Inc.
    show            : Ren & Stimpy
    episode_id      : 017
    season_number   : 1
    episode_sort    : 12
    media_type      : 10
    purchase_date   : 2012-04-25 02:49:04
    sort_album      : Best of Ren & Stimpy, Vol. 1
                    : <dict>
                    :   <dict>
                    :           <key>flavor</key>
                    :   </dict>
                    : </dict>
                    : </plist>
    Stream #0:0(eng): Audio: aac (LC) (drms / 0x736D7264), 44100 Hz, stereo, flt
      handler_name    : ?Apple Sound Media Handler
    Stream #0:1(eng): Video: none (drmi / 0x696D7264), none, 640x480, 1573 kb/s,
      handler_name    : ?Apple Video Media Handler
    Stream #0:2(eng): Data: none (tmcd / 0x64636D74) (default)
      handler_name    : ?Time Code Media Handler
    Stream #0:3: Video: mjpeg, yuvj444p(pc, bt470bg/unknown/unknown), 640x640 [S
Looks like same thing unfortunately.
Complete name                            : \\CISCO33327\Boombaclot\aint you seen my movies\12 Stimpy's Fan Club.m4v
Codec ID                                 : M4V
File size                                : 281 MiB
Duration                                 : 23mn 1s
Overall bit rate                         : 1 708 Kbps
Collection                               : Ren & Stimpy
Season                                   : 1
Album                                    : Best of Ren & Stimpy, Vol. 1
Album/Sorted by                          : Best of Ren & Stimpy, Vol. 1
Album/Performer                          : Ren & Stimpy
Part                                     : 12
Part/Position                            : 1
Part/Total                               : 1
Track name                               : Stimpy's Fan Club
Track name/Position                      : 12
Genre                                    : Animation
ContentType                              : TV Show
Description                              : Stimpy is receiving fan mail every day. Ren gets more and more jealous until he just can't take it anymore. Stimpy, realizing this, makes Ren President of the fan club in charge of answering all the letters. / Slap on your Happy Helmets with everyone’s favorite psychotic Chihuahua and stupid cat in these Season 1 and 2 classics. Watch them descend into Space Madness, sell Rubber Nipples, become heroic firedogs, search for Stimpy’s stinky “son,” and more!
Recorded date                            : UTC 1993-04-24 07:00:00
Encoded date                             : UTC 2009-05-12 11:53:46
Tagged date                              : UTC 2009-05-12 13:05:15
Writing library                          : Apple QuickTime
Copyright                                : © 2009 Viacom Inc.
Cover                                    : Yes
AppleStoreAccount                        : steve@rim.jobs
AppleStoreCatalogID                      : 312323196
AlbumTitleID                             : 312082951
PlayListID                               : 312082954
GenreID                                  : 4002
AppleStoreCountry                        : United States
TVNetworkName                            : Nick Rewind
Part_ID                                  : 017
PurchaseDate                             : 2012-04-25 02:49:04
ContentRating                            : us-tv|TV-Y7|200|
LongDescription                          : Stimpy is receiving fan mail every day. Ren gets more and more jealous until he just can't take it anymore. Stimpy, realizing this, makes Ren President of the fan club in charge of answering all the letters.
iTunMOVI                                 : <?xml version="1.0" encoding="UTF-8"?> / <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> / <plist version="1.0"> / <dict> /    <key>asset-info</key> /    <dict> /       <key>file-size</key> /       <integer>295092469</integer> /       <key>flavor</key> /       <string>4:640x480LC-128</string> /    </dict> / </dict> / </plist>
Format profile                           : Baseline@L3.0
Format settings, CABAC                   : No
Format settings, ReFrames                : 1 frame
Codec ID                                 : drmi / avc1
Codec ID/Info                            : Advanced Video Coding
Duration                                 : 23mn 1s
Bit rate                                 : 1 573 Kbps
Width                                    : 640 pixels
Height                                   : 480 pixels
Display aspect ratio                     : 4:3
Bits/(Pixel*Frame)                       : 0.214
Stream size                              : 259 MiB (92%)
Encoded date                             : UTC 2009-05-12 13:04:48
Color primaries                          : BT.601 NTSC
Matrix coefficients                      : BT.601
Codec ID                                 : 40
Duration                                 : 23mn 1s
Source duration                          : 23mn 1s
Bit rate                                 : 128 Kbps
Sampling rate                            : 44.1 KHz
Stream size                              : 20.8 MiB (7%)
Source stream size                       : 20.8 MiB (7%)
Encryption                               : iTunes
Other
Type                                     : Time code
Format                                   : QuickTime TC
Duration                                 : 23mn 1s
Time code of first frame                 : 00:00:00:00
Time code, striped                       : Yes
Encoded date                             : UTC 2009-05-12 13:05:15
Looks like the ones that aren't working are all from iTunes. Would they have put something on their files so I only can watch them with AppleTV or ipad or one of their products?
freaknik
Post Mon Dec 15, 2014 12:13 pm
This one plays perfectly.
These m4v movies are from itunes and have drm so you can only play them there. Codec is avc1 with drm on top of it that only itunes can take off unless you re encode the files as avc1 without the drm.
I must have done it with the one below because now only drm files are not in Serviio, ALL my other movies regardless of filetype or warning in the log are in the serviio menu.
So case closed, I am just a dummy and forgot the whole m4v fiasco because it has been so long since I have used an apple product.
I made it a habbit of always downloading the free shows in the itunes store (national geographic, cartoons, all in good quality).
But then when I went to watch them outside itunes, even though they are "free" and I "own" them, I can't play them with mpc or serviio or anything that isn't apple.
And I forgot about it because when I discovered this was when I got an android phone and never touched anything apple again.
When I got my new 2tb drive I piled in every movie I had and it had been so many years its a lot of movies and I forgot about drm and that whole can of worms.
Complete name                            : Y:\aint you seen my movies\Victory By Design - The Making Of.m4v
Codec ID                                 : M4V
File size                                : 253 MiB
Duration                                 : 21mn 33s
Overall bit rate                         : 1 643 Kbps
Encoded date                             : UTC 2008-11-26 03:43:45
Tagged date                              : UTC 2008-11-26 05:02:19
Codec ID                                 : avc1
Duration                                 : 21mn 33s
Bit rate                                 : 1 520 Kbps
Width                                    : 640 pixels
Height                                   : 480 pixels
Frame rate                               : 29.970 fps
Bits/(Pixel*Frame)                       : 0.165
Stream size                              : 234 MiB (93%)
Encoded date                             : UTC 2008-11-26 05:01:55
Codec ID                                 : 40
Duration                                 : 21mn 33s
Source duration                          : 21mn 33s
Bit rate                                 : 113 Kbps
Nominal bit rate                         : 128 Kbps
Stream size                              : 17.5 MiB (7%)
Source stream size                       : 17.5 MiB (7%)
Other
Type                                     : Time code
Encoded date                             : UTC 2008-11-26 05:02:18
Thanks for trying to help guys, Serviio works well as it was designed.
The difference between the apple goons and you guys is evident in your enthusiasm, diagnostic ability, and the fact that you genuinely seem more interested in helping customers enjoy the free version of your product.
Apple tries to cram proprietary hardware down your throat that expires every two years to obsolescence (iOS X.xx isn't availible on your device, please spend another $500).
Post Mon Dec 15, 2014 1:33 pm
AH, good old DRM. That explains it. :roll:
Glad you figured it out. Don't know if we helped much, but glad to try. :D
